2014 Toyota Camry Non-Smart Key, Remote Start Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=140628
Printed Date: April 07, 2026 at 6:18 AM
Topic: 2014 Toyota Camry Non-Smart Key, Remote Start Wiring
Posted By: caraudioholic24
Subject: 2014 Toyota Camry Non-Smart Key, Remote Start Wiring
Date Posted: January 11, 2016 at 7:11 PM
Hi I need info on a 2012 Toyota Camry non smart key.
Thank you in advance
Posted By: ninja zx9
Date Posted: January 12, 2016 at 9:59 AM
12volts
green (30A)
ignition switch, white 8 pin plug, pin 5
Starter blue + ignition switch, white 8 pin plug, pin 7
Second Starter lt. green + ignition switch, white 8 pin plug, pin 3
Ignition black + ignition switch, white 8 pin plug, pin 6
Second Ignition pink + ignition switch, white 8 pin plug, pin 1
Third Ignition N/A
Accessory white + ignition switch, white 8 pin plug, pin 2
Second Accessory N/A
Keysense green - Body ECU on dash fuse box, white 30 pin plug, pin 17
Power Lock blue (passenger door switch) - Body ECU on dash fuse box, white 30 pin plug, pin 9
Power Unlock green (passenger door switch) - Body ECU on dash fuse box, white 30 pin plug, pin 10
Lock Motor red 5 wire driver kick, white 18 pin plug, pin 18
Unlock Motor gray 5 wire driver kick, white 18 pin plug, pin 12
Parking Lights+ pink + dash fuse box, white 36 pin plug (3C), pin 5
Parking Lights- black - Body ECU on dash fuse box, white 30 pin plug, pin 30
Hazards white - A/C control assembly, black 16 pin plug, pin 4
Turn Signal(L) yellow + dash fuse box, white 36 pin plug (3C), pin 22
Turn Signal(R) green + dash fuse box, white 36 pin plug (3C), pin 19
Reverse Light pink + dash fuse box, white 36 pin plug (3C), pin 7
Door Trigger blue - dash fuse box, white 36 pin plug (3C), pin 15
Dome Supervision lt. green - dash fuse box, rear, white 40 pin plug (3B), pin 35
Trunk/Hatch Pin white - dash fuse box, white 36 pin plug (3C), pin 9
Hood Pin purple - dash fuse box, white 40 pin plug (3D), pin 25
Trunk/Hatch Release (use trunk release motor)
Power Sliding Door N/A
Factory Alarm Arm red (driver door key lock) - Body ECU on dash fuse box, white 30 pin plug, pin 11
Factory Alarm Disarm gray (driver door key unlock) double - Body ECU on dash fuse box, white 30 pin plug, pin 24
Disarm No Unlock (use keysense)
Tachometer green ac data link connector, white 16 pin plug, pin 9
Wait to start N/A
Brake Wire red + brake switch, white 4 pin plug, pin 1
Parking Brake yellow - dash fuse box, white 40 pin plug (3D), pin 20
Horn Trigger lt. blue - dash fuse box, white 40 pin plug (3D), pin 15
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
MAKE : TOYOTA | MODEL : CAMRY | YEAR : 2014
* The logo is registered trade mark of Toyota Corporate.
Date Posted: January 12, 2016 at 11:27 AM
Thank You..
I assume the car has a chipped key.. a key bypass like the 5556u should work?
Posted By: howie ll
Date Posted: January 12, 2016 at 11:40 AM
Yes.
Date Posted: January 12, 2016 at 12:20 PM
Thank you
