2011 volvo xc60 info.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=128374
Printed Date: May 14, 2026 at 10:30 AM
Topic: 2011 volvo xc60 info.
Posted By: 12volt.installs
Subject: 2011 volvo xc60 info.
Date Posted: August 27, 2011 at 10:42 PM
In the up coming week i will be installing a full stereo system with all rockford components the R400-4d with the R750-1d and the massive audio flat line 8 ch. high levell audio processer. but i seem to not be able to find any info on the vhicle i was just curious if anyone has worked on one and know the location of the oem amplfer and the dolby digital processor. and maybe how to get the radio out and wire/speaker colors
thank you ------------- Shawn Nickeson
Posted By: howie ll
Date Posted: August 28, 2011 at 3:35 AM
2010: Amp if present is under the passenger seat, I'll post the info on this site if required.
According to Directechs the radio ignition is CAN and the amp turn on is a MOST bus. I strongly suggest outing the factory amp and looking through Metra, Scosche etc. for head unit adaptors.
Date Posted: August 29, 2011 at 2:16 PM
thank you yes can you ost any wiring colors you may have. and i am actually leaving the oem radio in the car. and added a 4 channel and a mono block amp. so i wold need the high level input to the flatline processor but the wiring would be fantasic thanks
Posted By: howie ll
Date Posted: August 29, 2011 at 2:36 PM
Look under Downloads/Manuals alarm section, I posted the 2010, it's the latest I can access.
Date Posted: August 29, 2011 at 3:24 PM
thanks you very much dude that should be a hugh help
