2011 nissan quest sl remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=129264
Printed Date: March 21, 2026 at 2:28 PM
Topic: 2011 nissan quest sl remote start
Posted By: nixapatfan
Subject: 2011 nissan quest sl remote start
Date Posted: November 17, 2011 at 8:43 AM
Anyone have wiring diagrams for a 2011 Nissan Quest SL? I want to install a remote start system on it. I'd also like info on bypassing the immobilizer.
I'm looking to install the Audiovox AS9234 and a compatible immobilizer bypass with data link(Flashlogic - but Quest not listed compatible yet) so I can use the factory key fobs and keep installation clean.
If anyone has a better solutoin for a system like this, I'm open to suggestions.
Posted By: ropuma
Date Posted: January 14, 2012 at 11:19 AM
          (+)          BCM, PIN 15 OF WHITE 15 PIN PLUG
     Ignition 1          GRAY          (+)          BCM, PIN 29 OF WHITE 40 PIN PLUG
     Starter 1          VIOLET (PUSHBUTTON START)          (-)          AT IGNITION SWITCH OR BCM, PIN 6 OF WHITE 40 PIN PLUG
     Domelight Super          RED OR WHITE          (-)          BCM, PIN 7 OR 8 OF WHITE 15 PIN PLUG
     LF Latch          GREEN          (-)          BCM, PIN 7 OF BLACK 15 PIN PLUG
     RF Latch          LT BLUE          (-)          BCM, PIN 5 OF BLACK 15 PIN PLUG
     LR Latch          ORANGE          (-)          BCM, PIN 8 OF BLACK 15 PIN PLUG
     RR Latch          RED          (-)          BCM, PIN 6 OF BLACK 15 PIN PLUG
     Trunk Trigger          PINK          (-)          BCM, PIN 3 OF BLACK 15 PIN PLUG
     Alarm Disarm          WHITE (KEY CYLINDER IN DR. DOOR)          (-)          BCM, PIN 7 OF 40 PIN BLACK PLUG (WITHOUT POWER SLIDING DOOR) DOUBLE PULSE
     Alarm Arm          YELLOW (KEY CYLINDER IN DR. DOOR)          (-)          BCM, PIN 8 OF 40 PIN BLACK PLUG (WITHOUT POWER SLIDING DOOR)
     Parking Lights          RED / BLUE          (+)          AT FUSE BOX, PIN 8 OF WHITE 10 PIN PLUG
     Low Crr Pk Lights          AUTO LAMPS: WHITE          (-)          BCM, PIN 33 OF 40 PIN BLACK PLUG
     Note: makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
Posted By: shortcircuit161
Date Posted: January 14, 2012 at 11:42 AM
Not sure if this is the PTS or Standard Key model but both DEI (Xpresskit) and Fortin show bypass modules for this vehicle.
Check
-ifar.ca (Fortin)
-xpresskit.com (DEI)
Idatalink (maker of the Flashlogic units) don't have that model listed.
DEI shows the DB-ALL will work for it.
Fortin shows the EVO-CAN or EVO-ALL will work for it.
Either module will have to be flashed to the correct firmware.
I believe the Fortin bypass will work with datalink on that model of remote starter. But any of the bypasses will work well if connected Wire2Wire.
