2010 mitsubishi outlander, f.a.s.t. key
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=129322
Printed Date: March 21, 2026 at 8:02 AM
Topic: 2010 mitsubishi outlander, f.a.s.t. key
Posted By: sharpie22
Subject: 2010 mitsubishi outlander, f.a.s.t. key
Date Posted: November 21, 2011 at 1:10 PM
Can someone please provide the correct wiring for a remote/alarm install. Also, any information on how to bypass the F.A.S.T. key would be much appreciated.
Thank you.
Posted By: ropuma
Date Posted: January 02, 2012 at 9:25 PM
 MODEL  YEAR(S)
 OUTLANDER  2007 -2011
 KEY  T-HARNESS  IMMOBILIZER
  N/A   N/A   MITSUBISHI'S TRANSPONDER SYSTEM, See NOTE #1
 PART   COLOR  LOCATION  DIAGRAM
 12 VOLT CONSTANT   WHITE (+)   @ FUSE BOX, (BLACK, 2-PIN PLUG), PIN 1
 STARTER  ORANGE (+)  @ IGNITION SWITCH, (WHITE, 6-PIN PLUG), PIN 5
 STARTER 2  N/A
 IGNITION 1  WHITE (+)  @ IGNITION SWITCH, (WHITE, 6-PIN PLUG), PIN 2
 IGNITION 2  N/A
 IGNITION 3  N/A
 ACCESSORY /HEATER BLOWER 1  LT. GREEN (+)  @ IGNITION SWITCH, (WHITE, 6-PIN PLUG), PIN 6
 ACCESSORY /HEATER BLOWER 2  N/A
 KEYSENSE  N/A
 PARKING LIGHTS ( - )  N/A
 PARKING LIGHTS ( + )  YELLOW(+)(Left) and BROWN(+)(Right) (Requires 775 Relay)  @ FUSE BOX, (WHITE, 20-PIN PLUG), PINS 10 and 13
 POWER LOCK  WHITE/ BLACK (TYPE B)  in DRIVERS KICK PANEL, (BROWN, 24-PIN PLUG), PIN 2
 POWER UNLOCK  RED / YELLOW (TYPE B)  in DRIVERS KICK PANEL, (BROWN, 24-PIN PLUG), PIN 3
 LOCK MOTOR WIRE  RED / GREEN or RED (5-Wire Type)  @ FUSE BOX, (WHITE, 19-PIN PLUG), PIN 6
 DOOR TRIGGER  YELLOW (-)  @ FUSE BOX, (BROWN, 16-PIN PLUG), PIN 16
 DOMELIGHT SUPERVISION  YELLOW (-)  @ FUSE BOX, (WHITE, 6-PIN PLUG), PIN 5
 TRUNK RELEASE  BROWN (-)(Use RELEASE Motor wire if not Present), NOTE #2  @ FUSE BOX, (BROWN, 16-PIN PLUG), PIN 14
 SLIDING POWER DOOR  N/A
 HORN  GREEN (-)  @ HORN SWITCH or FUSE BOX, (WHITE, 19-PIN PLUG), PIN 19
 TACH  Any wire NOT RED / WHITE(4-CYL) or BLUE(V6) (AC)  @ Any FUEL-INJECTOR
 WAIT TO START LIGHT  N/A
 BRAKE  RED / WHITE or RED (+)  @ BRAKE PEDAL SWITCH or in DRIVERS KICK PANEL, Harness to REAR of Vehicle
 FACTORY ALARM DISARM   DISARMS with FACTORY REMOTE ONLY!!
 ANTI-THEFT  MITSUBISHI'S TRANSPONDER SYSTEM, See NOTE #1  @ IGNITION SWITCH TUMBLER
NOTES
 NOTE #1: MITSUBISHI'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module,
Part # 791 Bypass Module (for REMOTE STARTING ONLY!) an Extra Ignition key is
required to be placed inside this module for Operation.
Part # XK09 Bypass Module, this Module is a KEYLESS BYPASS MODULE and DOES
NOT require a Key to be placed inside the Module for Operation, this module will also
do the Keyless Entry.
NOTE #2: TEST this wire while Opening the LIFTGATE from the Handle on the REAR of the
Vehicle.
 LINK 1  LINK TEXT 1  LINK 2  LINK TEXT 2
EXTRA INFORMATION
For bypass use" EVO CAN "  OR "EVO ALL" FROM FORTIN ELECTRONICS.
