2005 Dodge Ram, Avistart 4113 Remote Start Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=147252
Printed Date: April 30, 2026 at 4:38 AM
Topic: 2005 Dodge Ram, Avistart 4113 Remote Start Wiring
Posted By: jasonfie00
Subject: 2005 Dodge Ram, Avistart 4113 Remote Start Wiring
Date Posted: February 09, 2022 at 11:02 AM
There is an avistart 4113 remote start/ alarm installed in my 2005 dodge ram 1500 4.7 l V8. Crew cab but doesn't work. I am looking for wiring schematics so I can go through and see what's wrong. Any info would be helpful. Thanks
------------- Jkf
Posted By: i am an idiot
Date Posted: February 10, 2022 at 8:39 AM
12 Volts Red (40A) + Ignition Switch, black 14 pin plug, pin 11 Directwire
Second 12 Volts Red (40A) + Ignition Switch, black 14 pin plug, pin 1 Directwire
Ground (chassis ground)
Starter Yellow + Ignition Switch, black 14 pin plug, pin 13 Directwire
Ignition Pink/Lt. Green + Ignition Switch, black 14 pin plug, pin 3 Directwire
Second Ignition Pink/White + Ignition Switch, black 14 pin plug, pin 2 Directwire
Accessory Dk. Blue + Ignition Switch, black 14 pin plug, pin 8 Directwire
Second Accessory Pink/Yellow (14 AWG) + Ignition Switch, black 14 pin plug, pin 9 Directwire
Third Accessory Pink/Yellow (16 AWG) + Ignition Switch, black 14 pin plug, pin 14
Fourth Accessory Pink/Yellow (12 AWG) (except base) (not required) + Ignition Switch, black 14 pin plug, pin 10
Ignition Interrupt Pink/Gray Cut Sentry Key Immobilizer Module, black 6 pin plug, pin 4
Keysense Violet/Tan - Ignition Switch, black 14 pin plug, pin 5 Directwire
J1850 White/Violet Data OBD-Data Link Connector, black 16 pin plug, pin 2
IMMO Data White/Violet Data Sentry Key Immobilizer Module, black 6 pin plug, pin 2
Door Lock MUX Violet/Dk. Green MUX Above Driver Kick, white 24 pin plug, pin 18 Directwire
Power Lock Violet/Dk. Green - 820 Ohms Above Driver Kick, white 24 pin plug, pin 18 Directwire
Power Unlock (same as power lock) - 330 Ohms
Lock Motor Lt. Green Reverse Above Driver Kick, white 24 pin plug, pin 17 Directwire
Driver Unlock Motor Tan/Lt. Green Reverse Above Driver Kick, white 24 pin plug, pin 20
Passenger Unlock Motor Violet/Lt. Blue Reverse Passenger Kick, white 19 pin plug, pin 9
Factory Alarm MUX Violet/Lt. Blue MUX Above Driver Kick, white 24 pin plug, pin 9 Directwire
Factory Alarm Arm Violet/Lt. Blue - 2000 Ohms Above Driver Kick, white 24 pin plug, pin 9 Directwire
Factory Alarm Disarm (same as factory alarm arm) - 480 Ohms
Parking Lights White/Gray + Junction Connector above driver kick, gray 74 pin plug, pin 19 Directwire
Parking Lights - White/Lt. Green (see Tech Doc 1082) - 270 or - 590 Ohms Headlight Switch, black 8 pin plug, pin 8 Directwire
Parking Lights MUX White/Lt. Green MUX Headlight Switch, black 8 pin plug, pin 8 Directwire
Hazards White/Orange - 120 Ohms Hazard-Wiper Switch, black 4 pin plug, pin 3 Directwire
Turn Signal (Left) (use hazards)
Turn Signal (Right) (use hazards)
Headlight White/Lt. Green (need to relay isolate from switch - 470 Ohms Headlight Switch, black 8 pin plug, pin 8 Directwire
Reverse Light White/Lt. Green + Inside Mirror --or-- Plug by PCM on passenger firewall
Left Front Door Trigger Violet - Above Driver Kick, white 24 pin plug, pin 5 Directwire
Right Front Door Trigger Violet/White (see Tech Doc 1076) - Passenger Kick, white 19 pin plug, pin 1 Directwire
Left Rear Door Trigger Violet/Gray (see Tech Doc 1076) - Above Driver Kick, white 24 pin plug, pin 6 Directwire
Right Rear Door Trigger Violet/Yellow (see Tech Doc 1076) - Passenger Kick, white 19 pin plug, pin 6 Directwire
Dome Light Yellow/Lt. Blue + Left Front Pillar --or-- Under Driver Dash, harness to instrument cluster
Tachometer Dk. Blue/Gray (gasoline) AC PCM on passenger firewall, orange 38 pin plug (second from top), pin 34 Notes
Tachometer 2 Dk. Blue/Gray (diesel) AC ECM on engine lower driver side, 60 pin plug, pin 24 --or-- Camshaft Position Sensor just left of ECM, 3 pin plug Directwire
Wait to Start (see Tech Doc 1091) (or program wait to start timer on remote start) Notes
Clutch Pedal Yellow/Dk. Blue - Clutch Switch, green 2 pin plug, pin 1
Rear Defroster Dk. Blue/Lt. Blue - Latched Junction Connector above driver kick, gray 74 pin plug, pin 1
Left Front Heated Seat Lt. Green/Dk. Green (+ 250 Ohms (LO); + 150 Ohms (HI)) MUX Driver Heated Seat Switch, red 6 pin plug, pin 6 Directwire
Right Front Heated Seat Lt. Green/White (+ 250 Ohms (LO); + 150 Ohms (HI)) MUX Passenger Heated Seat Switch, blue 6 pin plug, pin 6 Directwire
Speed Sense Dk. Green/Yellow AC PCM on passenger firewall, top black 38 pin plug, pin 13 (gas); ECM on engine lower driver side, 50 pin plug, pin 11 (diesel)
Brake Wire White/Tan + Electric Brake Provision Connector above driver kick, blue 4 pin plug, pin C Directwire
Parking Brake Dk. Green/White - Junction Connector above driver kick, gray 74 pin plug, pin 24 Directwire
Horn Trigger Dk. Green/Violet - Horn Switch-Clock Spring, white 6 pin plug, pin 6 Directwire
Wipers Brown/White (LO); Brown/Orange (HI) + Wiper Motor, 4 pin plug, pin B (LO); pin A (HI)
Wipers Protection Brown/Yellow Cut Hazard-Wiper Switch, black 4 pin plug, pin 4 Directwire
Left Front Window (Up/Down) Orange/Lt. Green - Orange/White A Driver Window-Door Lock Switch, blue 12 pin plug, pins 5 - 12
Right Front Window (Up/Down) Orange/Tan - Orange/Gray A Driver Kick, door harness
Left Rear Window (Up/Down) Orange/White - Orange/Gray A Driver Kick, door harness
Right Rear Window (Up/Down) Orange/Lt. Blue - Orange/Dk. Blue A Driver Kick, door harness
------------- Let's Go Brandon Brown. Congratulations on your first Xfinity Series Win. LGBFJB
Date Posted: February 10, 2022 at 8:40 AM
https://www.the12volt.com/installbay/downloads.asp?srch=all&term=4113------------- Let's Go Brandon Brown. Congratulations on your first Xfinity Series Win. LGBFJB
