2014 Ram 1500, 2500, 3500 Alarm/Remote Start Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=136335
Printed Date: April 12, 2026 at 5:24 PM
Topic: 2014 Ram 1500, 2500, 3500 Alarm/Remote Start Wiring
Posted By: flybyu
Subject: 2014 Ram 1500, 2500, 3500 Alarm/Remote Start Wiring
Date Posted: March 25, 2014 at 12:29 PM
I want to find the reverse wire color & location inside the vehicle for installation of GPS system we are installing in multiple vehicles. These are 2500's and 3500's. If you have the whole list of all the wire colors and locations that would be even better. Thanks
Posted By: wirewise
Date Posted: March 25, 2014 at 12:51 PM
RAM / 2500 / 2014 / Remote Start
12volts red (40A) + BCM under driver dash, black 4 pin plug (B), pin 3
Starter lt. blue/tan + BCM under driver dash, black 24 pin plug (A), pin 19
Second Starter PURPLE / brown Ignition Node/Keyless Ignition Node Module, blk 6 pin plg, pin 4
Ignition pink/white + BCM under driver dash, black 48 pin plug (E), pin 27
Second Ignition brown + BCM under driver dash, black 24 pin plug (A), pin 18
Third Ignition N/A
Accessory BROWN / orange + BCM under driver dash, black 48 pin plug (E), pin 36
Second Accessory N/A
Keysense N/A
Power Lock PURPLE / lt. green (passenger door switch) - 330 ohms Passenger Door Module, black 10 pin plug, pin 4
Power Unlock (same as power lock) - 100 ohms
Lock Motor lt. GREEN/ dk. blue 5 wire BCM under driver dash, white 48 pin plug (F), pin 2
Unlock Motor tan/lt. green 5 wire BCM under driver dash, white 48 pin plug (F), pin 1
Parking Lights+ WHITE/ brown (LF); WHITE/ orange (RF) + BCM, black 24 pin plug (A), pin 4; white 24 pin plug (D), pin 3
Notes: The LR - RR are WHITE/ gray - WHITE/ orange (+) at the BCM under driver dash, white 48 pin plug (F), pin 32; black 48 pin plug (E), pin 4.
Parking Lights- WHITE/ brown (need to relay isolate the switch) -1130 ohms BCM under driver dash, blue 24 pin plug (G), pin 20
Hazards WHITE/ dk. blue - BCM under driver dash, blue 24 pin plug (G), pin 21
Turn Signal(L) WHITE/ lt. green (F); white (R) + BCM, white 24 pin plug (D), pin 14; white 48 pin plug (F), pin 40
Turn Signal(R) WHITE/ tan (F); WHITE/ lt. green (R) + BCM, black 24 pin plug (A), pin 13; black 48 pin plug (E), pin 2
Reverse Light WHITE/ tan + BCM under driver dash, white 48 pin plug (F), pin 41
Door Trigger purple - BCM under driver dash, white 48 pin plug (F), pin 9
Dome Supervision yellow/purple + BCM under driver dash, blue 24 pin plug (G), pin 14
Trunk/Hatch Pin N/A
Hood Pin PURPLE / lt. blue - BCM under driver dash, black 24 pin plug (A), pin 11
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm (arms on lock with door open)
Factory Alarm Disarm (see disarm no unlock)
Disarm No Unlock (transponder and ignition)
Tachometer BROWN / stripe ac any fuel injector
Notes: On diesel models, use dk. blue/gray at the camshaft position sensor, 3 pin plug, pin 3.
Wait to start N/A
Brake Wire dk. GREEN / WHITE + BCM under driver dash, white 24 pin plug (D), pin 18
Parking Brake dk. GREEN / WHITE - BCM under driver dash, black 48 pin plug (E), pin 11
Horn Trigger dk. GREEN / WHITE + BCM under driver dash, black 24 pin plug (A), pin 23
Memory Seat 1 PURPLE / brown - resistor memory seat switch, black 4 pin plug, pin 3
Memory Seat 2 (same as memory seat 1) - resistor
Memory Seat 3 N/A - resistor
------------- ~wirewise~
Posted By: flybyu
Date Posted: March 25, 2014 at 3:17 PM
Awesome. Thanks. I really appreciate it
Posted By: michaelmrc
Date Posted: September 02, 2014 at 2:21 PM
i am working on a 2014 ram 2500 with hemi engine. i need to tap into the park lock indicator for a security system. whats the best way to access this. does someone have a wiring diagram or able to tell me which wire i can tap into for this. thanks
Posted By: lhcbec@hotmail.
