| Print Page | Close Window |
2012 Infiniti G37 Sedan, Alarm Install InformationPrinted From: the12volt.comForum Name: Vehicle Wiring Information & File Requests Forum Discription: Request Car Alarm, Car Stereo, Cruise Control, Remote Starter, Navigation, Mobile Video, and Other Vehicle Specific Wiring Info, Manuals, Tech Tips URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=147178 Printed Date: April 21, 2026 at 10:42 PM Topic: 2012 Infiniti G37 Sedan, Alarm Install Information Posted By: pappa14 Subject: 2012 Infiniti G37 Sedan, Alarm Install Information Date Posted: December 17, 2021 at 7:38 PM I have a Viper 5305V alarm. Looking for wiring info and any other install information. Going to be installing within the next month or so. Thank You
Replies: Posted By: pappa14 Date Posted: December 17, 2021 at 7:39 PM It is a push button start
Posted By: i am an idiot Date Posted: December 17, 2021 at 9:44 PM It is only available in push to start.
12 Volts white (40A) + BCM in passenger kick, black 3 pin plug, pin 1 Directwire Second 12 Volts red (80A) + dash fuse box, rear, white 1 pin plug, pin 1 Ground (chassis ground) Starter red (sedan, coupe); brown (convertible) - BCM in passenger kick, gray 40 pin plug, pin 21 Directwire Ignition lt. blue (sedan, coupe); red (convertible) + BCM in passenger kick, black 40 pin plug, pin 11 Directwire Second Ignition yellow - BCM in passenger kick, gray 40 pin plug, pin 16 Directwire Accessory beige + BCM in passenger kick, black 40 pin plug, pin 31 Directwire Second Accessory beige + BCM in passenger kick, black 40 pin plug, pin 24 Directwire PTS 1 brown - Push-Button Ignition Switch, brown 8 pin plug, pin 4 --OR-- BCM in passenger kick, gray 40 pin plug, pin 29 Directwire Keysense lt. blue + Key Slot, white 12 pin plug, pin 11 --OR-- BCM in passenger kick, green 40 pin plug, pin 10 Directwire CAN Bus High blue data OBD-data link connector, white 16 pin plug, pin 6 CAN Bus Low pink data OBD-data link connector, white 16 pin plug, pin 14 CAN Bus High 2 blue data BCM in passenger kick, black 40 pin plug, pin 20 Directwire CAN Bus Low 2 pink data BCM in passenger kick, black 40 pin plug, pin 19 Directwire IMMO Data white data Key Slot, white 12 pin plug, pin 3 --OR-- BCM in passenger kick, black 40 pin plug, pin 10 Directwire IMMO Clock gray data Key Slot, white 12 pin plug, pin 2 --OR-- BCM in passenger kick, black 40 pin plug, pin 9 Directwire Security Light white (sedan, coupe); red (convertible) - BCM in passenger kick, green 40 pin plug, pin 30 Directwire Door Lock Data violet (sedan, coupe); lt. green (convertible) (power window switch communication) data BCM in passenger kick, green 40 pin plug, pin 21 Directwire Power Lock (use factory alarm arm or insert pin) - BCM in passenger kick, green 40 pin plug, pin 37 Directwire Power Unlock (use factory alarm disarm or insert pin) - BCM in passenger kick, green 40 pin plug, pin 15 Directwire Lock Motor violet 5 wire BCM in passenger kick, white 16 pin plug, pin 5 Directwire Driver Unlock Motor green 5 wire BCM in passenger kick, white 16 pin plug, pin 6 Directwire Passenger Unlock Motor pink 5 wire BCM in passenger kick, white 16 pin plug, pin 2 Directwire Factory Alarm Arm violet (sedan, convertible); gray (coupe) (driver door key lock) - power window main switch, white 16 pin plug, pin 4 or 6 Directwire Factory Alarm Disarm yellow (sedan); white (coupe, convertible) (driver door key unlock) double - power window main switch, white 16 pin plug, pin 6 or 7 Directwire Disarm No Unlock (proximity key and push-button) Parking Lights red + driver kick (with DRL); dash fuse box, white 10 pin plug, pin 8 (without DRL) Directwire Hazards green - BCM in passenger