2004 ford expedition alarm wiring?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=124420
Printed Date: April 30, 2026 at 9:59 PM
Topic: 2004 ford expedition alarm wiring?
Posted By: rodstar1
Subject: 2004 ford expedition alarm wiring?
Date Posted: November 13, 2010 at 1:03 AM
Could someone please help with alarm wiring guide for 2004 ford expedition....?
------------- Rod Forbes
Posted By: ExtremeProAudio
Date Posted: November 15, 2010 at 11:15 AM
DIRECTWIRE™ WIRING INFORMATION - FORD / EXPEDITION / 2004 / Security
12volts lt. GREEN/ purple + ignition harness
Starter RED / lt. blue + ignition harness
Ignition blue/lt. green + ignition harness
Power Lock pink / YELLOW - driver kick panel or VSM
Notes: The VSM (Vehicle Security Module) is high in the passenger kick panel.
Power Unlock pink/lt. green - driver kick panel or VSM
Lock Motor pink/black 5wi driver kick panel or VSM
Unlock Motor RED / orange 5wi driver kick panel or VSM
Disarm Defeat pink/orange 5wi pass. kick panel or VSM
Parking Lights+ brown + headlight switch or DKP
Parking Lights- N/A
Hazards same as turn signals
Turn Signal(L) lt grn/wht(F), lt grn/org(R) + steering column
Turn Signal(R) wht/lt blu(F), org/lt blu(R) + steering column
Door Trigger BLACK/ lt. blue + driver kick, harness to rear
Dome Supervision use door trigger wire
Trunk/Hatch Pin common with door trigger
Hood Pin N/A
Trunk/Hatch Release WHITE/ pink + pass. kick panel or VSM
This wire is for the liftgate glass release. For the power liftgate open/close use gray/red (-) at the switch in the roof or at the power liftgate module in the left rear quarter panel.
Power Sliding Door N/A
Factory Alarm Arm N/A
Factory Alarm Disarm N/A
Disarm No Unlock N/A
Tachometer NOT RED / lt. green ac any ignition coil
Horn Trigger dk. blue - steering column or VSM
Memory Seat 1 BROWN / lt. green - module under driver seat
Memory Seat 2 BLACK/ orange - module under driver seat
Memory Seat 3 N/A -
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
SecuriLock
Part #: XK04
Alternate Part1 #: 1100F/1100X
Alternate Part2 #: 556SW
Alternate Part3 #: 556UW
Alternate Part4 #: DesignTech 20402
Alternate Part5 #: DesignTech 29402
Notes: Standard on all models. When using the 1100X, a software change to 1100FM is needed.
warning
