2000 NISSAN SENTRA WIRING DIAGRAM
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=1403
Printed Date: May 14, 2026 at 10:11 AM
Topic: 2000 NISSAN SENTRA WIRING DIAGRAM
Posted By: SOUND PRESSURE
Subject: 2000 NISSAN SENTRA WIRING DIAGRAM
Date Posted: June 19, 2002 at 10:14 PM
HELLO ROOM,
IN NEED OF A WIRING DIAGRAM AS WELL AS ANY INFO ON WHAT TO LOOK OUT FOR. LIKE DOOR LOCK TYPE(RELAYS NEEDED OR NOT.) WILL BE INSTALLING A VIPER 550 ESP. (REMOTE START) IT HAS A FACTORY ALARM ALREADY. GUESSING KEYLESS, MOST COMMON. WILL ALSO BE INSTALLING TRUNK UNLOCK TO CHANNEL CHANNEL 4. ANY TIPS WOULD BE HELPFUL. THANKS.
Sound Pressure
Posted By: Velocity Motors
Date Posted: June 20, 2002 at 6:21 AM
Nissan
Sentra
2000-2001
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
BLACK/ WHITE & BLACK YELLOW
IGNITION SWITCH HARNESS *, **
Ignition  #1:
BLACK/ RED
Ignition #2:
WHITE
Ignition  #3:
N/A
Accessory:
WHITE/ BLUE
Brake  Light:
RED / GREEN
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
Parking Lights:
WHITE/ RED OR RED / BLUE (+)
HEADLIGHT SWITCH OR DRIVER'S KICK PANEL
Headlights:
OEM Alarm  Disarm:
WHITE/ BLUE (-)
PIN 30 AT SECURITY MODULE ***
OEM Alarm  Arm:
LT. GREEN/ RED (-)
PIN 41 AT SECURITY MODULE ***
Diesel  Glow Plug:
N/A
Clutch  Bypass Wire:
Notes:
 * This Vehicle Is Equipped With Two Start Wires. Both Must Be Powered In Order For Vehicle To Start When Engine Is Cold;  ** Some Models May Have A Transponder Type Of Anti-Theft System.
Nissan
Sentra
2000-2001
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
WHITE/ RED
Starter  Kill:
Ignition  +12 Volts:
BLACK/ RED
Dome  Lights/Superv:
RED / WHITE (-)
DRIVER'S KICK PANEL OR AT SECURITY MODULE ***
OEM Horn:
WHITE/ GREEN (-)
STEERING COLUMN HARNESS
Power  Lock:
GRAY (-)
SECURITY MODULE ***
Power  Unlock:
PURPLE / RED (-)
SECURITY MODULE ***
Trunk  Release:
RED (-)
AT TRUNK RELEASE SWITCH
Alarm  Input Wire:
RED / WHITE (-)
Notes:
*** The Security Module Is Located To The Right Of The Steering Column Underneath The Dash.
Date Posted: June 20, 2002 at 10:41 PM
HEY JEFF,
WHAT TYPE OF DOORLOCK SYSTEM IS THIS? RELAYS NEEDED? ANY INFO ON TACH WIRE FOR REMOTE START? WILL SPILTING THE WIRE FOR BOTH START WIRES BE FINE, MAKING A Y SPLITER? AND WILL THE DOMELIGHT SEE ALL DOORS OR IS THERE A NEED FOR DIODE ISOLATION? THANKS FOR ALL YOUR HELP JEFF. THAT LAST BIG HEADACHE THAT I HAD WITH MY BONNEVILLE WENT GREAT! ALL INFO YOU PROVIDED ME WITH WAS PERFECT TO THE TEE!posted_image
Sound Pressure
Date Posted: June 21, 2002 at 8:08 AM
  • This is a negative type A system. No relays or diodes.... just two wires to hook p and your done.
  • The tach signal must be taken from one of the injectors. Any one of these are good:
    • BLACK/ RED
    • GRAY/RED
    • BLUE/RED
    • PURPLE
    •  if you have a tachometer in the gauges you can use the BLUE / ORANGE
  • Yes, making a "Y " splitter for the starter is exactly what I would do.
  • I am assuming that the car has power door locks, so for the door trigger you need to use the
    • RED for  the drivers door at the time control module or SECU
    • RED / WHITE for the passenger door at the time control module or SECU
Good to hear that the information was good for the Bonneville. Good luck with the Nissan and please post your results.
Date Posted: June 21, 2002 at 10:47 PM
HEY JEFF,
THANKS FOR THE INFO AGAIN. I WILL BE POSTING THE RESULTS IN SEPTEMBER AS I WILL BE INSTALLING THIS INTO MY SISTERS CAR WHEN I GO ON VACATION OUT OF STATE.  I'M JUST GETTING ALL INFO TO BE READY AND MAKE SURE THAT I HAVE ALL THAT I NEED. IS IT DIFICULT TO HOOK UP THE SUNROOF TO OPEN AND CLOSE? OHH WOULD IT BE SAFER TO DIODE ISOLATE THE TWO WIRES FOR THE DOOR TRIGGER?
THANKS
Sound Pressure
Date Posted: June 21, 2002 at 11:36 PM
I would suggest using a window control module for the sunroof and for the doors, it wouldn't hurt to diode isolate the wires from each other. The worst thing would be that they would do nothing.
Date Posted: June 22, 2002 at 11:01 PM
HEY JEFF,
THANKS AGAIN FOR EVERYTHING! YOU'VE BEEN VERY HELPFUL.
THANKS
Sound Pressure
Date Posted: June 23, 2002 at 12:42 AM
Koo, not a problem.posted_image
