2002 Jeep Grand Cherokee Laredo
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=12972
Printed Date: May 16, 2026 at 1:12 AM
Topic: 2002 Jeep Grand Cherokee Laredo
Posted By: Joshuamr2
Subject: 2002 Jeep Grand Cherokee Laredo
Date Posted: April 30, 2003 at 10:04 AM
I need to know where can I hook up the wire from an alarm out-put  to activate the parking lights on a 2002 Jeep Grand Cherokee Laredo, the alarm has a (+) out-put for this function, will I be on a  need of a relay, a resistor or both please help me out :errr: Thank You.
Posted By: NowYaKnow
Date Posted: May 01, 2003 at 4:57 AM
You will need a relay and a resistor. The parking lights on that should be a yellow wire @ the steering column. There is a harness with all the power wires in it and another harness. It's not in with the power wires it's in the other one. I've seen info say 1300 ohm and others say 915 ohm. I did an 03 yesterday and hit it with around a 915 ohm and it worked fine. So hook the relay up as follows:
85 - + Output from your alarm module
86 - To Ground
30 - To Ground
87a - Not Used
87 - To yellow wire w/ resistor inline
Good luck.
Date Posted: May 01, 2003 at 1:08 PM
NowYaKnow  You are the Men posted_image thank's for the iformation I would hook it up like that,  thank's again.posted_image
Date Posted: May 02, 2003 at 11:32 AM
NowYaKnow  Question? posted_image will this set-up make the parking lights turn on only or will it make then flash because that's what I'm looking for Flashing Parking Lights when the alarm it's trigger on (siren full  blasth and flashing parking lights) Please let me know as soon as possible thank you.
Posted By: Velocity Motors
Date Posted: May 04, 2003 at 10:14 AM
The dk. blue/pink will flash the hazard lights.  They will flash even with a latch input to the wire.  The parking lights can be activated by using a 1300 ohm resistor to ground on the yellow headlight wire.
Use a 330 ohm resistor to ground for headlight activation.  Use 80 ohms to ground on the same wire to operate both the headlights and parking lights.
Date Posted: May 06, 2003 at 11:29 AM
Thank You  for the information I did the wire hook up yesterday and it work fine, I hook it up to the dk. blue/pink wire and I got flashing parking lights when the alarm it's trigger. See the problem that I had with this alarm (factory OEM Alarm)  was it didn't  had an out-put for this funtion (flashing parking lights) but it had a siren out-put a ( -) & (+) wire control by the alarm module, the (+) it's always hot on the siren so I hook it up to the  (-) wire using a relay coming from the siren so now when the alarm it's trigger not only the siren sound but it also has flashing parking lights. Thanks again for the information.posted_image
