| Print Page | Close Window |
2011 mitsubishi outlander sportsmart keyPrinted From: the12volt.comForum Name: Vehicle Wiring Information & File Requests Forum Discription: Request Car Alarm, Car Stereo, Cruise Control, Remote Starter, Navigation, Mobile Video, and Other Vehicle Specific Wiring Info, Manuals, Tech Tips URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=129294 Printed Date: March 21, 2026 at 11:07 AM Topic: 2011 mitsubishi outlander sportsmart key Posted By: superwhite06 Subject: 2011 mitsubishi outlander sportsmart key Date Posted: November 19, 2011 at 8:12 PM I am looking for a wiring diagram for a 2011 Mitsubishi Outlander Sport with the Smart Key. I want to install a remote start only.
Thank you very much Greg Replies: Posted By: Velocity Motors Date Posted: November 20, 2011 at 4:46 PM 12 Volts purple (without KOS), red (with KOS) (10A) + ignition switch, 6 pin plug, pin 1 or engine switch, 10 pin plug, pin 10
Second 12 Volts BLACK/ red (80A), BLACK/ gray (80A) + dash fuse box, black 2 pin plug, pins 1 and 2 Starter lt. blue (without Keyless Operating System) + ignition switch, 6 pin plug, pin 5 Second Starter pink (with Keyless Operating System) + engine switch, 10 pin plug, pin 4 Ignition white + ignition switch, 6 pin plug, pin 2 On vehicles with Keyless Operating System, use white (for ignition sense only) at the dash fuse box, 15 pin plug, pin 6. Second Ignition N/A Third Ignition N/A Accessory lt. green + ignition switch, 6 pin plug, pin 6 On vehicles with Keyless Operating System, use lt. green (for accessory sense only) at the dash fuse box, 15 pin plug, pin 7. Second Accessory N/A Third Accessory N/A Keysense brown (without Keyless Operating System) - N.C. ignition key switch, 7 pin plug, pin 6 Data Bus N/A Can Bus High green (CAN-B); brown (CAN-C) data dash fuse box, 24 pin plug, pins 6 and 9 Can Bus Low red (CAN-B); yellow (CAN-C) data dash fuse box, 24 pin plug, pins 7 and 8 Can Bus Sw N/A Power Lock purple - dash fuse box, 24 pin plug, pin 2 Power Unlock white - dash fuse box, 19 pin plug, pin 15 Lock Motor lt. green 5 wire dash fuse box, 19 pin plug, pin 6 Driver Unlock Motor purple 5 wire dash fuse box, 19 pin plug, pin 2 Passenger Unlock Motor green 5 wire dash fuse box, 19 pin plug, pin 5 Parking Lights (-) (LIN bus) Parking Lights (+) yellow (L); pink (R) + dash fuse box, 20 pin plug, pins 10 and 13 Hazards lt. green - dash fuse box, 24 pin plug, pin 19 Turn Signal (Left) green + dash fuse box, 20 pin plug, pin 18 Turn Signal (Right) purple + dash fuse box, 20 pin plug, pin 19 Headlight purple (L); green (H) - dash fuse box, 16 pin plug, pins 6 and 13 AutoLights Reverse Light white + dash fuse box, 20 pin plug, pin 2 Left Front Door Trigger yellow - dash fuse box, brown 16 pin plug, pin 16 Right Front Door Trigger green - dash fuse box, brown 16 pin plug, pin 12 Left Rear Door Trigger red - dash fuse box, brown 16 pin plug, pin 7 Right Rear Door Trigger lt. green - dash fuse box, brown 16 pin plug, pin 8 Dome Supervision yellow - dash fuse box, 6 pin plug, pin 5 Trunk/Hatch Pin pink - dash fuse box, brown 16 pin plug, pin 5 Rear Glass Pin N/A Hood Pin pink - dash fuse box, 16 pin plug, pin 12 Trunk/Hatch Release brown (rear handle switch) - dash fuse box, brown 16 pin plug, pin 14 Trunk Release Motor green 5 wire dash fuse box, 20 pin plug, pin 1 Fuel Door Release N/A Power Sliding Door (Left) N/A Power Sliding Door (Right) N/A Factory Alarm Arm factory remote only Factory Alarm Disarm factory remote only Disarm No Unlock Transponder and ignition Trunk Alarm Shunt N/A Tachometer lt. green, yellow, green, or white ac any fuel injector, gray 2 pin plug, pin 2 Wait to Start N/A Neutral Safety N/A Clutch Pedal yellow (input); pink (output) + N.O. clutch switch, 2 pin plug, pins 1 and 2 Fuel Pump blue + dash fuse box, 2 pin plug, pin 1 Rear Defroster lt. blue - latched dash fuse box, 24 pin plug, pin 12 Mirror Defroster same as rear defroster Left Front Heated Seat 5 wire left heated seat switch, 6 pin plug, pin 5 Right Front Heated Seat 5 wire right heated seat switch, 6 pin