viper 5901
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=129700
Printed Date: April 26, 2026 at 11:00 PM
Topic: viper 5901
Posted By: valentin1234
Subject: viper 5901
Date Posted: December 15, 2011 at 7:08 AM
need help connecting ignition 2 on a 99 f150 im using a viper 5901 do i use a relay to connect if so can i get a diagram
Date Posted: December 15, 2011 at 7:17 AM
could i connect the second ignition wire input to a constant power source and connect the second ignition output directly to the second ignition on the ford second ignition wire
Posted By: ceasar326
Date Posted: December 15, 2011 at 12:08 PM
Use the (-) pink wire from Remote start auxiliary output 5pin
with a relay connect the (-) pink wire from your 5901 to 86, then connect constant 12v to 30 and 85. then run 87 to you 2nd ing wire of your truck and that should do it.
Posted By: theghostman01
Date Posted: December 15, 2011 at 12:41 PM
Nice job ceasar !
ThE GhOsTmAn01
Date Posted: December 15, 2011 at 12:46 PM
No problem trying to help as much as i can.
Date Posted: December 16, 2011 at 8:31 AM
thks man
Date Posted: December 16, 2011 at 8:52 AM
ok so now if i have an acessory 2 will it hook up the same or that another way
Date Posted: December 16, 2011 at 8:55 AM
so if i have an acessory 2 will it hook up the same or that different way
Posted By: smokeman1
Date Posted: December 16, 2011 at 4:57 PM
What did you connect the H3/7 to?
