’95 Infiniti J30
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=15044
Printed Date: April 30, 2026 at 1:55 AM
Topic: ’95 Infiniti J30
Posted By: glijetta90
Subject: ’95 Infiniti J30
Date Posted: June 16, 2003 at 8:12 PM
Checked database and says nothing about color codes for all the power and remote leads.  Any one know, I have tried everywhere else.  Thanks ahead of time
Posted By: Velocity Motors
Date Posted: June 16, 2003 at 8:29 PM
|              12V|WHITE/ red           |+  |ignition harness            |
|          STARTER|BLACK / YELLOW        |+  |ignition harness            |
|         IGNITION|WHITE/ black         |+  |ignition harness            |
|  SECOND IGNITION|BLACK/ red           |+  |ignition harness            |
|       POWER LOCK|yellow              |-  |theft warn mod. *2          |
|     POWER UNLOCK|GREEN/ red *4        |-  |theft warn mod. *2          |
| PARKING LIGHTS +|yellow/black        |   |at dimmer                   |
| PARKING LIGHTS -|pink (turn signals) |   |turn relay *3               |
|       HEADLIGHTS|wht(R) lt.grn.(L)   |-  |at switch                   |
|     DOOR TRIGGER|GREEN / WHITE         |-  |theft warn mod. *2          |
|  TRUNK/HATCH PIN|red                 |-  |theft warn mod.             |
|         HOOD PIN|BLACK/ pink          |-  |theft warn mod.             |
|TRNK/HTCH RELEASE|PURPLE / white        |-  |at switch                   |
|  FCTRY ALARM ARM|pink                |-  |theft warn mod.             |
|FCTRY ALRM DISARM|orange              |-  |theft warn mod.             |
|       TACHOMETER|blue/white *1       |   |plug on engine harness      |
|       BRAKE WIRE|PURPLE / brown dots   |+  |at switch                   |
|     HORN TRIGGER|gray/blue           |-  |steering column             |
|           WIPERS|lt. GREEN/ red       |-  |at column switch            |
|  LF WINDOW UP/DN|blu/blk - blu/red   |A  |in L.F. door                |
|  RF WINDOW UP/DN|blu/blk - blu/red   |A  |in R.F. door                |
|  LR WINDOW UP/DN|blu/blk - blu/red   |A  |in L.R. door                |
|  RR WINDOW UP/DN|blu/blk - blu/red   |A  |in R.R. door                |
Notes:
*1 Round gray plug taped to harness at passenger rear side of engine. Single blue/white wire at plug. Also found at ECM in the passenger kick panel.  *2 Theft warning module located under drivers side dash.  *3 the turn relay is left of steering column.  *4 Unlock requires a double pulse.
