2012 Nissan Rogue Stereo Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=132677
Printed Date: April 19, 2026 at 8:42 AM
Topic: 2012 Nissan Rogue Stereo Wiring
Posted By: rdub2k4
Subject: 2012 Nissan Rogue Stereo Wiring
Date Posted: November 15, 2012 at 10:34 AM
Does anybody happen to have the wiring diagram for the Rogue's stereo, non-bose? I'll be installing an Avic D3 in my girlfriend's Rogue and trying to keep her factory back-up camera. All the posts I've found on the internet don't list any colors/diagrams.
Thanks a bunch guys.
Posted By: rdub2k4
Date Posted: November 15, 2012 at 11:21 AM
Well, I found this.. but that's about it.
Audio/Mobile Video
     WIRE COLOR POLARITY LOCATION
Battery YELLOW (+) RADIO HARNESS
Accessory LIGHT BLUE (+) RADIO HARNESS
Ground
RADIO IS GROUNDED THROUGH THE RADIO CHASSIS MOUNTING BRACKETS.
Power Antenna BLACK (+) RADIO HARNESS
LF Speaker (+) RED
LF Speaker (-) GREEN
RF Speaker (+) ORANGE
RF Speaker (-) WHITE
LR Speaker (+) YELLOW
LR Speaker (-) LIGHT GREEN
RR Speaker (+) BLUE
RR Speaker (-) PINK
Steering Cntrls YES
Speed Cntrl YES
Radio Security YES
No info on the back-up camera.
Posted By: rdub2k4
Date Posted: November 15, 2012 at 11:25 AM
No edit button yet...
Found this too. https://postimage.org/image/m8iwv3z5h/
Hmm, this will be interesting.
Posted By: howie ll
Date Posted: November 15, 2012 at 11:35 AM
Metra:-
Fascia/fitting kit 99-7613
Wiring harness 70-7552
Antenna adaptor 40-N112
Much easier than trying to work everything out, just plug and play.
Speed sense;
Either;
White 20 pin plug, rear of radio BLUE at pin 18.
Or rear of instrument panel, white 40 pin plug BLUE or YELLOW pins 30 and 31. Note you might not have the colours depending on spec which is why I gave you different locations.
Camera Input:
WHITE or GREEN with shield white 32 pin plug rear of radio, pins 1& 2.
Posted By: howie ll
Date Posted: November 15, 2012 at 11:38 AM
That link, the only wire you will need there is GREEN reverse.
Posted By: rdub2k4
Date Posted: November 16, 2012 at 8:39 AM
I found some more info online regarding the backup camera. It seems to apply to all Nissan's. They use a 6volt power source instead of a 12 volt, so a voltage converter is needed.
Tackling this install in the next few days once my dash kit and harness arrive. :) Thanks for your help!
