2013 Nissan NV200, Alarm Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=147411
Printed Date: April 16, 2026 at 8:14 PM
Topic: 2013 Nissan NV200, Alarm Wiring
Posted By: jereli
Subject: 2013 Nissan NV200, Alarm Wiring
Date Posted: July 23, 2022 at 4:59 PM
I am looking for vehicle wiring information to install an alarm system. I did not find one posted in the vehicle wiring section for this model and hoping that someone has one. Thanks.
-J
Posted By: audiokid1
Date Posted: July 23, 2022 at 9:32 PM
Please send me a Private Message with your email and I will send you a PDF document for this install. I had to strip some I.P. off the document so it may read a little strange, but it has enough details for you to complete the installation without any issues.
Posted By: i am an idiot
Date Posted: July 24, 2022 at 12:06 PM
Item Wire Color Polarity Wire Location
12 Volts Blue (40A) + Ignition Switch, white 6 pin plug, pin 3
Ground (chassis ground)
Starter White + Ignition Switch, white 6 pin plug, pin 2
Ignition Red + Ignition Switch, white 6 pin plug, pin 1
Accessory Yellow + Ignition Switch, white 6 pin plug, pin 4
Second Accessory Brown + Ignition Switch, white 6 pin plug, pin 5
Keysense White + Key Switch, gray 6 pin plug, pin 1
CAN Bus High Blue Data OBD-Data Link Connector, white 16 pin plug, pin 6
CAN Bus Low Pink Data OBD-Data Link Connector, white 16 pin plug, pin 14
CAN Bus High 2 Blue Data BCM behind glove box, white 40 pin plug, pin 39
CAN Bus Low 2 Pink Data BCM behind glove box, white 40 pin plug, pin 40
OBD 12 Volts Lt. Green (10A) + OBD-Data Link Connector, white 16 pin plug, pin 16
OBD Ground Black - OBD-Data Link Connector, white 16 pin plug, pin 4
OBD Ignition White + OBD-Data Link Connector, white 16 pin plug, pin 8
OBD Connector White Driver Dash, Behind Fuse Panel Cover
IMMO Data Lt. Green Data NATS Antenna Amp on ignition switch, white 4 pin plug, pin 4
IMMO Data 2 Lt. Green (alternate location) Data BCM behind glove box, white 40 pin plug, pin 25
IMMO Clock Pink Data NATS Antenna Amp on ignition switch, white 4 pin plug, pin 2
IMMO Clock 2 Pink (alternate location) Data BCM behind glove box, white 40 pin plug, pin 21
Security Light Red - BCM behind glove box, white 40 pin plug, pin 23
Power Lock Red - BCM behind glove box, white 40 pin plug, pin 12 --or-- Driver Kick
Power Unlock Violet - BCM behind glove box, white 40 pin plug, pin 13 --or-- Driver Kick
Lock Motor Blue Reverse BCM behind glove box, white 15 pin plug, pin 14 --or-- Driver Kick
Driver Unlock Motor Green Reverse BCM behind glove box, white 15 pin plug, pin 1 --or-- Driver Kick
Passenger Unlock Motor Yellow Reverse BCM behind glove box, white 15 pin plug, pin 13 --or-- Passenger Kick
Factory Alarm Arm Pink (key lock) - BCM behind glove box, white 40 pin plug, pin 8
Factory Alarm Disarm Black (key unlock) Double - BCM behind glove box, white 40 pin plug, pin 7
Factory Alarm Arm2 Pink (alternate location) - Driver Kick, door harness, white 12 pin plug, pin 4
Factory Alarm Disarm2 Black (alternate location) Double - Driver Kick, door harness, white 12 pin plug, pin 7
Parking Lights Violet + Driver Firewall, harness from engine compartment
Hazards Blue - BCM behind glove box, white 40 pin plug, pin 29 --or-- Hazard Switch
Turn Signal (Left) Violet + BCM behind glove box, black 15 pin plug, pin 9
Turn Signal (Right) White + BCM behind glove box, black 15 pin plug, pin 8
Headlight White (L); Lt. Blue or Pink (R) + IPDM E/R-Underhood Fuse Box, white 16 pin plug, pin 5 (L); pin 6 (R)
AutoLights Yellow - BCM behind glove box, white 40 pin plug, pin 33
Reverse Light Green + Driver Firewall, harness from engine compartment
Left Front Door Trigger Brown - BCM behind glove box, black 15 pin plug, pin 4
Right Front Door Trigger Lt. Blue - BCM behind glove box, black 15 pin plug, pin 5
Left Rear Door Trigger Gray - BCM behind glove box, black 15 pin plug, pin 3
Right Rear Door Trigger Lt. Green - BCM behind glove box, black 15 pin plug, pin 2
Dome Light Brown - BCM behind glove box, white 15 pin plug, pin 5
Trunk/Hatch Pin White - BCM behind glove box, black 15 pin plug, pin 7
Trunk/Hatch Release (locks/unlocks along with doors)
Tachometer Red AC Camshaft Position Sensor, engine driver side, green or black 3 pin plug, pin 3
Fuel Pump Green + Driver Firewall, harness from engine compartment
Rear Defroster Gray - BCM behind glove box, white 40 pin plug, pin 10
Mirror Defroster (same as rear defroster)
Speed Sense White (except base audio) 8-Pulse Radio, white 20 pin plug, pin 18
Brake Wire Red + BCM behind glove box, white 40 pin plug, pin 9 --or-- Brake Switch
Parking Brake Lt. Blue - Parking Brake Switch, black 1 pin plug, pin 1
Horn Trigger Red - Horn Switch-Clock Spring, gray 8 pin plug, pin 5
Wipers Yellow (LO); White (HI) + IPDM E/R-Underhood fuse box, brown 12 pin plug, pin 12 (LO); pin 5 (HI)
Left Front Window (Up/Down) Blue - Gray A Power Window Main Switch, white 16 pin plug, pins 8 - 11
Right Front Window (Up/Down) Blue - Yellow A Passenger Power Window Switch, white 12 pin plug, pins 6 - 8
------------- Let's Go Brandon Brown. Congratulations on your first Xfinity Series Win. LGBFJB
Posted By: jereli
Date Posted: July 24, 2022 at 6:45 PM
Thanks for the replies. This will help greatly.
Date Posted: July 24, 2022 at 8:55 PM
I just sent an email with attached document to you
Date Posted: July 26, 2022 at 1:59 PM
Why not post the file here so others will be able to find it in the future------------- Let's Go Brandon Brown. Congratulations on your first Xfinity Series Win. LGBFJB