kick, black 40 pin plug, pin 39 Directwire Turn Signal (Left) beige (F); yellow (R) + BCM in passenger kick, white 16 pin plug, pin 15; white 12 pin plug, pin 6 Directwire Turn Signal (Right) white (sedan, coupe), brown (convertible) (F); violet (R) + BCM in passenger kick, white 16 pin plug, pin 14; white 12 pin plug, pin 1 Directwire Headlight violet (sedan), pink (coupe, convertible) (L); red (R) + headlights or underhood fuse box, white 8 pin plug, pins 2, 1 Reverse Light beige + driver kick, harness to rear or radio, white 32 pin plug, pin 19 or 21 Directwire Left Front Door Trigger gray (sedan, coupe); red (convertible) - BCM in passenger kick, green 40 pin plug, pin 39 Directwire Right Front Door Trigger red (sedan, coupe); beige (convertible) - BCM in passenger kick, green 40 pin plug, pin 13 Directwire Left Rear Door Trigger blue - BCM in passenger kick, gray 40 pin plug, pin 38 Directwire Right Rear Door Trigger beige - BCM in passenger kick, gray 40 pin plug, pin 37 Directwire Dome Light violet (dome lamp); lt. blue (step lamp) - BCM in passenger kick, white 16 pin plug, pins 16, 4 Directwire Trunk/Hatch Pin beige (sedan, coupe); green (convertible) - BCM in passenger kick, gray 40 pin plug, pin 19 Directwire Hood Pin lt. green - hood switch or underhood fuse box, white 16 pin plug, pin 14 Directwire Trunk/Hatch Release gray - BCM in passenger kick, gray 40 pin plug, pin 36 Directwire Trunk Release Motor lt. green (sedan, coupe); yellow (convertible) 5 wire BCM in passenger kick, white 12 pin plug, pin 4 Fuel Door Release (unlocks along with driver door) Tachometer red (sedan, coupe); brown (convertible) ac Power Steering Control Unit behind glove box, white 12 pin plug, pin 10 Clutch Pedal green (input); gray (output) + front clutch switch, blue 2 pin plug, pins 1, 2 Clutch Pedal 2 lt. blue (sedan); red (coupe, convertible) cut back clutch switch, blue 2 pin plug, pin 2 Fuel Pump pink (sedan, coupe); blue (convertible) + driver kick, harness to rear Rear Defroster green - latched dash fuse box, white 10 pin plug, pin 4 or BCM in passenger kick, green 40 pin plug, pin 40 Directwire Mirror Defroster (same as rear defroster) Left Front Heated Seat gray (sedan, coupe, convertible AT); green (convertible MT) + resistor driver heated seat switch, white 10 pin plug, pin 2 Notes Right Front Heated Seat lt. blue + resistor passenger heated seat switch, brown 8 pin plug, pin 2 Notes Speed Sense red (sedan, coupe); gray (convertible) 8-Pulse radio, white 32 pin plug, pin 17 or 22 Brake Wire pink or brown + dash fuse box, white 10 pin plug, pin 3 or BCM in passenger kick, green 40 pin plug, pin 7 Directwire Parking Brake beige (A/T); gray (sedan), violet (coupe, convertible) (M/T) - parking brake switch, white or black 1 pin plug, pin 1 Directwire Notes Horn Trigger lt. green - horn switch, gray 8 pin plug, pin 8 Wipers violet (L); blue (H) + wiper motor or underhood fuse box, white 36 pin plug, pins 2, 3 Left Front Window (Up/Down) (use factory alarm arm/disarm) Right Front Window (Up/Down) (see left front window) Left Rear Window (Up/Down) white - green (without anti-pinch) A driver kick, door harness Right Rear Window (Up/Down) lt. blue - lt. green (without anti-pinch) A driver kick, door harness Sun Roof (Open/Close) pink - gray (sedan); orange - green (coupe) (function with ignition on only) - sunroof switch, white 3 pin plug, pins 1 - 3 Directwire Notes Memory Seat 1 brown - Auto Drive Position Cntrl Unit right of column, wht 32 pin plug, pin 9 Memory Seat 2 violet - Auto Drive Position Cntrl Unit right of column, wht 32 pin plug, pin 25 ------------- Let's Go Brandon Brown. Congratulations on your first Xfinity Series Win. LGBFJB |
