99 honda civic wiring guide
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=128764
Printed Date: May 14, 2026 at 10:27 AM
Topic: 99 honda civic wiring guide
Posted By: nilliejones
Subject: 99 honda civic wiring guide
Date Posted: October 08, 2011 at 6:23 PM
I have a different assortment of wires than the ones listed in my car.
I have:
White with blue
yellow with red
red with black
red
black
gray with black
red with green
brown with black
blue
blue with yellow
gray with white
red with yellow
brown with white
I need help knowing which are for the:
1) +12 V Battery
2) +12 V Ignition
3) dash dimmer
Posted By: i am an idiot
Date Posted: October 08, 2011 at 8:25 PM
Has the plug already been cut off of the wires?  If not, do not do it.  You can purchase the harness for 15 dollars.  It has been a long time, but I think Yellow/Red and WHITE/ Blue are constant and switched 12 volts.
Date Posted: October 08, 2011 at 10:22 PM
Yeah, I cut it off and I have the part to reconnect. That's where I'm stuck at because the dash light no longer work / the warning signal for when I leave the lights on but get out of the car.
I'll try that combo. Thanks.
Posted By: howie ll
Date Posted: October 09, 2011 at 10:00 AM
White with blue = 12v+ constant 7.5amp fuse under hood. Also clock
yellow with red = 12v+ ACC under dash fuse box.
red with black = Illumination, you may have shorted this one*
red = ? = RED / green = Right front +
black = Ground (0v)
gray with black = Left front -
red with green = Right front +
brown with black = Right front -
blue ? = blue/green = Left front +
blue with yellow = Left rear +
gray with white = Left rear -
red with yellow = Right rear +
brown with white = Right rear -
The above would have taken Mr. I or myself less time to find these out than to write them down using a good old test light.
Dash light, actually running or side lights depending on which side of the Atlantic you're from to buzzer to ground through door switch. Does your dome light come on when you open the driver's door? If not it's the driver's door switch at fault especially those awful corroding slide switches.
