| Print Page | Close Window |
Alarm Wiring, 2015 Toyota PriusPrinted From: the12volt.comForum Name: Vehicle Wiring Information & File Requests Forum Discription: Request Car Alarm, Car Stereo, Cruise Control, Remote Starter, Navigation, Mobile Video, and Other Vehicle Specific Wiring Info, Manuals, Tech Tips URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=144302 Printed Date: May 12, 2026 at 4:05 AM Topic: Alarm Wiring, 2015 Toyota Prius Posted By: jhl605 Subject: Alarm Wiring, 2015 Toyota Prius Date Posted: April 10, 2018 at 12:57 PM I have a 2015 Toyota Prius PTS. I'm wanting to install the viper 5706v and would like wiring information for my car. I looked already in your database but did not find my vehicle.
Thank you James Lanier Replies: Posted By: wirewise Date Posted: April 10, 2018 at 1:12 PM Here is the Prius and Prius C (further down).
PRIUS 2010-2015 KEY T-HARNESS IMMOBILIZER N/A N/A TOYOTA'S PROXIMITY (Smart Key) ANTI-THEFT SYSTEM, See NOTE #1 PART COLOR LOCATION DIAGRAM 12 VOLT CONSTANT WHITE (+) @ DASH FUSE BOX, (WHITE 1-Pin Plug(E) Pin 1 STARTER NOT USED FOR REMOTE STARTING! STARTER 2 N/A IGNITION 1 NOT USED FOR REMOTE STARTING! IGNITION 2 N/A IGNITION 3 N/A ACCESSORY/HEATER BLOWER 1 NOT USED FOR REMOTE STARTING! ACCESSORY/HEATER BLOWER 2 N/A KEYSENSE N/A PARKING LIGHTS ( - ) YELLOW (-) @ BODY ECU, (WHITE, 30-Pin Plug) Pin 30, NOTE #6 PARKING LIGHTS ( + ) BROWN (+) @ DASH FUSE BOX, (WHITE 36-Pin Plug(D) Pin 18 POWER LOCK LT. GREEN (TYPE B), (TEST with Passenger Switch) NOTE #2 @ BODY ECU, (WHITE, 30-Pin Plug) Pin 9, NOTE #6 POWER UNLOCK BROWN (TYPE B), (TEST with Passenger Switch) NOTE #3 @ BODY ECU, (WHITE, 30-Pin Plug) Pin 10, NOTE #6 LOCK MOTOR WIRE RED to BLUE (5-wire type) in DRIVERS KICK PANEL, (WHITE, 26-Pin Plug) Pin 1 DOOR TRIGGER PURPLE (-) @ DASH FUSE BOX, (WHITE 36-Pin Plug(D) Pin 35 DOMELIGHT SUPERVISION BLUE (-) @ DASH FUSE BOX, (REAR, WHITE 56-Pin Plug(A) Pin 52 TRUNK RELEASE GRAY (-), NOTE #4 in DRIVERS KICK PANEL, (WHITE, 64-Pin Plug) Pin 46 SLIDING POWER DOOR N/A HORN LT. BLUE (-) @ DASH FUSE BOX, (WHITE 40-Pin Plug(C) Pin 24 TACH N/A WAIT TO START LIGHT N/A BRAKE BLUE (+) @ BRAKE SWITCH or in DRIVERS KICK PANEL, (WHITE, 10-Pin Plug) Pin 5 FACTORY ALARM DISARM PURPLE (-) NOTE #5 @ BODY ECU, (WHITE, 30-Pin Plug) Pin 24, NOTE #6 ANTI-THEFT TOYOTA'S PROXIMITY (Smart Key) ANTI-THEFT SYSTEM NOTES NOTE #1: This Vehicle is Equipped with TOYOTA'S PROXIMITY (Smart Key) ANTI-THEFT SYSTEM SYSTEM that requires a INTERFACE BYPASS MODULE for REMOTE STARTING, Part # DBALL2 NOTE #2: this wire is only needed if the Door Locks do not function with the Aftermarket System while the vehicle is running. All other times just use the Factory Alarm Arm wire. NOTE #3: this wire is only needed if the Door Locks do not function with the Aftermarket System while the vehicle is running. All other times just use the Factory Alarm Disarm wire. NOTE #4: TEST this wire while opening the Hatch with the Handle on the Rear of the Vehicle. NOTE #5: TEST this wire while turning the Key in the Drivers Door, this wire will also Unlock the Doors with a double pulse.. NOTE #6: the BODY ECU is located under the Drivers Dash and is attached to the Right side of the Dash Fuse Box. ============================== PRIUS C 2012-2016 KEY T-HARNESS IMMOBILIZER