99 Jeep Grand Cherokee avital 5303LX/DBall2
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=142483
Printed Date: May 16, 2026 at 8:48 AM
Topic: 99 Jeep Grand Cherokee avital 5303LX/DBall2
Posted By: patrickbjeep
Subject: 99 Jeep Grand Cherokee avital 5303LX/DBall2
Date Posted: January 24, 2017 at 1:27 PM
So I purchased am Avital 5303LX and DBall2 for my 99 Jeep Grand Cherokee. I plan to do the D2D install. I do not have the wiring diagram for the 5303LX but I do have the wiring diagram for the Avital 4103LX. So I compared the two installation manuals and came up with wiring:
DBALL H10/9 TO (Pink) Avital Ribbon 2 (Yellow): (+) IGNITION INPUT TO ALARM
DBALL H14/2 TO (Violet / YELLOW) Jeep OBDII Pin 2
DBALL H14/9 TO (Orange / YELLOW) Jeep Immobilizer Pin 3 (Dark Blue/White): Immobilizer Side
DBALL H14/8 TO (Yellow) Jeep Immobilizer Pin 3 (Dark Blue/White) – Car Side
DBALL H12/9 & 8 (Violet/Green, Violet/Brown) TO Jeep Headlight Switch Pin 11 (Yellow)
Avital H/6 (Red): (+) 30A HIGH CURRENT 12V INPUT TO Jeep Ignition Switch (Red)
Avital H/8 (RED / White): (+) 30A HIGH CURRENT 12V INPUT TO Jeep Ignition Switch (Red)
Avital H/5 (Pink): OUTPUT TO PRIMARY IGNITION CIRCUIT TO Jeep Ignition Switch (Dark Blue)
Avital H/1 (Purple): STARTER OUTPUT TO STARTER (STARTER SIDE) TO Jeep Ignition Switch (Yellow)
Avital H/4 (Orange): OUTPUT TO ACCESSORY CIRCUIT TO Jeep Ignition Switch (RED / Black)
Avital H/7 (Pink/White): OUTPUT TO SECOND IGNITION CIRCUIT TO Jeep Ignition Switch (BLACK/ Orange
Avital H3/1 (BLACK/ White): (-) NEUTRAL SAFETY SWITCH INPUT TO Ground
Avital H1/5 (Black): GROUND TO Ground
Avital H1/11 Light Flash Output (White): (+)/(-) SELECTABLE LIGHT FLASH OUTPUT TO DBALL H10/7 Parking Lights Input (Pink/White)
Avital Door Lock 1 Unlock (Light Blue): (-) TO DBALL H10/2 Unlock Input (Blue)
Avital Door Lock 3 Lock (Green): (-) TO DBALL H10/1 Lock Input (Green)
Avital Ribbon Harness 7 Status Output (Blue): (-) 200mA STATUS OUTPUT TO DBALL H10/10 GRW (Status) Input (Blue/White)
Avital Ribbon Harness 5 Starter Output(Purple): (-) 200mA STARTER RELAY TURN ON TO DBALL H10/8 Starter Input (Violet)
Avital H3/2 Tach Input (Violet/White): TACHOMETER INPUT WIRE TO DBALL H12/5 Tach Output (Violet/White)
Avital H3/4 Hood Pin Switch Shutdown (Gray): (-) HOOD PIN SWITCH SHUTDOWN WIRE TO Jeep Hood Pin Switch
DBALL H14/13 12v (Red) Jeep Ignition Switch (Red) TO DBALL H14/14 Ground (Black) Ground
The underlined connections are the ones that did not directly relate when comparing the wiring diagrams/instillation manuals.
Am I missing anything obvious? Does anyone have the wiring guide for a 99 jeep grand cherokee for Avital 5303LX/DBall2? Thanks.
