toyata matrix wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=13918
Printed Date: May 15, 2026 at 11:32 PM
Topic: toyata matrix wiring
Posted By: zenderfin
Subject: toyata matrix wiring
Date Posted: May 24, 2003 at 3:58 AM
can anyone hook me up w/ a diagram for the toyota matrix? Thanx for the help.
Posted By: Velocity Motors
Date Posted: May 24, 2003 at 11:31 AM
|              12V|white & black       |+  |ignition harness            |
|          STARTER|red                 |+  |ignition harness            |
|         IGNITION|BLACK/ white         |+  |ignition harness            |
|  SECOND IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|        ACCESSORY|blue/red            |+  |ignition harness            |
|       POWER LOCK|green *1            |-  |passenger kick panel        |
|     POWER UNLOCK|blue/black *1       |-  |passenger kick panel        |
|       LOCK MOTOR|blue                |   |driver kick, door harness   |
|     UNLOCK MOTOR|red                 |   |driver kick, door harness   |
|    DISARM DEFEAT|red                 |   |driver kick, harness to rear|
| PARKING LIGHTS +|green               |   |driver kick panel           |
| PARKING LIGHTS -|GREEN / WHITE         |   |headlight switch            |
|       HEADLIGHTS|red                 |-  |headlight switch            |
|     DOOR TRIGGER|RED / yellow          |-  |driver kick panel           |
| DOME SUPERVISION|comes on with unlock|   |                            |
|  TRUNK/HATCH PIN|common with doors   |   |                            |
|TRNK/HTCH RELEASE|blue/white          |-  |release switch on dash      |
|  FCTRY ALARM ARM|arms with lock      |   |                            |
|FCTRY ALRM DISARM|disarms with unlock |   |                            |
| DISARM NO UNLOCK|blu/blk (key sense) |-  |ignition harness            |
|       TACHOMETER|black *2            |   |pin 5, conn. 4 @ PCM *3     |
|      SPEED SENSE|PURPLE / white        |   |pin 17, conn. 3 @ PCM *3    |
|       BRAKE WIRE|GREEN / WHITE         |+  |brake pedal switch          |
|     HORN TRIGGER|GREEN/ YELLOW        |-  |steering column             |
|           WIPERS|blu/wht(L),blu/red(H|+  |steering column             |
|  LF WINDOW UP/DN|yellow - green      |A  |driver window switch        |
|  RF WINDOW UP/DN|blk/red - blk/wht   |A  |driver kick, door harness   |
|  LR WINDOW UP/DN|RED / blu - blue      |A  |driver kick, door harness   |
|  RR WINDOW UP/DN|RED / blk - red       |A  |driver kick, door harness   |
| SUN RF OPN/CLOSE|green - red         |A  |sunroof switch assembly     |
|   SUN ROOF LIMIT|grn/wht or RED / blu  |-  |sunroof switch assembly     |
|        RADIO 12V|blue/white          |+  |radio harness               |
|     RADIO GROUND|brown               |-  |radio harness               |
|     RADIO SWITCH|gray                |+  |radio harness               |
| RADIO ILLUMINATE|green               |+  |radio harness               |
|    POWER ANTENNA|black               |+  |radio harness               |
|       LF SPEAKER|pink - purple       |   |radio harness or amplifier*4|
|       RF SPEAKER|lt. green - blue    |   |radio harness or amplifier*4|
|       LR SPEAKER|black - yellow      |   |radio harness or amplifier*4|
|       RR SPEAKER|red - white         |   |radio harness or amplifier*4|
Notes:
*1 These are the passenger key cylinder wires. Meter the wires while turning the key in the passenger door.  *2 Also can go to any one of the ignition coils under the black motor cover and use RED / blue, YELLOW /GREEN, gray, or white.  *3 The PCM (Powertrain Control Module) is behind the glove box.  *4 The amplifier is under the front passenger seat.
