Request 2000 Chevy Astro Cargo Van (not p
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=17316
Printed Date: April 26, 2026 at 9:25 PM
Topic: Request 2000 Chevy Astro Cargo Van (not p
Posted By: prelude1481
Subject: Request 2000 Chevy Astro Cargo Van (not p
Date Posted: August 07, 2003 at 9:42 PM
I need the wiring diagram for a 2000 chevrolet astro cargo van (not passenger van). I dont know if there may be a difference or not. Any help would be appreciated - i will be doing install on Friday after lunch.
Thanks,
Jeremy
Posted By: ViperATC5
Date Posted: August 08, 2003 at 7:55 AM
The software does not discern a difference between the passenger van and the cargo van- here is the info that I have:
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|red & RED / white |+ |ignition harness |
| STARTER|yellow |+ |ignition harness |
| IGNITION|pink |+ |ignition harness |
| SECOND IGNITION|white |+ |ignition harness |
| ACCESSORY|orange |+ |ignition harness |
| SECOND ACCESSORY|brown |+ |ignition harness |
| POWER LOCK|lt. blue |+ |drivers kick panel |
| POWER UNLOCK|white |+ |drivers kick panel |
| LOCK MOTOR|gray | |drivers kick panel |
| UNLOCK MOTOR|tan | |drivers kick panel |
| DISARM DEFEAT|tan | |passengers kick panel |
| PARKING LIGHTS +|brown | |drivers kick panel |
| HEADLIGHTS|white |+ |headlight switch |
| DOOR TRIGGER|*1 |- |BCM *2 |
| DOME SUPERVISION|gray/black |- |relay above diagnostic plug |
| TRUNK/HATCH PIN|*1 |- |*2 |
|TRNK/HTCH RELEASE|lt. blue |- |relay above diagnostic plug |
| TACHOMETER|white | |PCM *3 |
| SPEED SENSE|GREEN / WHITE | |radio |
| BRAKE WIRE|white |+ |brake switch |
| HORN TRIGGER|black |- |steering column |
| WIPERS|purple |+ |steering column |
| LF WINDOW UP/DN|blue - brown |A |power window switch |
| RF WINDOW UP/DN|lt. blue - tan |A |drivers door harness |
| RADIO 12V|orange |+ |radio |
| RADIO GROUND|black |- |radio |
| RADIO SWITCH|yellow |+ |radio |
| RADIO ILLUMINATE|gray |+ |radio |
| LF SPEAKER|tan - gray | |radio |
| RF SPEAKER|lt. green - green | |radio |
| LR SPEAKER|brown - yellow | |radio |
| RR SPEAKER|blue - lt. blue | |radio |
Notes:
NOTE: This vehicle has the passlock II immobilizer system that, when adding a remote start, must be interfaced with. Use DEI part 555t or 555L. *1 There are 4 separate door trigger wires. You must use all 4 wires and diode isolate each. The drivers door is blue in the purple plug pin B4. The passenger front door is orange in the purple plug pin B2. The sliding door is pink in the lt. blue plug pin B10. The rear door is yellow in the lt. blue plug pin B11. *2 The BCM is located above the climate controls. *3 The PCM is located below the battery.
