Speaker Wiring for 2017 Ford F150 Non-Sony
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=143911
Printed Date: April 17, 2026 at 12:14 PM
Topic: Speaker Wiring for 2017 Ford F150 Non-Sony
Posted By: flagshippy
Subject: Speaker Wiring for 2017 Ford F150 Non-Sony
Date Posted: December 19, 2017 at 2:43 PM
HI All, I have a 2017 Ford F150 Lariat with sync 3 and NON_SONY. I'm adding an alpine v90 amp and and a PAC4 (behind head unit to convert speaker wire signal to RCAs for the AMP. I'm in DESPERATE need of a wiring diagram of wire color identifications of the sync3 system so I can identify the speaker wires, ground, power, and remote to attach to the PAC4. I've searched high and low and can not find anything on the 2017 (or 2016 even). I have my interior ripped apart now and really need to get this right. My local installation guys won't share even though I bought $2G worth of stuff from them to do this project.
------------- Flag shippy
Date Posted: December 19, 2017 at 2:47 PM
I've seen some "DirectWire" Wiring information for 2010, and 2011 Ford F150 on this site, but they are pretty old and of a time before Sync, let alone Sync 3, so they don't work. I've also seen some posts in the F150 forums that show speaker wire only on some 2015, but not of the power, ground, remote etc from the Sync 3 system. I understand that Ford can change the wire colors every year, so I'm hesitant to believe the 2016 wiring anyway.
Posted By: geepherder
Date Posted: December 19, 2017 at 5:26 PM
https://www.revbase.com/BBBMotor/Wd/DownloadPdf?id=1166939
------------- My ex once told me I have a perfect face for radio.
Date Posted: December 19, 2017 at 6:12 PM
Thank you! Exactly what I needed!
Posted By: mraburke64
Date Posted: December 26, 2017 at 2:50 AM
Hi this might help me but it is over my head. I can most likely locate such, but what i am not getting is which wire in the diagram would I use to get power for amp that is switched on a 2017 Ford F150 4x4 supercrew with 5.0 ? And does anyone know if there is an accessible wire loom of which I can access without pulling stereo? Or should I just bite the bullet and pull unit?? Thanks.
------------- AB
Date Posted: December 26, 2017 at 12:16 PM
check violet/green at the ignition harness (accessory)