Date Posted: September 28, 2015 at 3:09 PM
Does this work on the 2014 Ram 1500? If not, does anyone have this answer for a 2014 Ram 1500?
Posted By: wire_ninja
Date Posted: December 03, 2015 at 11:40 AM
Is this information similar to a 2014 Durango?
Posted By: alwayswet
Date Posted: June 20, 2018 at 5:41 PM
Doing a search for 2016 2500 brings me to your post, however it's located in 2014 2500 model forum..is the wiring the same, and is it same for diesels?
Thank you..
Bill
------------- Freedom Isn't Free, Never Forget 9/11
Posted By: wirewise
Date Posted: June 20, 2018 at 8:26 PM
RAM 1500-2500
MODEL YEAR(S
1500-2500 2013-2016
KEY T-HARNESS IMMOBILIZER
N/A N/A MULTIPLEX IGNITION/ANTI-THEFT SYSTEM, SEE NOTE #1
PART COLOR LOCATION DIAGRAM
12 VOLT CONSTANT RED (+) @ BCM, BLACK 4-PIN PLUG, PIN 3, SEE NOTE #2
STARTER CONNECTION MADE AT INTERFACE BYPASS MODULE
STARTER 2 N/A
IGNITION 1 CONNECTION MADE AT INTERFACE BYPASS MODULE
IGNITION 2 N/A
IGNITION 3 N/A
ACCESSORY/HEATER BLOWER 1
ACCESSORY/HEATER BLOWER 2 N/A
KEYSENSE N/A
PARKING LIGHTS ( - ) WHITE/DK.BLUE (-) USE HAZARD LIGHTS BCM under driver dash, blue 24 pin plug (G), pin 21
PARKING LIGHTS ( + ) N/A
POWER LOCK PURLE/LT. GREEN (-) THRU a 330 Ohm Resistor will LOCK Passenger Door Module, black 10 pin plug, pin 4
POWER UNLOCK SAME AS POWER LOCK (-) THRU a 100 Ohm Resistor will UNLOCK Passenger Door Module, black 10 pin plug, pin 4
LOCK MOTOR WIRE LT. GREEN /DK. BLUE (5 WIRE) BCM under driver dash, white 48 pin plug (F), pin 2
DOOR TRIGGER PURPLE (-) @ BCM, WHITE 48-PIN PLUG, PIN 9
DOMELIGHT SUPERVISION YELLOW/PURPLE (+) @ BCM, BLUE 24-PIN PLUG, PIN 14
TRUNK RELEASE N/A
SLIDING POWER DOOR N/A
HORN DARK GREEN/WHITE (+) @ BCM, BLACK 24-PIN PLUG, PIN 23
TACH BROWN/STRIPE (AC) ANY FUEL INJECTOR, On diesel models, use dk. blue/gray at the camshaft position sensor, 3 pin plug, pin 2.
WAIT TO START LIGHT N/A
BRAKE DARK GREEN/WHITE (+) @ BCM, WHITE 24-PIN PLUG, PIN 18
FACTORY ALARM DISARM MULTIPLEX IGNITION/ANTI-THEFT SYSTEM, SEE NOTE #1
ANTI-THEFT MULTIPLEX IGNITION + TRANSPONDER ANTI-THEFT SYSTEM, SEE NOTE #1 @ IGNITION BARREL
NOTES
NOTE#1: This vehicle is EQUIPPED with a MULTIPLEX IGNITION/ ANTI-THEFT SYSTEM that REQUIRES a INTERFACE BYPASS MODULE PART # DBALL2 for REMOTE STARTING, VEHICLES WITH SMART KEY AND PUSH TO START ALSO REQUIRE A DBALL2. The BCM is located under the DRIVERS SIDE of DASH.
Date Posted: June 20, 2018 at 8:39 PM
Thank you!
