2006 pontiac vibe ignition wire
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=124333
Printed Date: May 01, 2026 at 2:41 AM
Topic: 2006 pontiac vibe ignition wire
Posted By: laserbeak43
Subject: 2006 pontiac vibe ignition wire
Date Posted: November 08, 2010 at 12:22 PM
hello,
I have an alarm and have put its ignition wire on the BLACK/ white ignition wire"S" on the ignition pin. Are there supposed to be two wires? it doesn't look like their working either, since i can't get into programming mode and the fact that my car is turned on or off is ignored by the alarm.
Posted By: corrado007
Date Posted: November 12, 2010 at 4:12 PM
laserbeak43 wrote:
hello,
I only saw '07 listed here so I pulled the following from Code Systems website.
2006 Pontiac Vibe
Battery         BLACK      (+)        IGNITION SWITCH HARNESS
Ignition 1 BLACK / YELLOW (+)     IGNITION SWITCH HARNESS
Ignition 2 BLACK/ WHITE (+)     Ignition Switch Harness
Accessory 1 BLUE/RED     (+)     Ignition Switch Harness
Starter 1   RED          (+)     IGNITION SWITCH HARNESS
You should probably test the wires before hooking them up to ensure you are using the right one. Looks like you have 2 ignition wires and you're currently hooked up to ignition 2.
Date Posted: November 24, 2010 at 8:37 PM
Hi,
Thanks for your reply, and sorry mine is so late, but the two ignition wires are both black and white, the white stripe on one, is smaller than the other though. I've tried the BLACK / YELLOW one, had no effect.
I'll let you know if i can figure it out.
Date Posted: November 25, 2010 at 3:56 PM
oh that was the right one, the taps i were using were too big for that particular wire.
Posted By: howie ll
Date Posted: November 26, 2010 at 1:41 PM
TAPS? Blasphemy ban this person from the site! SOLDER and Scotch 33+.
Date Posted: November 27, 2010 at 9:03 AM
i hear you, the connections feel flimsy.