N/A N/A TOYOTA'S TRANSPONDER SYSTEM, Requires Bypass Module and spare key, VEHICLES WITH SMART KEY AND PUSH TO START REQUIRE A DBALL2 INTERFACE PART COLOR LOCATION DIAGRAM 12 VOLT CONSTANT BLACK (+) dash fuse box, white 1 pin plug (3E), pin 1 STARTER GREEN (+) ignition switch, white 8 pin plug, pin 7 STARTER 2 N/A IGNITION 1 PINK (+) ignition switch, white 8 pin plug, pin 6 IGNITION 2 LT. BLUE (+) ignition switch, white 8 pin plug, pin 1 IGNITION 3 N/A ACCESSORY/HEATER BLOWER 1 BLUE (+) ignition switch, white 8 pin plug, pin 2 ACCESSORY/HEATER BLOWER 2 N/A KEYSENSE PURPLE (-) Body ECU on dash fuse box, white 30 pin plug, pin 17 PARKING LIGHTS ( - ) LT. BLUE (-) Body ECU on dash fuse box, white 30 pin plug, pin 30 PARKING LIGHTS ( + ) GREEN (+) dash fuse box, white 36 pin plug (3D), pin 10 POWER LOCK BLUE (-) Body ECU on dash fuse box, white 30 pin plug, pin 9 POWER UNLOCK WHITE (-) Body ECU on dash fuse box, white 30 pin plug, pin 10 LOCK MOTOR WIRE YELLOW (5-WIRE) driver kick, white 20 pin plug, pin 7 DOOR TRIGGER RED (-) dash fuse box, white 36 pin plug (3D), pin 36 DOMELIGHT SUPERVISION BLACK (-) dash fuse box, rear, white 40 pin plug (3B), pin 6 TRUNK RELEASE GREEN (-) driver kick, white 20 pin plug, pin 16 SLIDING POWER DOOR N/A HORN LT. GREEN (-) dash fuse box, white 40 pin plug (3C), pin 19 TACH LT. GREEN (AC) data link connector, white 16 pin plug, pin 9 WAIT TO START LIGHT N/A BRAKE BLUE (+) dash fuse box, white 36 pin plug (3D), pin 19 FACTORY ALARM DISARM GREEN (-) TEST BY TURNING KEY IN DRIVER'S DOOR Body ECU on dash fuse box, white 30 pin plug, pin 24 ANTI-THEFT TOYOTA'S TRANSPONDER SYSTEM, Requires Bypass Module, VEHICLES WITH SMART KEY AND PUSH TO START REQUIRE A DBALL2 INTERFACE ------------- ~wirewise~ Verify all wiring with your meter before making any connections! Posted By: qpham504 Date Posted: November 29, 2020 at 9:27 AM Hi, Sorry to bump and old thread and hopefully the mod is around to answer but what do you mean by "NOT USED FOR REMOTE STARTING!"
Posted By: i am an idiot Date Posted: November 29, 2020 at 3:08 PM Following info is from Directechs for the 2015 Prius Smart Key.
12 Volts white (125A) + dash fuse box, white 1 pin plug (2E), pin 1 Second 12 Volts white (125A) + dash fuse box, white 1 pin plug (2E), pin 1 Ground (chassis ground) Ignition red + dash fuse box, white 40 pin plug (2C), pin 2 Second Ignition black + dash fuse box, rear, white 40 pin plug (2B), pin 25 Accessory green + dash fuse box, rear, white 56 pin plug (2A), pin 43 PTS 1 black - power start stop switch, black 14 pin plug, pin 7 PTS 2 yellow - power start stop switch, black 14 pin plug, pin 2 CAN Bus High white data OBD-Data Link Connector, white 16 pin plug, pin 6 CAN Bus Low yellow data OBD-Data Link Connector, white 16 pin plug, pin 14 OBD 12 Volts red (7.5A) + OBD-Data Link Connector, white 16 pin plug, pin 16 OBD Ground green - OBD-Data Link Connector, white 16 pin plug, pin 4 RX DATA violet (BRX) data Body ECU on dash fuse box, white 30 pin plug, pin 4 TX DATA green (BTX) data Body ECU on dash fuse box, white 30 pin plug, pin 16 IMMO Data blue (IMO) data Power Management ECU behind glove box, gray 31 pin plug, pin 20 IMMO Data 2 red (IMI) data Power Management ECU behind glove box, gray 31 pin plug, pin 21 Security Light black + Certification