plug, pin 5 Speed Sense brown ac radio, 20 pin plug, pin 11 Brake Wire lt. green + brake switch, 4 pin plug, pin 2 Parking Brake lt. green - driver kick, 18 pin plug, pin 15 Horn Trigger green - dash fuse box, 19 pin plug, pin 19 Wipers white - dash fuse box, 24 pin plug, pin 21 Left Front Window (Up/Down) pink - blue A power window main switch, 19 pin plug, pins 2 and 6 Right Front Window (Up/Down) lt. blue - green A driver kick, 12 pin plug, pins 6 and 5 Left Rear Window (Up/Down) white - lt. green A driver kick, 12 pin plug, pins 2 and 1 Right Rear Window (Up/Down) gray - yellow A driver kick, 12 pin plug, pins 12 and 11 Sun Roof (Open/Close) green - brown (function with ignition on only) - sunshade switch, black 6 pin plug, pins 5 and 6 Sun Roof (Limit/Close) N/A Memory Seat 1 N/A Memory Seat 2 N/A Memory Seat 3 N/A Radio 12V red + radio, 20 pin plug, pin 10 Radio Ground black - radio, 20 pin plug, pin 20 Radio Ignition white + radio, 20 pin plug, pin 1 Radio Illumination pink (dimmer) + radio, 20 pin plug, pin 9 Factory Amp Turn-on lt. blue + radio, 18 pin plug, pin 17 Power Antenna pink + radio, 20 pin plug, pin 14 Left Front Speaker (+/-) white - black +,- radio, 20 pin plug, pins 8 and 18 If equipped, the amplifier is under the front passenger seat. On vehicles with amplifier, the speaker wires are purple - blue at the amplifier, 18 pin plug, pins 8 and 18. The tweeter wires are brown - yellow at the amplifier, 14 pin plug, pins 6 and 14. Right Front Speaker (+/-) red - green +,- radio, 20 pin plug, pins 6 and 16 If equipped, the amplifier is under the front passenger seat. On vehicles with amplifier, the speaker wires are yellow - brown at the amplifier, 18 pin plug, pins 7 and 17. The tweeter wires are pink - blue at the amplifier, 14 pin plug, pins 5 and 13. Left Rear Speaker (+/-) brown - yellow +,- radio, 20 pin plug, pins 7 and 17 If equipped, the amplifier is under the front passenger seat. On vehicles with amplifier, the speaker wires are green - red at the amplifier, 14 pin plug, pins 1 and 7. Right Rear Speaker (+/-) blue - lt. green +,- radio, 20 pin plug, pins 5 and 15 If equipped, the amplifier is under the front passenger seat. On vehicles with amplifier, the speaker wires are purple - pink at the amplifier, 14 pin plug, pins 2 and 8. Center Channel (+/-) N/A Subwoofer (+/-) green - pink (1); white - gray (2) +,- amplifier, 18 pin plug, pins 1 and 9; 2 and 10 If equipped, the amplifier is under the front passenger seat. Aux. Audio Input Left (+/-) purple - gray +,- radio, 18 pin plug, pins 13 and 14 Aux. Audio Input Right (+/-) lt. green - gray +,- radio, 18 pin plug, pins 4 and 14 RSE Video (+/-) white - gray (rear view camera video) +,- radio, 24 pin plug, pins 7 and 20 RSE Audio Left (+/-) black - gray (USB audio) +,- radio, 18 pin plug, pins 12 and 2 RSE Audio Right (+/-) white - gray (USB audio) +,- radio, 18 pin plug, pins 3 and 2 Satellite Radio 12 Volts gray + Satellite Radio Tuner, 14 pin plug, pin 1 If equipped, the Satellite Radio Tuner is behind the glove box. Satellite Radio Ground black - Satellite Radio Tuner, 14 pin plug, pin 8 Satellite Radio Ignition (CAN-B) Satellite Radio Antenna (coaxial cable) Satellite Audio Left (+/-) pink - gray +,- Satellite Radio Tuner, 14 pin plug, pins 6 and 7 Satellite Audio Right (+/-) blue - gray +,- Satellite Radio Tuner, 14 pin plug, pins 14 and 7 Item Size Depth Location Headunit irregular center of dash Left Front Speaker 6.3 left front door Left Front Tweeter 1.4 left front door Right Front Speaker 6.3 right front door Right Front Tweeter 1.4 right front door Left Rear Speaker 6.3 left rear door Left Rear Tweeter N/A Right Rear Speaker 6.3 right rear door Right Rear Tweeter N/A Center Channel N/A Subwoofer 9.8 right rear quarter panel Left Front Headrest Right Front Headrest Left Rear Headrest Right Rear Headrest Satellite Radio Tuner behind glove box ------------- Jeff Velocity Custom Home Theater Mobile Audio/Video Specialist Morden, Manitoba CANADA Posted By: superwhite06 Date Posted: November 20, 2011 at 4:51 PM thank you very much
