2012 Honda Civic Coupe Alarm/Remote Start Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=145127
Printed Date: April 30, 2026 at 1:36 PM
Topic: 2012 Honda Civic Coupe Alarm/Remote Start Wiring
Posted By: wildstone81
Subject: 2012 Honda Civic Coupe Alarm/Remote Start Wiring
Date Posted: January 01, 2019 at 12:41 PM
Trying to get the correct wiring to install a compustar cs800-s on a 2012 Honda Civic coupe
------------- Keith Andrew Stone
Posted By: wirewise
Date Posted: January 03, 2019 at 5:27 PM
CIVIC 2012-2015
KEY T-HARNESS IMMOBILIZER
N/A N/A Equipped with Honda's TRANSPONDER Anti-Theft System, SEE NOTE #1
PART COLOR LOCATION DIAGRAM
12 VOLT CONSTANT WHITE (+) @ IGNITION SWITCH, WHITE 6-PIN PLUG, PIN 1
STARTER YELLOW (+) @ IGNITION SWITCH, WHITE 5-PIN PLUG, PIN 5
STARTER 2 N/A
IGNITION 1 BLUE (+) @ IGNITION SWITCH, WHITE 5-PIN PLUG, PIN 2
IGNITION 2 N/A
IGNITION 3 N/A
ACCESSORY/HEATER BLOWER 1 ORANGE (+) @ IGNITION SWITCH, WHITE 5-PIN PLUG, PIN 4
ACCESSORY/HEATER BLOWER 2 RED (+) @ IGNITION SWITCH, WHITE 6-PIN PLUG, PIN 3
KEYSENSE N/A
PARKING LIGHTS ( - ) GRAY (-) @ HEADLIGHT SWITCH, 12-PIN PLUG, PIN 8
PARKING LIGHTS ( + ) RED (+) @ DASH FUSE BOX, GREEN 44-PIN PLUG(B), PIN 29
POWER LOCK BLUE (-) TYPE B IN DRIVERS KICK @ DOOR HARNESS, 25-PIN PLUG, PIN 11
POWER UNLOCK GRAY (-) TYPE B IN DRIVERS KICK @ DOOR HARNESS, 25-PIN PLUG, PIN 18
LOCK MOTOR WIRE N/A
DOOR TRIGGER GREEN (-) @ DASH FUSE BOX, GREEN 44-PIN PLUG(B), PIN 39
DOMELIGHT SUPERVISION PINK (-) BELOW DASH FUSE BOX, 28-PIN PLUG, PIN 18
TRUNK RELEASE N/A
SLIDING POWER DOOR N/A
HORN ORANGE (-) or PINK (-) @ HORN SWITCH
TACH YELLOW, BLUE, RED, BROWN (AC), TAN, BLUE, RED, PURPLE (Si MODELS) @ ANY FUEL INJECTOR, 2-PIN PLUG, PIN 1
WAIT TO START LIGHT N/A
BRAKE LT. GREEN (+) @ BRAKE SWITCH or DASH FUSE BOX, 44-PIN PLUG (B), PIN 10
FACTORY ALARM DISARM BROWN (-) (TEST WITH DRIVERS DOOR KEY) IN DRIVERS KICK @ DOOR HARNESS, 25-PIN PLUG, PIN 9
ANTI-THEFT TRANSPONDER ANTI-THEFT SYSTEM
NOTES
NOTE #1: This vehicle is equipped with HONDA'S TRANSPONDER ANTI-THEFT SYSTEM, you have (3) options to bypass the Anti-Theft system on this vehicle, option 1 requires an extra IGNITION KEY that starts the vehicle to be placed INSIDE the 791 Bypass Module OR inside the B-Series Remote Starters WITH Built in bypass, this key must remain inside the bypass for Remote starting. Option 2 is, IF you have (2) keys that start the vehicle, you can use Part # PKALL, this INTERFACE BYPASS MODULE requires (2) keys that start the vehicle for programming, but you will NOT have to place a key inside this module. Option 3 is using the DBALL2 INTERFACE BYPASS MODULE, this module requires only 1 Key for programming and makes the installation of the remote starter a little easier, all connections such as, door lock and unlock, the trunk release and brake connections are all made at the Interface bypass module, you do not have to locate and connect these wires in the vehicle.
------------- ~wirewise~