ECU behind glove box, white 36 pin plug, pin 2 Power Lock lt. green (passenger door switch) - Body ECU on dash fuse box, white 30 pin plug, pin 9 Power Unlock brown (passenger door switch) - Body ECU on dash fuse box, white 30 pin plug, pin 10 Lock Motor red 5 wire driver kick, white 26 pin plug, pin 1 Driver Unlock Motor black 5 wire driver kick, white 26 pin plug, pin 15 Passenger Unlock Motor violet 5 wire dash fuse box, white 36 pin plug (2D), pin 11 Factory Alarm Arm green (driver door key lock) - Body ECU on dash fuse box, white 30 pin plug, pin 11 Factory Alarm Disarm violet (driver door key unlock) double - Body ECU on dash fuse box, white 30 pin plug, pin 24 Disarm No Unlock (proximity key and push-button) Parking Lights brown + dash fuse box, white 36 pin plug (2D), pin 18 Parking Lights - yellow - Body ECU on dash fuse box, white 30 pin plug, pin 30 Directwire Hazards yellow - Body ECU on dash fuse box, white 30 pin plug, pin 3 Turn Signal (Left) yellow + dash fuse box, white 36 pin plug (2D), pin 17 Turn Signal (Right) green + dash fuse box, white 36 pin plug (2D), pin 4 Headlight blue - Body ECU on dash fuse box, white 30 pin plug, pin 29 Directwire AutoLights white cut Body ECU on dash fuse box, white 30 pin plug, pin 28 Directwire Reverse Light red + driver kick, white 64 pin plug, pin 29 Left Front Door Trigger violet - dash fuse box, white 36 pin plug (2D), pin 35 Right Front Door Trigger brown - dash fuse box, white 36 pin plug (2D), pin 36 Left Rear Door Trigger green - Body ECU on dash fuse box, white 30 pin plug, pin 6 Right Rear Door Trigger (same as left rear door trigger) Dome Light blue - dash fuse box, rear, white 56 pin plug (2A), pin 52 Trunk/Hatch Pin blue - Body ECU on dash fuse box, white 30 pin plug, pin 19 Trunk/Hatch Release gray (rear handle switch) - driver kick, white 64 pin plug, pin 46 Trunk Release Motor yellow 5 wire dash fuse box, white 36 pin plug (2D), pin 9 Fuel Door Release lt. green (Plug-in Hybrid) - fuel lid opener switch, black 5 pin plug, pin 4 Tachometer (program engine checking off) Fuel Pump red + driver kick, white 10 pin plug, pin 8 Rear Defroster yellow - A/C Amplifier under front of center console, white 40 pin plug, pin 20 Mirror Defroster (same as rear defroster) Left Front Heated Seat beige (except Plug-in Hybrid) + seat heater switch, black 8 pin plug, pin 3 Notes Right Front Heated Seat gray (except Plug-in Hybrid) + seat heater switch, black 8 pin plug, pin 6 Notes Speed Sense violet ac radio, white 28 pin plug, pin 17 or white 20 pin plug, pin 3 Brake Wire blue + brake switch or driver kick, white 10 pin plug, pin 5 Parking Brake red - dash fuse box, white 40 pin plug (2C), pin 20 Horn Trigger lt. blue - dash fuse box, white 40 pin plug (2C), pin 24 Wipers red (LO); white (HI); brown (ignition) + wiper switch, white 10 pin plug, pins 3, 4, 2 Left Front Window (Up/Down) (motor is part of module) Right Front Window (Up/Down) (motor is part of module) Left Rear Window (Up/Down) (motor is part of module) Right Rear Window (Up/Down) (motor is part of module) Sun Roof (Open/Close) lt. blue - brown (function with ignition on only) - driver kick, white 64 pin plug, pins 51 - 52 Posted By: qpham504 Date Posted: November 29, 2020 at 4:57 PM Wow! Thanks! I'll check them against the 2012 prius IV.
