US Spec. 2019 Nissan Sentra Radio Wiring Diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=145877
Printed Date: April 21, 2026 at 8:42 PM
Topic: US Spec. 2019 Nissan Sentra Radio Wiring Diagram
Posted By: nv200
Subject: US Spec. 2019 Nissan Sentra Radio Wiring Diagram
Date Posted: December 22, 2019 at 1:38 AM
Nissan changed the head unit on '19+ model and I can't find the new diagram for the new 40pin and 20pin connectors. Does anyone have it? Thanks
Picture for the 40pin connector is attached. Please review
posted_image
posted_image
posted_image
Posted By: i am an idiot
Date Posted: December 22, 2019 at 3:21 PM
That does not look like the plug for the radio. It may be the plug for the display, but I do not think it is the plug you are looking for.
Radio 12V      yellow      +      radio, white 20 pin plug, pin 19
Radio Ground      black      -      radio, white 20 pin plug, pin 20
Radio Ignition      blue      +      radio, white 20 pin plug, pin 7
Radio Illumination      violet (parking lights); gray (dimmer, w/o navigation)      +,-      radio, white 20 pin plug, pins 9, 8
Factory Amp Turn-on      gray      +      radio, white 20 pin plug, pin 1
Power Antenna      black      +      radio, gray 3 pin plug, pin 1
Left Front Speaker (+/-)      blue - pink      +,-      radio, white 20 pin plug, pins 2 - 3           Notes
Right Front Speaker (+/-)      green - red      +,-      radio, white 20 pin plug, pins 11 - 12           Notes
Left Rear Speaker (+/-)      lt. green - lt. blue or lt. green - violet      +,-      radio, white 20 pin plug, pins 4 - 5           Notes
Right Rear Speaker (+/-)      brown - yellow      +,-      radio, white 20 pin plug, pins 13 - 14           Notes
Subwoofer (+/-)      yellow - blue (L); red - white (R)      +,-      amplifier under rear deck, brown 14 pin plug, pins 2 - 7; 10 - 9
Aux. Audio Input Left (+/-)      yellow - green      +,-      radio, white 32 pin plug, pins 18 - 2 or white 8 pin plug, pins 4 - 2           Notes
Aux. Audio Input Right (+/-)      blue - green      +,-      radio, white 32 pin plug, pins 1 - 2 or white 8 pin plug, pins 3 - 2           Notes
Rearview Camera Video      violet - (shield)      +,-      radio, white 32 pin plug, pins 2 - 1 or white 24 pin plug, pins 16 - 15
Satellite Radio 12 Volts      (built into radio)
Posted By: nv200
Date Posted: December 22, 2019 at 6:52 PM
Thanks. Your info is pre '19 model with 32 pin connector. Nissan changed it to 40 pin on 19+ model.
Based on my research this 40 pin connector is reverse camera, steering control, and speed sensor, etc.
Date Posted: December 22, 2019 at 9:36 PM
Info came from Directechs 2019   They do not have any info on 2020
Posted By: ghollett12
Date Posted: June 26, 2020 at 12:53 PM
Any update on this as I'm running into the same issue trying to get the pin outs for the 40 pin connector,
Posted By: t0mf00lery7717
Date Posted: July 21, 2020 at 2:40 PM
Hello, I have a 2018 Nissan Altima with very similar radio and wiring, see pictures, can you help me identify the audio power etc. wires so that I can add an aftermarket system? posted_image posted_image posted_image posted_image
Build.
Posted By: skydeaner
Date Posted: October 09, 2020 at 9:29 PM
the 20pin handles the radio power ground acc, speakers, vss wires.
a standard 20pin Nissan harness will work for that.
the backup camera and steering wheel controls it doesn't seem anyone knows yet. they come off that 40pin connector. I have it limited down to the group of 4 that are 2 blacks, a red and a white, go to the camera but I don't know which is which as I already removed the factory unit and installed my pioneer and I can't find info on this anywhere.
I'm about to give up on it and install a standard 12v backup camera.
oh yeah that's another thing, for the camera you will need the axxess 6v converter or a similar buck converter as Nissan apparently lost their minds and decided to power their cams with 6 instead of 12volts.
Date Posted: October 13, 2020 at 11:59 PM
with the help of axxess support I got everything figured out except for the speedsense wire.
well... and the aux in, but honestly that would be incredibly easy with a multimeter I just don't care about that because I'll never use it.
anyone know what wire the speedsense is and which harness it comes from, the 40pin or the 20pin? I don't know if i have any extras on the 20pin or not...
Date Posted: October 14, 2020 at 8:12 AM
Can you post the information Metra helped you with? Wire colors and where they went. It may be helpful for someone in the future.
Date Posted: October 14, 2020 at 8:20 AM
yes I will, I am just waiting for my day off so I can also drop a picture somewhere and link it or however you do that in this forum. I'm unusually busy as of late
Date Posted: October 14, 2020 at 8:56 AM
Above the window you are typing in there is an arrow pointing up with a tree behind it. That is the upload an image button. Use it if the image is on your phone or computer. To the left of that is just a picture of a tree. Click that if the image is somewhere on the web.
Date Posted: October 14, 2020 at 9:12 PM
Thanks for that
The connector
posted_image
For the backup cam:
I think i got the pin numbers right
purple-- composite+ [center conductor] (pin 49)
black--ground (pin 48)
teal--6v+ (pin 28)
blue--composite- [outer ring](pin 29)
for the aswc-1.
posted_image
So their pink wire to the light blue,
Their blue/pink to the light green below it.
