2001 buick century wiring harness
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=134955
Printed Date: March 25, 2026 at 1:03 PM
Topic: 2001 buick century wiring harness
Posted By: jr789
Subject: 2001 buick century wiring harness
Date Posted: September 27, 2013 at 11:33 PM
Hi ,
       Does anyone have a schematic or know which of the two bundles of wires under the column are used when wiring a remote ready starting system?? The reason im asking is because there are two bundles one with green tape and the other with red tape each has yellow wires(ie - presumably one is the starter wire)
My main concern is safety and not setting off an airbag.
Posted By: i am an idiot
Date Posted: September 28, 2013 at 1:39 AM
Do you not have access to a volt meter?
Posted By: jr789
Date Posted: September 28, 2013 at 9:32 AM
Yes thanks but im still concerned about grounding out an air bag wire.
Date Posted: September 28, 2013 at 7:38 PM
Using a digital meter will not affect an airbag. The purpose of the meter is to see which of the 2 yellow wires have 12 volts on it during start. If only one of them has 12 volts when the starter is turning, that is the wire you need to use.
Posted By: jr789
Date Posted: September 28, 2013 at 10:46 PM
Ok
      Thanks ill give it a try.
