2012 Ford Mustang Radio Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=131255
Printed Date: April 18, 2026 at 10:48 PM
Topic: 2012 Ford Mustang Radio Wiring
Posted By: myouell
Subject: 2012 Ford Mustang Radio Wiring
Date Posted: April 23, 2012 at 1:12 PM
I am trying to put subs and a amp in a 2012 mustan and cant find the wiring diagram cam anyone help
Posted By: tonanzith
Date Posted: April 26, 2012 at 11:45 AM
Radio 12V WHITE/ red + radio, gray 24 pin plug, pin 1
Radio Ground BLACK/ gray - radio, gray 24 pin plug, pin 13
Radio Ignition (MS CAN)
Radio Illumination (MS CAN)
Factory Amp Turn-on blue/green + radio, gray 24 pin plug, pin 7
The front subwoofer amp turn-on wire is PURPLE / red at the radio, gray 8 pin plug, pin 4. The rear subwoofer amp turn-on wire is gray/purple at the radio, gray 8 pin plug, pin 8.
Power Antenna YELLOW /GREEN + radio, gray 24 pin plug, pin 5
Left Front Speaker (+/-) white - WHITE/ brown or green - gray +,- radio, gray 24 pin plug, pins 8 and 21
If equipped, the amplifier is in the right side of the cargo compartment. On vehicles with amplifier, the speaker wires are white - WHITE/ brown at the amplifier, gray 14 pin plug, pins 13 and 6.
Right Front Speaker (+/-) WHITE/ purple - WHITE/ orange or purple - yellow +,- radio, gray 24 pin plug, pins 11 and 12
If equipped, the amplifier is in the right side of the cargo compartment. On vehicles with amplifier, the speaker wires are WHITE/ purple - WHITE/ orange at the amplifier, gray 14 pin plug, pins 11 and 4.
Left Rear Speaker (+/-) WHITE/ green - BROWN / yellow or GREEN/ brn - gray/brn +,- radio, gray 24 pin plug, pins 9 and 22
If equipped, the amplifier is in the right side of the cargo compartment. On vehicles with amplifier, the speaker wires are WHITE/ green - BROWN / yellow at the amplifier, gray 14 pin plug, pins 12 and 5.
Right Rear Speaker (+/-) BROWN / white - BROWN / blue or PURPLE / brn - yel/blue +,- radio, gray 24 pin plug, pins 10 and 23
If equipped, the amplifier is in the right side of the cargo compartment. On vehicles with amplifier, the speaker wires are BROWN / white - BROWN / blue at the amplifier, gray 14 pin plug, pins 10 and 3.
Center Channel (+/-) N/A
Subwoofer (+/-) pur/grn - grn/wht (F); brn/blue - wht/blue (R) +,- radio, gray 8 pin plug, pins 1 and 2; 5 and 6
Aux. Audio Input Left (+/-) blue - YELLOW /GREEN (without SYNC) +,- radio, gray 16 pin plug, pins 7 and 8
Aux. Audio Input Right (+/-) blue/green - WHITE/ green (without SYNC) +,- radio, gray 16 pin plug, pins 6 and 14
RSE Video (+/-) BROWN / purple - WHITE/ green (navigation video) +,- radio, gray 10 pin plug, pins 3 and 8
RSE Audio Left (+/-) blue - gray/orange (SYNC audio) +,- radio, gray 16 pin plug, pins 1 and 2
RSE Audio Right (+/-) PURPLE / green - BROWN / white (SYNC audio) +,- radio, gray 16 pin plug, pins 9 and 10
------------- Gary Sather
