Keyless Entry Wiring, 2018 GMC Savanah
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=147158
Printed Date: April 30, 2026 at 9:10 AM
Topic: Keyless Entry Wiring, 2018 GMC Savanah
Posted By: zammarelli
Subject: Keyless Entry Wiring, 2018 GMC Savanah
Date Posted: December 01, 2021 at 3:57 PM
I want to install keyless entry on a work van. Very simple. Just a fob to lock/unlock doors. Don't need anything fancy like alarms, remote starts, don't even want horn or light activation. I've done this before on older vehicles but wasn't sure if there's anything special on newer ones. Is it still as simple as finding the lock and unlock wires and splicing in my keyless entry box? Thsi is a 2018 gmc savana
Posted By: i am an idiot
Date Posted: December 01, 2021 at 6:47 PM
12 Volts      red/white (10A)      +      BCM under passenger dash, black 25 pin plug, pin 1      Directwire
Second 12 Volts      red/black (125A)      +      body fuse box under driver seat      Directwire
Ground      (chassis ground)
Starter      violet (for starter kill only)      +      starter or underhood fuse box, lt. gray 56 pin plug, pin E1
Second Starter      pink (R Code) (see Tech Doc 1605)      +9600 ohms      ignition switch, black 6 pin plug, pin 5      Directwire
Ignition      pink      +      ignition switch, black 6 pin plug, pin 2      Directwire
Accessory      brown      +      ignition switch, black 6 pin plug, pin 3      Directwire
Second Accessory      same as second starter      +6300 ohms
Keysense      same as second starter
CAN Bus High      tan/black      data      OBD-data link connector, black 16 pin plug, pin 6
CAN Bus Low      tan      data      OBD-data link connector, black 16 pin plug, pin 14
CAN Bus SW      dk. green      data      OBD-data link connector, black 16 pin plug, pin 1
OBD 12 Volts      red/white (20A)      +      OBD-data link connector, black 16 pin plug, pin 16
OBD Ground      black/white      -      OBD-data link connector, black 16 pin plug, pin 4
IMMO Data      dk. green      data      Immobilizer Control Module on ignition switch, black 5 pin plug, pin 4      Directwire
IMMO Power      red/white      +      Immobilizer Control Module on ignition switch, black 5 pin plug, pin 1      Directwire
Power Lock      pink/black      -      driver kick or BCM under pass dash, gray plug, pin 12      Directwire
Power Unlock      orange/black      -      driver kick or BCM under pass dash, gray plug, pin 11      Directwire
Power Unlock - Driver Door      yellow      -      BCM under pass dash, gray plug, pin 6
