2014 Ford Transit Connect Alarm Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=145544
Printed Date: April 16, 2026 at 8:14 PM
Topic: 2014 Ford Transit Connect Alarm Wiring
Posted By: jjmd845
Subject: 2014 Ford Transit Connect Alarm Wiring
Date Posted: July 27, 2019 at 8:07 PM
Need wiring information gor w014 transit connect please! Thank you!!
Posted By: wirewise
Date Posted: July 28, 2019 at 9:36 AM
TRANSIT CONNECT      2014-2016
KEY      T-HARNESS      IMMOBILIZER
N/A      N/A      FORD's TRANSPONDER ANTI-THEFT SYSTEM, See Note #1
PART      COLOR      LOCATION      DIAGRAM
12 VOLT CONSTANT      YELLOW (+) and RED (+)      @BCM GREEN 2 PIN PLUG(G), PINS 1,2 SEE NOTE#2
STARTER      BLUE/WHITE (+)      @ IGNITION SWITCH, BLACK 7-PIN PLUG, PIN 7
STARTER 2      N/A
IGNITION 1      BROWN/YELLOW (+)      @ IGNITION SWITCH, BLACK 7-PIN PLUG, PIN 1
IGNITION 2      N/A
IGNITION 3      N/A
ACCESSORY/HEATER BLOWER 1      PURPLE/GREEN (+)      @ IGNITION SWITCH, BLACK 7-PIN PLUG, PIN 6 SEE NOTE#2
ACCESSORY/HEATER BLOWER 2      N/A
KEYSENSE      BLUE/GRAY (+)      @ IGNITION SWITCH, BLACK 7-PIN PLUG, PIN 5
PARKING LIGHTS ( - )      Use Hazard Lights for (-) hook up BROWN/YELLOW (-)      @ BCM, BLUE 60 PIN PLUG (C), PIN 27, SEE NOTE #2
PARKING LIGHTS ( + )      YELLOW/BLUE (+) (L) BROWN/YELLOW (+) (R)      @ BCM, GREEN 42 PIN PLUG(A),PINS 1, 26 SEE NOTE #2
POWER LOCK      GRAY/YELLOW (-) TYPE (B)      @ BCM BROWN 60 PIN PLUG (B), PIN 36 SEE NOTE #2
POWER UNLOCK      PURPLE/GRAY (-) TYPE (B)      @ BCM BLUE 60 PIN PLUG(C), PIN 26
LOCK MOTOR WIRE      GRAY/BROWN (5-WIRE) ONE TOUCH WINDOW DOWN VEHICLES ONLY with ONE TOUCH UP/ DOWN wire is BLACK @ DRIVERS DOOR MODULE BLACK 22 PIN PLUG, PIN4      @ BCM BROWN 20 PIN PLUG(E), PIN 1
DOOR TRIGGER      WHITE/BROWN (-)      Connect NEGITIVE (-) door trigger wire from alarm to dome light supervision on car
DOMELIGHT SUPERVISION      WHITE/BROWN (-)      @ BCM GRAY 20 PIN PLUG(H), PIN 11
TRUNK RELEASE      BROWN (-)      @ BCM BROWN 60 PIN PLUG(B), PIN 49 SEE NOTE #2
SLIDING POWER DOOR      N/A
HORN      PURPLE/GREEN (-)      @ BCM, GREEN 42 PIN PLUG(A), PIN 31 SEE NOTE #2
TACH      GREEN/BLUE (AC)      @ Any FUEL INJECTOR (2.5L) .(1.6L) TOP OF ENGINE BLACK 8 PIN PLUG, PIN 1
WAIT TO START LIGHT      N/A
BRAKE      GREEN/RED (+)      @ BCM GREEN 42 PIN PLUG(A), PIN 16
FACTORY ALARM DISARM      N/A
ANTI-THEFT      TRANSPONDER
NOTES
NOTE #1 TRANSPONDER TYPE ANTI -THIEF SYSTEM REQUIRES #791 BYPASS AND EXTRA IGNITION KEY TO LEAVE IN BYPASS FOR REMOTE STARTING.
NOTE #2 THE BCM (BODY CONTROL MODULE) IS LOCATED BEHIND THE GLOVE BOX
~wirewise~
