2021 Ram ProMaster City, Alarm Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=147213
Printed Date: April 29, 2026 at 5:38 PM
Topic: 2021 Ram ProMaster City, Alarm Wiring
Posted By: kamikaze4299
Subject: 2021 Ram ProMaster City, Alarm Wiring
Date Posted: January 12, 2022 at 5:25 PM
Does someone have the wiring color diagram for the Ram ProMaster City Van (Small Van)? I have to install a Security System in one for a Customer.
Date Posted: January 12, 2022 at 5:28 PM
Its a 2021 ProMaster City (Small Van)
Posted By: i am an idiot
Date Posted: January 12, 2022 at 6:36 PM
Item      Wire Color      Polarity      Wire Location      Photo      Note
12 Volts      Red/Green (20A)      +      Ignition Switch, black 3 pin plug, pin 2      Directwire
Second 12 Volts      Red/Black (60A)      +      BCM-Dash Fuse Box, 1 pin plug, pin 1
Ground      (chassis ground)
Starter      White/Red      +      Ignition Switch, black 3 pin plug, pin 3      Directwire
Ignition      Dk. Blue      +      Ignition Switch, black 2 pin plug, pin 2      Directwire
Second Ignition      Orange      +      Ignition Switch, black 3 pin plug, pin 1      Directwire
Accessory      Gray      +      Ignition Switch, black 2 pin plug, pin 1      Directwire
Key Release      Brown/Yellow      Cut      Key Lock Solenoid, white 2 pin plug, pin 2      Directwire
CAN Bus High      Green (CAN C)      Data      BCM-Dash Fuse Box, black 60 pin plug, pin 44
CAN Bus Low      Brown (CAN C)      Data      BCM-Dash Fuse Box, black 60 pin plug, pin 45
CAN Bus High 2      Dk. Blue (CAN B)      Data      BCM-Dash Fuse Box, black 60 pin plug, pin 58
CAN Bus Low 2      White (CAN B)      Data      BCM-Dash Fuse Box, black 60 pin plug, pin 57
Power Lock      Violet/Red (need to relay isolate from switch)      - 1000 Ohms      BCM-Dash Fuse Box, black 60 pin plug, pin 51      Directwire
Power Unlock      (same as power lock, front doors only); (for rear doors see trunk/hatch release)      -
Lock Motor      White/Black      Reverse      BCM-Dash Fuse Box, black 32 pin plug, pin 16
Driver Unlock Motor      Orange/Green      Reverse      BCM-Dash Fuse Box, black 32 pin plug, pin 31
Passenger Unlock Motor      (no progressive unlock)
Factory Alarm Arm      (factory remote only)
Factory Alarm Disarm      (transponder and ignition)
Parking Lights      Green/Yellow (LF); Green/White (RF); Yellow/Red (LR); Yellow/Black (RR)      +      BCM-Dash Fuse Box, black 60 pin plug, pins 29, 15; 60 pin plug, pins 6, 5      Directwire
Parking Lights -      Green/Black      -      Headlight-Wiper Switch, 10 pin plug, pin 3
Turn Signal (Left)      Dk. Blue/White (F); Dk. Blue/White (R)      +      BCM-Dash Fuse Box, black 60 pin plug, pin 10; 60 pin plug, pin 1      Directwire
Turn Signal (Right)      Dk. Blue/Black (F); Dk. Blue/Black (R)      +      BCM-Dash Fuse Box, black 60 pin plug, pin 8; 60 pin plug, pin 3      Directwire
Headlight      Green/White (high beams)      -      Headlight-Wiper Switch, 10 pin plug, pin 2
Reverse Light      Gray/Green      +      BCM-Dash Fuse Box, 60 pin plug, pin 44
Left Front Door Trigger      White/Violet      -      BCM-Dash Fuse Box, black 60 pin plug, pin 54      Directwire
Right Front Door Trigger      White/Red      -      BCM-Dash Fuse Box, black 60 pin plug, pin 53      Directwire
Left Rear Door Trigger      White/Violet      -      BCM-Dash Fuse Box, 60 pin plug, pin 40
Right Rear Door Trigger      White/Green      -      BCM-Dash Fuse Box, 60 pin plug, pin 56
Dome Light      Gray/Dk. Blue      -      BCM-Dash Fuse Box, 60 pin plug, pin 9
Trunk/Hatch Pin      White/Gray      -      BCM-Dash Fuse Box, 60 pin plug, pin 39
Trunk/Hatch Release      Violet/Dk. Blue (rear doors unlock)      -      BCM-Dash Fuse Box, black 60 pin plug, pin 24      Directwire
Trunk Release Motor      Orange/Dk. Blue (unlock only)      Reverse      BCM-Dash Fuse Box, black 32 pin plug, pin 30
Tachometer      Brown/Yellow, Brown/Dk. Blue, Brown/Blue, or Brown/Tan      ac      Any Fuel Injector, black 2 pin plug, pin 1
Fuel Pump      Violet/Green      +      Driver Kick, harness to rear
Rear Defroster      Brown/Dk. Blue      - Latched      BCM-Dash Fuse Box, black 60 pin plug, pin 6      Directwire
Mirror Defroster      (same as rear defroster)
Left Front Heated Seat      Gray      Reverse      Driver Seat Heater Switch, 4 pin plug, pin 4
Right Front Heated Seat      Gray      Reverse      Passenger Seat Heater Switch, 4 pin plug, pin 4
Speed Sense      (wheel speed sensor)
Brake Wire      Green/Black (functions with ignition on only)      +      BCM-Dash Fuse Box, black 60 pin plug, pin 34      Directwire
Parking Brake      White/Yellow      -      BCM-Dash Fuse Box, 60 pin plug, pin 19
Horn Trigger      Green/White      -      BCM-Dash Fuse Box, black 60 pin plug, pin 1      Directwire
Wipers      White (LO); White/Red (HI)      +      BCM-Dash Fuse Box, black 32 pin plug, pins 3, 14
Left Front Window (Up/Down)      (motor is part of module)
Right Front Window (Up/Down)      (motor is part of module)
Left Rear Window (Up/Down)      (motor is part of module)
Right Rear Window (Up/Down)      (motor is part of module)
Radio 12V      Red/Green      +      Radio, black 52 pin plug, pin 44
Radio Ground      Black      -      Radio, black 52 pin plug, pin 43
Date Posted: January 18, 2022 at 7:55 PM
Thank You!
Posted By: audiokid1
Date Posted: January 22, 2022 at 8:02 AM
Did you already complete this install? I have some specific details for this vehicle that I could email you.
Date Posted: January 29, 2022 at 12:36 PM
No I have not, but I am starting it today. Here is my email clintonecooper4299@gmail.com
Date Posted: January 30, 2022 at 10:28 AM
I sent you an email with a few details. I hope it helps
Date Posted: January 30, 2022 at 2:31 PM
Can you post those details here as well? It may help someone else in the future.
Date Posted: January 30, 2022 at 5:40 PM
Please see attached photos
posted_image
posted_image
Date Posted: January 30, 2022 at 8:57 PM
Thank You.
Date Posted: January 31, 2022 at 3:48 PM
I wanted to upload this as a pdf, but forgot it's not an option.
Date Posted: January 31, 2022 at 7:14 PM
Look all the way to the right on the browse or search for files
