wiring diagram for a remote start, 2014 Kia Rio5
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=140888
Printed Date: April 08, 2026 at 12:54 PM
Topic: wiring diagram for a remote start, 2014 Kia Rio5
Posted By: quiggy
Subject: wiring diagram for a remote start, 2014 Kia Rio5
Date Posted: February 21, 2016 at 7:32 PM
I'm looking for a wiring diagram for a remote start on a 2014 Kia Rio5.
Thanks for any help,
Posted By: wirewise
Date Posted: February 21, 2016 at 7:50 PM
KIA / RIO (SMART KEY) / 2014 / Remote Start
12volts pink (40A) + right of dash fuse box, white 41 pin plug, pin 11
Starter white + Smart Key Module left of steering column, white 26 pin plug, pin 17
Second Starter pink (SS1); gray/black (SS2) - Smart Key Module left of steering column, wht 26 pin plg, pins 25, 8
Ignition white + Smart Key Module left of steering column, white 26 pin plug, pin 5
Second Ignition N/A
Third Ignition N/A
Accessory blue + Smart Key Module left of steering column, white 26 pin plug, pin 18
Second Accessory yellow + Smart Key Module left of steering column, white 26 pin plug, pin 19
Keysense N/A
Power Lock pink - BCM right of steering column, white 16 pin plug, pin 6
Power Unlock red (all doors); BLACK/ orange (driver door only) - BCM right of strng column, wht 16 pin plg, pin5; wh 22 pin plg, pin20
Lock Motor green 5 wire dash fuse box, white 42 pin plug (F), pin 21
Unlock Motor brown 5 wire dash fuse box, white 42 pin plug (F), pin 40
Parking Lights+ GREEN/ black (L); yellow/black (R) + dash fuse box, white 42 pin plug (F), pins 35, 34
Parking Lights- pink/black - BCM right of steering column, white 26 pin plug, pin 7
Hazards green - BCM right of steering column, white 16 pin plug, pin 4
Turn Signal(L) green (F); green (R) + dash FB, wh 54 pin plg (E), pin 41; driver kick, wht 39 pin plug, pin 7
Turn Signal(R) blue (F); green (R) + dash FB, wh 54 pin plg (E), pin 40; pass kick, wht 39 pin plug, pin 36
Reverse Light green + BCM right of steering column, white 26 pin plug, pin 16
Door Trigger green - BCM right of steering column, white 26 pin plug, pin 23
Dome Supervision blue - BCM right of steering column, white 22 pin plug, pin 3
Trunk/Hatch Pin BROWN / orange - BCM right of steering column, white 26 pin plug, pin 26
Hood Pin yellow - BCM right of steering column, white 26 pin plug, pin 19
Trunk/Hatch Release blue (on hatchback models this wire only unlocks) - BCM right of steering column, white 22 pin plug, pin 21
Power Sliding Door N/A
Factory Alarm Arm pink (key lock); blue/blk (detect) (Tech Doc 1300) - and open BCM right of steering column, white 26 pin plug, pins 6, 20
Factory Alarm Disarm brn/org (key unlck); bu/bk (detect)(Tech Doc 1300) both - BCM right of steering column, white 26 pin plug, pins 5, 20
Disarm No Unlock (see factory alarm disarm)
Tachometer gray ac Smart Key Module left of steering column, white 26 pin plug, pin 23
Wait to start N/A
Brake Wire green + Smart Key Module left of steering column, white 16 pin plug, pin 5
Parking Brake green - BCM right of steering column, white 12 pin plug, pin 3
Horn Trigger blue - right of dash fuse box, white 41 pin plug, pin 26
KIA / RIO / 2014 / Remote Start
12volts pink (40A) + ignition switch, black 6 pin plug, pin 1
Starter white + ignition switch, black 6 pin plug, pin 3
Second Starter N/A
Ignition pink + ignition switch, black 6 pin plug, pin 4
Second Ignition N/A
Third Ignition N/A
Accessory red + ignition switch, black 6 pin plug, pin 2
Second Accessory green + ignition switch, black 6 pin plug, pin 6
Keysense white + key switch, white 6 pin plug, pin 3
Tachometer green ac camshaft position sensor, engine driver side, black 3 pin plug, pin 2
Wait to start N/A
Brake Wire green + left of dash fuse box, blue 20 pin plug, pin 16
------------- ~wirewise~
Posted By: quiggy
Date Posted: February 21, 2016 at 10:14 PM
thanks is this for the hatch back Rio and is smart key the push start model
