99 Ford Expedition Wire Diagram Needed
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=15601
Printed Date: May 05, 2026 at 1:59 PM
Topic: 99 Ford Expedition Wire Diagram Needed
Posted By: Infntrymn
Subject: 99 Ford Expedition Wire Diagram Needed
Date Posted: June 28, 2003 at 9:14 PM
Looking for a wire diagram for a 99 Ford Expedition, or to know if it is the same as another year that I can look for.  Thanks.  Rob
Posted By: Velocity Motors
Date Posted: June 28, 2003 at 9:31 PM
|              12V|yellow, grn/purple  |+  |ignition harness            |
|          STARTER|RED / lt. blue        |+  |ignition harness            |
|         IGNITION|blue/lt. green      |+  |ignition harness            |
|  SECOND IGNITION|gray / YELLOW(2nd acc)|+  |ignition harness            |
|        ACCESSORY|RED / black           |+  |ignition harness            |
| SECOND ACCESSORY|BLACK/ green         |+  |ignition harness            |
|       POWER LOCK|pink / YELLOW         |-  |keyless module *2           |
|     POWER UNLOCK|pink/green          |-  |keyless module *2           |
|       LOCK MOTOR|pink/black          |   |drivers kick panel          |
|     UNLOCK MOTOR|RED / orange          |   |drivers kick panel          |
|    DISARM DEFEAT|pink/orange         |   |passengers kick panel       |
| PARKING LIGHTS +|brown               |   |at light switch             |
| PARKING LIGHTS -|                    |   |                            |
|       HEADLIGHTS|                    |   |                            |
|     DOOR TRIGGER|lt. blue/white *3   |-  |keyless module *2           |
| DOME SUPERVISION|BLACK/ lt. blue      |+  |passenger kick panel        |
|  TRUNK/HATCH PIN|tied in with door   |   |                            |
|         HOOD PIN|                    |   |                            |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|                    |   |                            |
|       TACHOMETER|*1                  |   |                            |
|      SPEED SENSE|gray/black          |   |cruise control module *4    |
|       BRAKE WIRE|green               |+  |at brake switch             |
|     HORN TRIGGER|dk. blue            |-  |steering column             |
|           WIPERS|                    |   |                            |
|  LF WINDOW UP/DN|wht/blk - orn/wht   |A  |at drivers door motor       |
|  RF WINDOW UP/DN|tan/blu - wht/yel   |A  |drivers door switch         |
|  LR WINDOW UP/DN|yel/blu - gry/orn   |A  |drivers door switch         |
|  RR WINDOW UP/DN|RED / blk - yel/blk   |A  |drivers door switch         |
Notes:
NOTE: This vehicle is equipted with PATS (Passive Anti Theft System). Use PKF module to over-ride during remote start.  *1 Tach wire: On the 4.6L it is a pink/white in a 3 pin plug at the front of the motor below the air intake and next to the fan. On the 5.4L it is a lt. GREEN / WHITE at the coil on the passenger side of the motor between the fuel injectors.  *2 The keyless module is located high in the drivers kick against the firewall.  *3 One of two. The wire is in pin 11 and it is next to the BLACK/ pink wire. Test with a digital multi-meter ONLY, to keep from damaging the circuit tied into the other lt. blue/white.  *4 The cruise control module is on the driver side fender.
