2016 Hyundai Sonata, Alarm Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=146546
Printed Date: April 20, 2026 at 1:22 AM
Topic: 2016 Hyundai Sonata, Alarm Wiring
Posted By: avrohom24
Subject: 2016 Hyundai Sonata, Alarm Wiring
Date Posted: November 09, 2020 at 10:53 PM
Hi, Im installing the Avital 4105 on a 2016 Sonata. The wiring is supposed to be the same as the 2011 Soanta, however its not. I was wondering if its the same as the 2017 Tucson as there is a wiring diagram for that. The wires Im missing for now are the Horn wire, Alarm Disarm, headlights, and Rear Defogger. Any and all help is greatly appreciated
------------- AYS
Posted By: i am an idiot
Date Posted: November 10, 2020 at 1:01 PM
Hybrid? Smart Key? Regular Key?
Date Posted: November 10, 2020 at 1:31 PM
Regular Key. Love your user name!
------------- AYS
Date Posted: November 15, 2020 at 2:53 PM
Item Wire Color Polarity Wire Location Photo Note
12 Volts red/orange (30A) + ignition switch, black 6 pin plug, pin 1
Second 12 Volts red (40A) + ignition switch, black 6 pin plug, pin 5
Ground (chassis ground)
Starter yellow + ignition switch, black 6 pin plug, pin 3
Ignition pink + ignition switch, black 6 pin plug, pin 4
Accessory orange + ignition switch, black 6 pin plug, pin 2
Second Accessory blue + ignition switch, black 6 pin plug, pin 6
Keysense white - key switch, white 6 pin plug, pin 4
CAN Bus High white (C-CAN) data OBD-data link connector, black 16 pin plug, pin 6 Directwire
CAN Bus Low brown (C-CAN) data OBD-data link connector, black 16 pin plug, pin 14 Directwire
CAN Bus High 2 yellow (B-CAN) data SJB-dash fuse box, rear, white 32 pin plug (F), pin 9
CAN Bus Low 2 black (B-CAN) data SJB-dash fuse box, rear, white 32 pin plug (F), pin 10 Directwire
IMMO Data blue/orange (EMS COM) data driver kick, white 47 pin plug, pin 19 Directwire
K Line blue/black data OBD-data link connector, black 16 pin plug, pin 12 Directwire
Power Lock white (w/o memory); (or use factory alarm arm) - SJB-dash fuse box, white 32 pin plug (H), pin 1
Power Unlock yellow (w/o memory); (or use factory alarm disarm) - SJB-dash fuse box, white 32 pin plug (H), pin 19
Power Unlock - Driver Door yellow/orange - SJB-dash fuse box, rear, white 32 pin plug (F), pin 5 Directwire
Lock Motor gray/black 5 wire SJB-dash fuse box, black 51 pin plug (D), pin 44
Driver Unlock Motor white 5 wire driver kick, white 77 pin plug, pin 52 Directwire
Passenger Unlock Motor brown 5 wire SJB-dash fuse box, black 51 pin plug (D), pin 26
Factory Alarm Arm yellow (see Tech Doc 1300) - SJB-dash fuse box, white 32 pin plug (H), pin 5
Factory Alarm Disarm blue (see Tech Doc 1300) double - SJB-dash fuse box, white 32 pin plug (H), pin 22
Lock Detection brown (see Tech Doc 1300) open SJB-dash fuse box, white 32 pin plug (H), pin 10
Unlock Detection (same as lock detection) -
Parking Lights green/black (L); brown/black (R) + SJB-dash fuse box, black 51 pin plug (D), pins 6, 5
Parking Lights - blue/orange - 1680 ohms headlight/wiper switch, black 16 pin plug, pin 14
Parking Lights MUX blue/orange MUX headlight/wiper switch, black 16 pin plug, pin 14
Hazards red/black - SJB-dash fuse box, rear, white 32 pin plug (F), pin 13 Directwire
Turn Signal (Left) blue/orange (F); blue/orange (R) + SJB-dash fuse box, white 20 pin plug (B), pin 18; black 51 pin plug (D), pin 30
Turn Signal (Right) red/orange (F); red/orange (R) + SJB-dash fuse box, white 20 pin plug (B), pin 8; black 51 pin plug (D), pin 28
Headlight blue/orange - 5580 ohms headlight/wiper switch, black 16 pin plug, pin 14
AutoLights blue/orange cut headlight/wiper switch, black 16 pin plug, pin 14
Reverse Light blue + driver kick, white 47 pin plug, pin 7 Directwire
Left Front Door Trigger blue - SJB-dash fuse box, white 32 pin plug (H), pin 9
Right Front Door Trigger white - SJB-dash fuse box, white 32 pin plug (H), pin 11
Left Rear Door Trigger brown - SJB-dash fuse box, white 32 pin plug (H), pin 12
Right Rear Door Trigger orange - SJB-dash fuse box, white 32 pin plug (H), pin 14
Dome Light yellow - left front pillar, white 36 pin plug, pin 4
Trunk/Hatch Pin black/orange - SJB-dash fuse box, white 32 pin plug (H), pin 13
Hood Pin green - SJB-dash fuse box, white 24 pin plug (C), pin 3
Trunk/Hatch Release white - trunk lid opener switch, 8 pin plug, pin 3
Trunk Release Motor red + SJB-dash fuse box, black 51 pin plug (D), pin 41
Fuel Door Release green/black + fuel lid opener switch, 8 pin plug, pin 5
Tachometer blue/orange (2.4L, 2.0L-T); green (1.6L-T) ac camshaft position sensor on engine driver side, gray 3 pin plug, pin 3; black 3 pin plug, pin 2
Fuel Pump green + driver kick, white 6 pin plug, pin 2
Rear Defroster black/orange - latched SJB-dash fuse box, white 24 pin plug (C), pin 10
Mirror Defroster (same as rear defroster)
Left Front Heated Seat red + A/C Control Module, white 40 pin plug, pin 16
Right Front Heated Seat brown + A/C Control Module, white 40 pin plug, pin 17
Speed Sense green ac OBD-data link connector, black 16 pin plug, pin 3 or radio, white 24 pin plug, pin 16 Directwire
Brake Wire green + driver kick, white 47 pin plug, pin 14 Directwire
Parking Brake orange (without electric parking brake) - SJB-dash fuse box, white 24 pin plug (C), pin 13
Horn Trigger yellow/orange - driver kick, white 47 pin plug, pin 35
Wipers blue + driver kick, white 47 pin plug, pin 33
Left Front Window (Up/Down) (motor is part of module)
Right Front Window (Up/Down) orange - white (without auto up/down only) A driver kick (without memory); RF window switch, white 8 pin plug, pins 3 - 2 (with memory)
Left Rear Window (Up/Down) gray - pink (without memory); green - yellow (with memory) A driver kick (without memory); LR window switch, white 12 pin plug, pins 1 - 4 (with memory)
Right Rear Window (Up/Down) green - yellow (without memory); brown - white (with memory) A driver kick (without memory); RR window switch, white 12 pin plug, pins 1 - 4 (with memory)
Sun Roof (Open/Close) yellow - gray (function with ignition on only) - panorama sunroof switch, black 6 pin plug, pins 2 - 3
Memory Seat 1 pink - driver kick, harness to rear
Memory Seat 2 blue - driver kick, harness to rear
