2017 Volkswagen Jetta, Remote Start Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=147029
Printed Date: April 30, 2026 at 3:12 PM
Topic: 2017 Volkswagen Jetta, Remote Start Wiring
Posted By: jsabatio07
Subject: 2017 Volkswagen Jetta, Remote Start Wiring
Date Posted: September 08, 2021 at 4:14 PM
I am search of a wiring diagram/schematic for a 2017 Jetta to install a Compustar remote starter, any feedback is greatly appreciated.
1.4T, automatic w/ push to start
------------- jsab07
Posted By: wirewise
Date Posted: September 08, 2021 at 4:35 PM
I believe this is it. If not, it should point you in the right direction. Be sure to verify all wires with your meter before making any connections.
KEY T-HARNESS IMMOBILIZER
N/A N/A VW'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, VEHICLES WITH SMART KEY AND PUSH TO START REQUIRES A DBALL2
PART COLOR LOCATION DIAGRAM
12 VOLT CONSTANT RED/WHITE (+) VESCM under driver dash, black 73 pin plug, pin 68
STARTER RED/BLACK (+) ignition switch, 10 pin plug, pin 4
STARTER 2 N/A
IGNITION 1 BLACK/PURPLE (+) ignition switch, 10 pin plug, pin 8
IGNITION 2 N/A
IGNITION 3 N/A
ACCESSORY/HEATER BLOWER 1 BLACK/RED (+) ignition switch, 10 pin plug, pin 3
ACCESSORY/HEATER BLOWER 2 N/A
KEYSENSE BLACK/GRAY (+) ignition switch, 10 pin plug, pin 2
PARKING LIGHTS ( - ) BROWN/YELLOW USE HAZARDS (-) headlight switch, 10 pin plug, pin 3
PARKING LIGHTS ( + ) GRAY/RED (+) headlight switch, 10 pin plug, pin 3
POWER LOCK BLUE/RED (-) ONE WIRE SYSTEM headlight switch, 10 pin plug, pin 3
POWER UNLOCK SAME AS LOCK WIRE (- 180 OHM ) headlight switch, 10 pin plug, pin 3
LOCK MOTOR WIRE BLUE/GREEN (5-WIRE) VESCM under driver dash, black 73 pin plug, pin 11
DOOR TRIGGER BROWN/YELLOW (-) VESCM under driver dash, black 73 pin plug, pin 19
DOMELIGHT SUPERVISION RED/BLUE (-) VESCM under driver dash, black 73 pin plug, pin 4
TRUNK RELEASE PURPLE (-) VESCM under driver dash, black 73 pin plug, pin 23
SLIDING POWER DOOR N/A
HORN BLACK/WHITE (+) VESCM under driver dash, black 73 pin plug, pin 72
TACH BLUE/GRAY (1.8L), GREEN/RED (2.0L), GREEN/PURPLE (TDI) (AC) cam position sensor on engine top driver side or center, 3 pin plug, pin 2
WAIT TO START LIGHT N/A
BRAKE BLACK/RED (+), (TEST with IGNITION KEY ON) VESCM under driver dash, black 73 pin plug, pin 43
FACTORY ALARM DISARM N/A
ANTI-THEFT VW'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, VEHICLES WITH SMART KEY AND PUSH TO START REQUIRES A DBALL2
------------- ~wirewise~
Date Posted: September 08, 2021 at 7:21 PM
Awesome, thank you so much
