96 4runner ignition diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=131292
Printed Date: April 18, 2026 at 8:32 AM
Topic: 96 4runner ignition diagram
Posted By: vasiq4
Subject: 96 4runner ignition diagram
Date Posted: April 27, 2012 at 12:04 PM
Hey guys,
I am trying to remove an aftermarket alarm system from my '96 4Runner SR5, but just can't understand the wiring setup. I am following an online "alarm removal manual" that provides a step-by-step description of removing the alarm. At one point it mentions "two large wires coming from the module that are the same color splice into the ignition wire". As far as I am concerned, all wires coming out of the module are the same size, and many wires are in fact the same color. I am totally confused. Also, for the life of me, I can't locate the ignition wire/wires. Follow the link so you guys can see what I am doing.
https://www.facebook.com/media/set/?set=a.3293349607527.138985.1081402733&type=3&l=78bbb0cbcf
------------- vasiq
Posted By: tommy...
Date Posted: April 27, 2012 at 4:41 PM
If it is JUST an aftermarket... Trace all the wires from the Brain to their connections, and dis-connect... Fix spot where attachment was made... Is the Loom the wires are in have any other wires in the Loom... If not, remove the Loom and trace the wires... How does the online manual know which unit you have installed in the 4runner...?
------------- M.E.C.P & First-Class
Posted By: tommy...
Date Posted: April 27, 2012 at 4:44 PM
1996 Toyota 4Runner DirectWire 2.0 Vehicle Information
Security
Item Wire Color Polarity Wire Location
12 Volts white - WHITE/ red + ignition harness
Starter black + ignition harness
Ignition BLACK / YELLOW + ignition harness
Data Bus
Can Bus High
Can Bus Low
Can Bus Sw
Power Lock RED / white - 10 pin plug, left of fusebox
Power Unlock RED / yellow - 10 pin plug, left of fusebox
Lock Motor
Driver Unlock Motor
Passenger Unlock Motor
Parking Lights (-) RED / white steering column
Parking Lights (+) green white plug, front of fusebox
Hazards
Turn Signal (Left)
Turn Signal (Right)
Headlight red or green - steering column
AutoLights
Left Front Door Trigger BLACK/ white - DKP, harness to rear
Right Front Door Trigger
Left Rear Door Trigger
Right Rear Door Trigger
Dome Supervision use door trigger
Trunk/Hatch Pin RED / white - DKP, harness to rear
Rear Glass Pin
Hood Pin
Trunk/Hatch Release
Trunk Release Motor
Fuel Door Release
Power Sliding Door (Left)
Power Sliding Door (Right)
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Trunk Alarm Shunt
Tachometer black ac ignitor or diag. plug
Ignitor is on passenger side fender well. Diagnostic connector is on drivers side top of motor.
Fuel Pump
Horn Trigger GREEN/ red - steering column
Memory Seat 1
Memory Seat 2
Posted By: howie ll
Date Posted: April 27, 2012 at 4:57 PM
Just remove the alarm "brain" and see if the vehicle starts. If so that's it, job done.
If it doesn't it's more like to be a starter than ignition cut, look for the black or BLACK / YELLOW and join.
This sort of job is about 5 minutes for me with multiple cuts, and I'm sure the same for Tommy.
Just drop the knee pad and if the ignition switch is in the steering column cowl remove for ignition loom access, what 6 screws all together?
Posted By: vasiq4
Date Posted: April 27, 2012 at 11:15 PM
Thank you so much for your reply. Well the problem is that there are way too many wires coming out of the alarm unit; online videos and manuals claim that the yellow wire goes to the ignition. Since the alarm system has blocked the vehicle from starting, I figured I should begin with the yellow wire. I can link pictures so you guys have a better idea what I am talking about. Also, you said to look for the black or BLACK / YELLOW wire and join. Join with what? Please provide a detailed explanation as I am not too car savvy.
------------- vasiq
Posted By: howie ll
Date Posted: April 28, 2012 at 2:10 AM
Look for the vehicle black or BLACK / YELLOW.
If the gauge lights come on and it doesn't turn over then the black has been cut, join the leads together..
If the starter turns over and it doesn't fire up, it's the BLACK / YELLOW for the same treatment.
From your line of questioning I would respectfully suggest you get a pro to sort this out, literally a 5-20 minute job, I do it all the time on vehicles of this vintage.
Posted By: tommy...
Date Posted: April 28, 2012 at 7:29 AM
I 2nd paying a shop to do it... This seems way over your head... Online manuals do not know what you have installed... Though, generically accurate... Look for your starter wire in the car and re-attach... then unplug brain and start vehicle... Otherwise... $68 at any shop...
Posted By: vasiq4
Date Posted: April 28, 2012 at 6:42 PM
Thank you so much guys. I simply took the module aka "brains" out and the truck started just fine. Thanks again, really appreciate it. The moderator can now go ahead and archive the thread.
------------- vasiq
Posted By: howie ll
Date Posted: April 28, 2012 at 6:43 PM
So you finally noticed my first post then?
Posted By: vasiq4
Date Posted: April 28, 2012 at 7:07 PM
hahaha kinda wanted to go with the manual that I got online. The plethora of wires essentially made me give up on the step by step procedure of the manual.
Thanks again.
------------- vasiq
