2014 Nissan Altima SV Radio 32 Pin Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=145211
Printed Date: April 30, 2026 at 8:20 PM
Topic: 2014 Nissan Altima SV Radio 32 Pin Wiring
Posted By: andrew2506
Subject: 2014 Nissan Altima SV Radio 32 Pin Wiring
Date Posted: February 05, 2019 at 12:17 PM
Hi there
Im looking for 2014 nissan altima SV radio harness diagram. My radio has 8 pin, 16pin main and 32 pin comm connector. I figured 8 pin and 16 pin however stuck with 32pin connector. I would be grateful If anyone can help me with the wiring for this connector.
Im trying to swap radio on model S with SV (want to use aftermarket camera) I purchased a harness for an aftermarket camera which works fine BTW but still need to find wires for steering wheel
Thank you
Posted By: motosaki
Date Posted: February 06, 2019 at 3:20 PM
Radio 12V     green     +     radio, white 20 pin plug, pin 19
Radio Ground     (chassis on base audio); gray (except base audio)     -     radio, white 20 pin plug, pin 20
Radio Ignition     pink     +     radio, white 20 pin plug, pin 7
Radio Illumination     red     +     radio, white 20 pin plug, pin 9
Factory Amp Turn-on     white     +     radio, white 20 pin plug, pin 1
Power Antenna     black     +     radio, gray 3 pin plug, pin 3
Left Front Speaker (+/-)     violet - lt. blue or black - white     +,-     radio, white 20 pin plug, pins 2 - 3
Right Front Speaker (+/-)     yellow - brown or black - white     +,-     radio, white 20 pin plug, pins 11 - 12
Left Rear Speaker (+/-)     brown - yellow or green - red     +,-     radio, white 20 pin plug, pins 4 - 5
Right Rear Speaker (+/-)     lt. green - violet or green - red     +,-     radio, white 20 pin plug, pins 13 - 14
Center Channel (+/-)     green - red     +,-     amplifier under rear deck, brown 14 pin plug, pins 11 - 12
Subwoofer (+/-)     white - green (L); white - green (R) (rear deck speakers with amp)     +,-     amplifier under rear deck, brown 14 pin plug, pins 6 - 1; 7 - 8
Aux. Audio Input Left (+/-)     red - black     +,-     radio, white 8 pin plug, pins 4 - 2 or white 24 pin plug, pins 3 - 2
Aux. Audio Input Right (+/-)     white - black     +,-     radio, white 8 pin plug, pins 3 - 2 or white 24 pin plug, pins 1 - 2
Rearview Camera Video     black - (shield)     +,-     radio, white 32 pin plug, pins 2 - 1 or white 24 pin plug, pins 21 - 22
The steering wheel controls are done thru data (CAN Lines, RX-TX, or IMMO) can't really help you there sorry.
15yrs. in the industry. everything from simple deck installs, to remote starters, and full custom audio systems. I've Installed it all.
Date Posted: February 07, 2019 at 10:54 AM
Thanks, I actually was able to get all wiring for 32pin connector and connect SV radio with screen to S model to have USB and backup camera. Here is pin out wiring:
posted_image
posted_image
posted_image
Posted By: dnn00180
Date Posted: July 07, 2020 at 7:53 PM
Hi I'm would like to do the same thing I purchased a sv wire harness and have no idea on the steering wheel wires please help.
dbewkirk
