2011 Mitsubishi Endeavor Tech Sheet
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=147101
Printed Date: April 30, 2026 at 5:17 PM
Topic: 2011 Mitsubishi Endeavor Tech Sheet
Posted By: skyram
Subject: 2011 Mitsubishi Endeavor Tech Sheet
Date Posted: October 27, 2021 at 12:05 PM
Hi,
Can anyone provided me with a tech sheet for a Mitsubishi 2011 Endeavor LS V6?
------------- CEndeavor
Posted By: wirewise
Date Posted: October 27, 2021 at 12:51 PM
ENDEAVOR 2008-2011
KEY T-HARNESS IMMOBILIZER
N/A N/A MITSUBISHI'S TRANSPONDER ANTI-THEFT SYSTEM, See NOTE #1
PART COLOR LOCATION DIAGRAM
12 VOLT CONSTANT BLUE/YELLOW (+) @ IGNIION SWITCH, (6-PIN PLUG), PIN 1
STARTER BLACK/YELLOW (+) @ IGNIION SWITCH, (6-PIN PLUG), PIN 5
STARTER 2 N/A
IGNITION 1 BLACK/WHITE (+) @ IGNIION SWITCH, (6-PIN PLUG), PIN 2
IGNITION 2 N/A
IGNITION 3 N/A
ACCESSORY/HEATER BLOWER 1 BLUE/RED (+) @ IGNIION SWITCH, (6-PIN PLUG), PIN 4
ACCESSORY/HEATER BLOWER 2 BLUE/BLACK (+) @ IGNIION SWITCH, (6-PIN PLUG), PIN 6
KEYSENSE N/A
PARKING LIGHTS ( - ) N/A
PARKING LIGHTS ( + ) GREEN/ORANGE (+)(Left), GREEN/WHITE (+)(Right)(Requires 775 relay) in DRIVERS KICK PANEL(Left), or FUSE BOX, (TOP, 15-PIN PLUG), PIN 2(Right)
POWER LOCK PURPLE (-) TYPE B in DRIVERS KICK PANEL or ETACS-ECU, (WHITE, 24-PIN PLUG), PIN 13, NOTE #2
POWER UNLOCK LT. GREEN/RED (-) TYPE B in DRIVERS KICK PANEL or ETACS-ECU, (WHITE, 24-PIN PLUG), PIN 14, NOTE #2
LOCK MOTOR WIRE BLUE/RED (5-wire type) in DRIVERS KICK PANEL or FUSE BOX, (BOTTOM, 28-PIN PLUG), PIN 19
DOOR TRIGGER LIGHT GREEN (-) in DRIVERS KICK PANEL or FUSE BOX, (TOP, 15-PIN PLUG), PIN 6
DOMELIGHT SUPERVISION RED/GREEN (-) @ FUSE BOX, (TOP, 3-PIN PLUG), PIN 1
TRUNK RELEASE BLACK/YELLOW (-), NOTE #3 in DRIVERS KICK PANEL or ETACS-ECU, (WHITE, 24-PIN PLUG), PIN 21, NOTE #2
SLIDING POWER DOOR N/A
HORN LT. GREEN (-) @ HORN SWITCH or ETACS-ECU, (WHITE, 24-PIN PLUG), PIN 24, NOTE #2
TACH Any wire NOT RED (AC) @ Any FUEL-INJECTOR
WAIT TO START LIGHT N/A
BRAKE GREEN (+) @ BRAKE PEDAL SWITCH or in DRIVERS KICK PANEL, Harness to REAR of Vehicle.
FACTORY ALARM DISARM DISARMS with FACTORY REMOTE ONLY !!
ANTI-THEFT MITSUBISHI'S TRANSPONDER ANTI-THEFT SYSTEM, See NOTE #1 @ IGNITION SWITCH TUMBLER
NOTES
NOTE #1: MITSUBISHI'S TRANSPONDER ANTI-THEFT SYSTEM, Requires Bypass Module, Part # 791 Bypass Module (for REMOTE STARTING ONLY!) an Extra Ignition key is required to be placed inside this module for Operation.
Part # XK09 Bypass Module, this Module is a KEYLESS BYPASS MODULE and DOES NOT require a Key to be placed inside the Module for Operation.
NOTE #2: the ETACS-ECU, (Electronic Time and Alarm Control System ECU) is located under the DRIVERS DASH, attached to the Back of the FUSE BOX, it has 2 Plugs on the LEFT side Edge.
NOTE #3: TEST this wire while Opening the LIFTGATE from the Handle on the REAR of the Vehicle.
------------- ~wirewise~
