Blazer install problems - Please help
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=14027
Printed Date: May 16, 2026 at 6:19 AM
Topic: Blazer install problems - Please help
Posted By: Sulsa
Subject: Blazer install problems - Please help
Date Posted: May 26, 2003 at 7:45 PM
I am trying to remove the bezel from my '95 Blazer. I have remove the two screws, but it seems the bezel gets hung up on the shifter knob and the hazard switch. I atempted to remove them by removing the steering column cover, but thus far I have been only been able to remove the bottom. Any suggestions what I need to do next?
Thanks,
Aaron
Posted By: Velocity Motors
Date Posted: May 26, 2003 at 7:55 PM
Check this list of removal processes and see if there is one close to your Blazer
Posted By: Sulsa
Date Posted: May 27, 2003 at 10:30 AM
I didn't see anything for my model year. Any other places to look?
Posted By: esmith69
Date Posted: May 28, 2003 at 11:10 AM
That hazard switch and shifter are a pain in the butt.  Hopefully you have the steering column that tilts?  If so, tilt it all that way down, and you might even need to put pressure on it because the spot where it will lock in to place is slightly higher than how far you can really push on it.
Just make sure you've removed all the screws--sometimes there's some on the bottom side of the trim as well, and the only way to get to them is to remove the underdash panel first.  Getting the top part to go over the hazard switch is the hardest part though.  It's okay to put pressure on it, sometimes you even have to bend it a lil bit.
I usually try to push down on the top part and pull out towards myself, and try to get that deep top section free first.  once you've gotten that it's just a matter of wiggling the bottom part out.  Also I usually end up putting the emergency brake on and shifting between park and 2nd depending on how far I've gotten the panel out.  usually i have to switch the shift lever a couple of times before I finally get the trim removed.
Ethan
Donate to the12volt.com