I combined about 5 1 watt resistors I had of various values in parallel to get the 68 ohm resistance needed, but I assume they make 68 ohm resistors lol, I just had a bunch of random ones laying around.
Everything worked perfectly except for the phone and google voice buttons being backward for the pioneer. And it wouldn't reprogram by hitting the reset button or holding volume up like their instructions say (I think there is something weird about the volume buttons, like it's not a constant when held down or something) So I had to reprogram those reversed using the windows remapping tool, but they also make a version for iphones and android phones if you don't have a computer available.
All buttons work, I have assigned second commands for long holding down buttons and changed some things to my liking in there also, it's pretty cool.
Their support staff is top notch, I don't think i've ever had a better customer service experience, the dude I was dealing with up there was obviously a pro at what he does and responded super quick.
Date Posted: October 14, 2020 at 9:21 PM
Still need to figure out the vss wire and then I can get everything soldered in place. Anyone know which it is and if it comes from this 40 pin or the 20 pin ?
pioneer dmh-4660nex for the head unit
Skar 150.4ab for my mids and highs, 2 way active MX-261 components (midbass champs for sure with this much power and very detailed)
taramps 3000wrms for the sub which is a 12" NVX vcw122 (more bass than i'll ever need in a custom made box tuned to ~26hz based on impedance)
Posted By: happy_dalek
Date Posted: November 08, 2020 at 3:59 PM
Thank you so much for this information skydeaner! Although the wire colors are different in my 2018 Kicks, the pinouts for the camera and swc are exactly as you mentioned.
Date Posted: January 27, 2021 at 11:24 PM
You're welcome! yay I helped someone! actually it's funny cuz my car got totalled in late December and I got a 19 maxima instead and the colors were off on that too red/black/white/gray and my pinout worked on this car too! so thank goodness I decided to post my results for everyone! it almost makes me think Nissan knows what they are doing they just give zero loves about the color of wires they use lmao
edit: oh and I was just talking about the camera, but now that you mention it, yes the swc was the same on the maxima also just different colors as well. So maybe I will make a post with all three cars in the title here at 12v and other forums so no one has to search Google tediously. And thanks for saying thank you, that made my day.
Posted By: tonii38
Date Posted: May 18, 2021 at 12:45 AM
So the black isn't a shield? Bare wiring underneath? Mine are different color on 2019 Nissan Altima but I believe black is shield being positive for the signal
A
Date Posted: May 18, 2021 at 1:32 AM
I personally wouldn't rely on any "color". As they follow absolutely no standard from one vehicle to another apparently. They didn't care they were using blue for shield (composite outer ring) on my sentra, and I don't remember the color the shield was on my maxima because I just went by my pinout and not by colors, and by the time I got it working I was tired and just threw it all back together.
And the dude with the kicks says his were all different colors also lol. I would just count the pins and do a quick check and see if it works.
If you still have the stock head unit it is easy to check the 6v+ and ground with a multimeter, pop it in reverse (with the ebrake on lol) and probe the pins for 6 volts.. and then if you get the composite center pin and outer ring (shield) backeards it won't harm anything it just won't work and you can then reverse them and be done with it.
Posted By: str8jeanius
Date Posted: August 20, 2021 at 9:38 PM
Hey would you happen to know what any of the other wire colors mean on the 40pin connector? I’m trying to upgrade my 2018 Sentra radio to the 2019 one with CarPlay but I don’t want to slice into the wrong colors. Also if you know what any of the colors on the 2018 Sentra’s 32pin connector?
Posted By: audiokid1
Date Posted: August 21, 2021 at 11:21 AM
2019 Nissan Sentra Connectors
posted_image
posted_image
I'd need more info on the other vehicles in order to provide any help. Trim level of vehicle, Bose or Non-Bose, Nav or No Nav.
Date Posted: August 22, 2021 at 6:01 AM
Aw thanks man, you're a lifesaver. I wasn't expecting a reply back but I'm glad you could help. By the way, I have a 2018 Nissan Sentra SV with 1.8L It came with the regular radio. I want to upgrade to the 2019 carplay radio. I'll provide photos. MOst of the connectors fit. Im just having trouble with the 40Pin which controls the rearview camera. I understand i have to splice my 32pin connector into the 40pin but i didnt know which color wires to splice. Or if i should get a harness and splice into the harness wires to keep my original wiring for future purposes. Here's some photos of the radio and the connectors
posted_image
posted_image
posted_image
posted_image
posted_image
Date Posted: August 22, 2021 at 9:21 AM
Thanks for supplying photos.....Hopefully this helps
2018 Wire Info
posted_image
posted_image
Date Posted: August 22, 2021 at 9:53 AM
Aw man thank you so much!! Hey would you mind if i share this information on another forum? a few friends of mine would greatly appreciate this help and help others along the way as well. Again, friend thank you so much for this 8D
Date Posted: August 22, 2021 at 10:08 AM
Please feel free to share
Posted By: imtfox
Date Posted: September 25, 2025 at 9:29 PM
I don't know who might need this, but the reverse wire for a 2020 Nissan Sentra is hunter green in the bundle from the rear in the driver's kick panel. I have yet to get a steering wheel control interface to program correctly for it. Seems to be more Renault than Nissan in the guts. The camera wires above work well.
Who's House?? Run's house!!
