2014 Honda Odyssey EXL, Door Lock and Hazard Light Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=146914
Printed Date: April 28, 2026 at 3:30 AM
Topic: 2014 Honda Odyssey EXL, Door Lock and Hazard Light Wiring
Posted By: nokanfiga
Subject: 2014 Honda Odyssey EXL, Door Lock and Hazard Light Wiring
Date Posted: June 30, 2021 at 4:59 PM
I’m looking for wiring diagram and locations for the door unlock/lock, and hazard lights location for install of a device called MoboKey. Any assistance will be greatly appreciated. Thanks!!
Posted By: i am an idiot
Date Posted: June 30, 2021 at 8:03 PM
Power Lock (see factory alarm arm)
Power Unlock (see factory alarm disarm)
Factory Alarm Arm Pink (driver door key lock) - Power Window Master Switch, gray 37 pin plug, pin 34
Factory Alarm Disarm Brown (key unlock); White (unlock detection) Both - - Power Window Master Switch, gray 37 pin plug, pins 33, 31
Parking Lights Red + Passenger Kick Fuse Box, green 13 pin plug (A), pin 7
Parking Lights - Gray - Headlight Switch, black/white 12 pin plug, pin 11 Directwire
Hazards Green + Hazard Switch, green 5 pin plug, pin 4
Date Posted: August 10, 2021 at 2:23 AM
Is there a way to wire door unlock/ lock from the Mobokey device using wires from the keyless entry module located under the dash? Trying to avoid "fishing" wires through the driver's door harness from under the dash. TIA!!!
Date Posted: August 10, 2021 at 9:55 AM
Directechs has only the information I posted. If there was a way to do it without going into the door, and they knew how to do it, they would have given that as an option as well.
