2012 Nissan Caravan NV3500 Alarm Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=145814
Printed Date: May 03, 2026 at 3:51 PM
Topic: 2012 Nissan Caravan NV3500 Alarm Wiring
Posted By: steveta54
Subject: 2012 Nissan Caravan NV3500 Alarm Wiring
Date Posted: November 29, 2019 at 2:31 AM
Hi everybody I have a 2012 Nissan caravan and was after some wiring diagrams for one or any help if someone has done one . Thanks
Steve’s help full hints
Posted By: mgoetz74
Date Posted: November 29, 2019 at 1:15 PM
https://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.aspx
Posted By: wirewise
Date Posted: November 29, 2019 at 1:40 PM
https://www.the12volt.com/installbay/vehiclewiring/1/yeard/Nissan.html
NISSAN NV
MODEL      YEAR(S
NV      2012-2016
KEY      T-HARNESS      IMMOBILIZER
N/A      N/A      REQUIRES BYPASS MODULE PART# 791 AND A SPARE IGNITION KEY, See NOTE #1
PART      COLOR      LOCATION      DIAGRAM
12 VOLT CONSTANT      GREEN (+)      WHITE 6-PIN PLUG, PIN 3 @ IGNITION SWITCH
STARTER      YELLOW (+)      WHITE 6-PIN PLUG, PIN 2 @ IGNITION SWITCH
STARTER 2      N/A
IGNITION 1      BLUE (+)      WHITE 6-PIN PLUG, PIN 1 @ IGNITION SWITCH
IGNITION 2      N/A
IGNITION 3      N/A
ACCESSORY/HEATER BLOWER 1      RED (+)      WHITE 6-PIN PLUG, PIN 4 @ IGNITION SWITCH
ACCESSORY/HEATER BLOWER 2      PURPLE (+)      WHITE 6-PIN PLUG, PIN 5 @ IGNITION SWITCH
KEYSENSE      N/A
PARKING LIGHTS ( - )      N/A
PARKING LIGHTS ( + )      RED (+)      WHITE 4-PIN PLUG, PIN 3 in DRIVERS KICK PANEL
POWER LOCK      GRAY (-) TYPE B      in DRIVERS KICK PANEL or WHITE 15-PIN PLUG, PIN 5 @ BCM, See NOTE #2
POWER UNLOCK      RED (-) TYPE B      in DRIVERS KICK PANEL or WHITE 15-PIN PLUG, PIN 6 @ BCM, See NOTE #2
LOCK MOTOR WIRE      N/A
DOOR TRIGGER      LT. BLUE (-)      in DRIVERS KICK PANEL or WHITE 15-PIN PLUG, PIN 7 @ BCM, See NOTE #2
DOMELIGHT SUPERVISION      BLUE (-)      in DRIVERS A PILLAR or BLACK 15-PIN PLUG, PIN 8 @ BCM, See NOTE #2
TRUNK RELEASE      LOCKS/UNLOCKS with POWER LOCKS
SLIDING POWER DOOR      N/A
HORN      WHITE (-)
TACH      Any wire NOT WHITE or WHITE/GREEN (AC)      @ Any FUEL-INJECTOR
WAIT TO START LIGHT      N/A
BRAKE      LT. GREEN (+)      in DRIVERS KICK PANEL, WHITE 4PIN PLUG, PIN 2
FACTORY ALARM DISARM      YELLOW (-) Requires Double pulse      @ BCM, WHITE 40-PIN PLUG, PIN 7, See NOTE #2
ANTI-THEFT      See NOTE #1
NOTES
NOTE #1: THIS VEHICLE REQUIRES A BYPASS MODULEPART #791 AND A SPARE IGNITION KEY FOR REMOTE STARTING
NOTE #2: THE BCM IS LOCATED BEHIND THE INSTRUMENT CLUSTER.
~wirewise~
Date Posted: November 29, 2019 at 2:32 PM
Thanks m8 had a look but wiring completely different for New Zealand model. I made central locking work but had to solder back of circuit board and door switches are all separate can’t find single wire that’s operated all doors. I’ll keep trying
