2017 Ford Explorer Sport, Speaker Wiring Diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=147006
Printed Date: May 12, 2026 at 9:17 PM
Topic: 2017 Ford Explorer Sport, Speaker Wiring Diagram
Posted By: javi20914
Subject: 2017 Ford Explorer Sport, Speaker Wiring Diagram
Date Posted: August 28, 2021 at 10:21 AM
I really need this wiering diagram thank you
2017 ford explorer sport wiring diagram
Speaker wiring diagram
Javier Sanchez
Posted By: i am an idiot
Date Posted: August 28, 2021 at 12:20 PM
If it is a smart key, this is it. If a regular key, let me know and I can see if the info is different.
Factory Amp Turn-on      Violet/Red      +      Radio, black 26 pin plug, pin 18
Power Antenna      Blue/Brown or Blue      +      Radio, black 24 pin plug, pin 2
Left Front Speaker (+/-)      White - White/Brown or Green - Gray      +,-      Radio, black 24 pin plug, pins 22 - 10
Right Front Speaker (+/-)      White/Violet - White/Orange or Violet - Yellow      +,-      Radio, black 24 pin plug, pins 23 - 11
Left Rear Speaker (+/-)      White/Green - Brown/Yellow or White - Brown      +,-      Radio, black 24 pin plug, pins 21 - 9
Right Rear Speaker (+/-)      Brown/White - Brown/Blue or Brown - Blue      +,-      Radio, black 24 pin plug, pins 24 - 12
Center Channel (+/-)      Green - Gray/Yellow      +,-      Radio, black 24 pin plug, pins 20 - 8
Left Front Speaker - With Amp      White - White/Brown      +,-      Amplifier in right rear quarter panel, gray 16 pin plug, pins 2 - 10
Right Front Speaker - With Amp      White/Violet - White/Orange      +,-      Amplifier in right rear quarter panel, gray 16 pin plug, pins 6 - 14
Left Front Tweeter - With Amp      Green/Orange - Gray/Orange      +,-      Amplifier in right rear quarter panel, gray 16 pin plug, pins 3 - 11
Right Front Tweeter - With Amp      Violet/Orange - Yellow/Orange      +,-      Amplifier in right rear quarter panel, gray 16 pin plug, pins 7 - 15
Left Rear Speaker - With Amp      White/Green - Brown/Yellow      +,-      Amplifier in right rear quarter panel, gray 16 pin plug, pins 4 - 12
Right Rear Speaker - With Amp      Brown/White - Brown/Blue      +,-      Amplifier in right rear quarter panel, gray 16 pin plug, pins 8 - 16
Left Rear Tweeter - With Amp      Green/Brown - Gray/Brown      +,-      Amplifier in right rear quarter panel, gray 16 pin plug, pins 5 - 13
Right Rear Tweeter - With Amp      (parallel with left rear tweeter)
Center Channel - With Amp      Green - Gray/Yellow      +,-      Amplifier in right rear quarter panel, gray 16 pin plug, pins 1 - 9
Subwoofer - With Amp      Green/Violet - Gray (coil 1); Violet - Yellow (coil 2)      +,-      Amplifier in right rear quarter panel, blue 16 pin plug, pins 1 - 9 (coil 1); pins 2 - 10 (coil 2)
Aux. Audio Input Left (+/-)      Blue/Red - Gray/Orange (SYNC audio)      +,-      Radio, black 26 pin plug, pins 12 - 25
Aux. Audio Input Right (+/-)      Violet/Green - Brown/White (SYNC audio)      +,-      Radio, black 26 pin plug, pins 13 - 26
Rearview Camera Video      White - Brown/Violet --or-- Green/Blue - Brown/Violet --or-- Green - Violet/Gray      +,-      Front Control-Display, black 12 pin plug, pins 6 - 12 --or-- SYNC Module-Display, black 54 pin plug, pins 14 - 15
Date Posted: August 31, 2021 at 12:59 AM
Thank you very much
Javier Sanchez
