2010 Chevrolet Traverse Alarm/Remote Start Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=132529
Printed Date: April 30, 2026 at 12:59 AM
Topic: 2010 Chevrolet Traverse Alarm/Remote Start Wiring
Posted By: lurch228
Subject: 2010 Chevrolet Traverse Alarm/Remote Start Wiring
Date Posted: October 31, 2012 at 6:29 AM
Constant 12 volts RED\BLACK (50A) (x3) FUSE BOX BLACK 84 PIN CONN, PINS 5, 6, & 76
Ignition 12 volts PINK (+) IGNITION SWITCH
Starter YELLOW (NOT FOR REMOTE START) ECM UNDER HOOD BLACK 58 PIN CONN, PIN 57
Dome Light GRAY\BLACK (+) BCM WHITE CONN PIN 5*
Driver's Front Door Pin GRAY\BLACK (-) BCM PINK CONN PIN 10
Pass Front Door Pin TAN\WHITE (-) BCM PINK CONN PIN 8
Driver's Rear Door Pin LT BLUE\BLACK (-) BCM PINK CONN PIN 15
Pass Rear Door Pin LT GREEN\BLACK (-) BCM PINK CONN PIN 14
Trunk Pin PINK\BLACK (-) BCM PINK CONN PIN 12
OEM Hood Pin PINK\BLACK (-) BCM BLACK CONN PIN 17
Parking Lamp BROWN\WHITE (-) HEADLIGHT SWITCH
Lock PINK\BLACK (-) BCM GRAY CONN PIN 12** #201
Unlock ORANGE\BLACK (-) BCM GRAY CONN PIN 11 "FIRST PULSE DISARMS SECOND PULSE UNLOCKS"
IGNITION DATABUS WHITE (R CODE) WHITE\BLACK (5V REF) IGNITION SWITCH
DOORLOCK DATABUS DK GREEN (DATA) OBDII PIN 1
*BCM is under drivers dash left of column. **If these wires are not present use INTERFACE MODULE.
#201 Negative door lock diagram.
Tach Signal TAN ANY FUEL INJECTOR
Ignition #2 NA
Ignition #3 NA
Accessory BROWN IGNITION SWITCH
Accessory #2 SAME AS STARTER #2
Accessory #3 NA
Starter #2 USE INTERFACE MODULE
Neutral Safety NA
Brake Light LT BLUE (+) BCM BROWN CONN, PIN 5
Parking Brake ORANGE\BLACK (-) PARKING BRAKE SWITCH
Clutch Pedal NA
Reverse Light LT GREEN (+) BCM PINK CONN PIN 2
Rear Defrost WHITE (+ LATCHED) HVAC CONTROL MODULE BLUE 16 PIN CONN PIN 8 OR BLK 16 PIN CONN PIN 10*
*HVAC CONTROL MODULE is under radio.
Window Up D\ DK BLUE, P\ DK BLUE, D\ DK BLUE, P\ DK BLUE @ EACH SWITCH
Window Down D/ BROWN, P/ BROWN, D/ BROWN, P/ BROWN #211
Keysense SAME AS STARTER #2
Trunk Release GRAY (-) BCM PINK CONN PIN 23
OEM Horn TAN (-) HORN SWITCH
Headlights WHITE (-) HEADLIGHT SWITCH
OEM Alarm Arm ARMS ON LOCK WITH DOOR OPEN
OEM Alarm Disarm OEM REMOTE ONLY
Vehicle Speed Sense DK GREEN\WHITE RADIO BROWN 16 PIN CONN, PIN 5
#211 Reversal rest at ground window circuit.
OEM Keyless Module -
Motor Lock GRAY (5 WIRE) DRIVER KICK
Motor All Unlock TAN (5 WIRE) DRIVER REAR DOOR HARNESS
Motor Driver Unlock (disarm defeat) TAN (5 WIRE) DRIVER KICK
OEM Lock Relays -
Add On Security Type - TYPE 5 #225
Posted By: lurch228
Date Posted: November 03, 2012 at 1:25 AM
Hope someone is getting some use out of this.
