Relay Location 98 EZGO Cart
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=133012
Printed Date: May 02, 2026 at 5:07 AM
Topic: Relay Location 98 EZGO Cart
Posted By: jash12
Subject: Relay Location 98 EZGO Cart
Date Posted: December 18, 2012 at 12:39 PM
Looking for someone to look over my EZGO wiring diagram and tell me where I need to add relays and/or diodes.
Mainly looking at the Alarm system, Rocker Switch, Brake Switch and Ignition/Light Switch.
https://mflgolfcart.shutterfly.com/pictures/17
Thank you in advance.
Posted By: oldspark
Date Posted: December 18, 2012 at 5:44 PM
That looks like OEM wiring so it should be fine.
You'd only add a relay for the lights if that improves brightness.
And high-current switch life could be extended by using relays. IMO that's for switches carrying more than a few Amps, eg, headlights, ignition switch, and brake & reversing lights (else change to LEDs) etc.
Usually starter motors also use a relay but that detail is lacking from your diagram. (Plus it's a combined starter/generator.)
Posted By: howie ll
Date Posted: December 21, 2012 at 9:43 AM
WHY do you need to add relays and diodes?