Posted By: i am an idiot Date Posted: November 29, 2020 at 7:31 PM They do not have a listing for an IV, they do have this for the 2012 Prius V
12 Volts green (30A) + dash fuse box, white 36 pin plug (2D), pin 13 Second 12 Volts white (125A) + dash fuse box, white 1 pin plug (2E), pin 1 Ground (chassis ground) Ignition red + dash fuse box, white 40 pin plug (2C), pin 2 Second Ignition black + dash fuse box, rear, white 40 pin plug (2B), pin 25 Accessory green + dash fuse box, rear, white 56 pin plug (2A), pin 43 PTS 1 black - power start stop switch, gray 14 pin plug, pin 7 PTS 2 yellow - power start stop switch, gray 14 pin plug, pin 2 CAN Bus High black data OBD-Data Link Connector, white 16 pin plug, pin 6 CAN Bus Low white data OBD-Data Link Connector, white 16 pin plug, pin 14 OBD 12 Volts lt. blue (7.5A) + OBD-Data Link Connector, white 16 pin plug, pin 16 OBD Ground green - OBD-Data Link Connector, white 16 pin plug, pin 4 RX DATA violet (BRX) data Body ECU on dash fuse box, white 30 pin plug, pin 4 TX DATA green (BTX) data Body ECU on dash fuse box, white 30 pin plug, pin 16 IMMO Data lt. blue (IMO) data Power Management ECU behind glove box, gray 31 pin plug, pin 20 IMMO Data 2 lt. green (IMI) data Power Management ECU behind glove box, gray 31 pin plug, pin 21 Security Light gray + Certification ECU behind glove box, white 36 pin plug, pin 2 Power Lock pink (passenger switch) - Body ECU on dash fuse box, white 30 pin plug, pin 9 Directwire Power Unlock lt. blue (passenger switch) - Body ECU on dash fuse box, white 30 pin plug, pin 10 Directwire Lock Motor red reverse driver kick, white 12 pin plug, pin 7 Driver Unlock Motor black reverse driver kick, white 12 pin plug, pin 1 Passenger Unlock Motor violet reverse dash fuse box, white 36 pin plug (2D), pin 11 Factory Alarm Arm green (key lock) - Body ECU on dash fuse box, white 30 pin plug, pin 11 Directwire Factory Alarm Disarm violet (key unlock) double - Body ECU on dash fuse box, white 30 pin plug, pin 24 Directwire Disarm No Unlock (proximity key and push button) Parking Lights green + dash fuse box, white 36 pin plug (2D), pin 18 Parking Lights - yellow - Body ECU on dash fuse box, white 30 pin plug, pin 30 Directwire Hazards gray - hazard switch, black 8 pin plug, pin 3 Turn Signal (Left) yellow + dash fuse box, white 36 pin plug (2D), pin 17 Turn Signal (Right) lt. blue + dash fuse box, white 36 pin plug (2D), pin 4 Headlight pink - Body ECU on dash fuse box, white 30 pin plug, pin 29 Directwire AutoLights green cut Body ECU on dash fuse box, white 30 pin plug, pin 28 Directwire Reverse Light red + driver kick, white 76 pin plug, pin 5 Left Front Door Trigger yellow - dash fuse box, white 36 pin plug (2D), pin 35 Right Front Door Trigger brown - dash fuse box, white 36 pin plug (2D), pin 36 Left Rear Door Trigger green - Body ECU on dash fuse box, white 30 pin plug, pin 6 Directwire Right Rear Door Trigger (same as left rear door trigger) Dome Light pink - dash fuse box, rear, white 56 pin plug (2A), pin 52 Trunk/Hatch Pin blue - Body ECU on dash fuse box, white 30 pin plug, pin 19 Directwire Trunk/Hatch Release gray (rear handle switch) - driver kick, white 76 pin plug, pin 4 Trunk Release Motor yellow reverse dash fuse box, white 36 pin plug (2D), pin 9 Tachometer (program engine checking off) Fuel Pump red + driver kick, white 10 pin plug, pin 8 Rear Defroster lt. blue - A/C Amplifier under front of center console, white 40 pin plug, pin 20 Mirror Defroster (same as rear defroster) Left Front Heated Seat tan + seat heater switch, black 8 pin plug, pin 3 Right Front Heated Seat gray + seat heater switch, black 8 pin plug, pin 6 Speed Sense blue ac radio, white 28 pin plug, pin 17 Brake Wire blue + brake switch --or-- driver kick, white 10 pin plug, pin 5 Parking Brake red - dash fuse box, white 40 pin plug (2C), pin 20 Horn Trigger lt. blue - dash fuse box, white 40 pin plug (2C), pin 24 Wipers red (LO); white (HI); black (ignition) + wiper switch, white 10 pin plug, pin 3 (LO); pin 4 (HI); pin 2 (ignition) Directwire Left Front Window (Up/Down) (motor is part of module) Right Front Window (Up/Down) (motor is part of module) Left Rear Window (Up/Down) (motor is part of module) Right Rear Window (Up/Down) (motor is part of module) Sun Roof (Open/Close) lt. green - white (function with ignition on only) - driver kick, white 76 pin plug, pins 25 - 26 Posted By: qpham504 Date Posted: December 06, 2020 at 11:57 PM Thanks for the update. I haven't had time to test wires due to me trying to make a decision on swapping the engine out now and avoid it later while also working 6 days a week. Pandemic times.....
But thanks for updating. |
