| Print Page | Close Window |
96 Honda CRV Wiring and/or location diagrPrinted From: the12volt.comForum Name: Vehicle Wiring Information & File Requests Forum Discription: Request Car Alarm, Car Stereo, Cruise Control, Remote Starter, Navigation, Mobile Video, and Other Vehicle Specific Wiring Info, Manuals, Tech Tips URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=17381 Printed Date: April 27, 2026 at 3:54 AM Topic: 96 Honda CRV Wiring and/or location diagr Posted By: muldrocks Subject: 96 Honda CRV Wiring and/or location diagr Date Posted: August 09, 2003 at 2:23 AM Greeting from Down Under! We have just bought an imported Jap 96 Honda CRV, and wish to add a few extra's ( Alarm, air horns,driving lights, better stereo, courtesy light delay, etc), but have no manual, no diagram, no nothing. ANYTHING will be appreciated. Like today I have found out that whilst the CRV has "central locking" on the 2 back doors and the passengers, there is NOTHING on the drivers door! Couldn't believe it! Last car I was lucky to know the dealer and I got a photocopy of the electrics and location manual. I haven't been able to even locate a Manual for this vehicle! Cheers, and thanks ! John from New Zealand ------------- John Muldrock Hawera New Zealand Replies: Posted By: Montrealler Date Posted: August 09, 2003 at 11:01 AM there is the uk wiring for 97 crv| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V| | | | | STARTER|BLACK/ white | |ignition harness | | SECOND STARTER| | | | | IGNITION|BLACK / YELLOW | |ignition harness | | SECOND IGNITION| | | | | THIRD IGNITION| | | | | ACCESSORY|WHITE/ black | |ignition harness | | SECOND ACCESSORY| | | | | POWER LOCK|blu/wht/silver band |- |in driver door | | POWER UNLOCK|blu/RED / silver band |- |in driver door | | LOCK MOTOR| | | | | UNLOCK MOTOR| | | | | DISARM DEFEAT| | | | | PARKING LIGHTS +|grn/red & grn/yel | |blue plug at fusebox | | PARKING LIGHTS -| | | | | HEADLIGHTS| | | | | DOOR TRIGGER|GREEN/ silver rings |- |grey plug in driver kickwell| | DOME SUPERVISION| | | | | TRUNK/HATCH PIN|blue/black | |at boot switch | | HOOD PIN| | | | |TRNK/HTCH RELEASE| | | | | FCTRY ALARM ARM| | | | |FCTRY ALRM DISARM| | | | | DISARM NO UNLOCK| | | | | TACHOMETER| | | | | SPEED SENSE| | | | | BRAKE WIRE| | | | | HORN TRIGGER|blue/black |- |steering column | | WIPERS| | | | | LF WINDOW UP/DN| | | | | RF WINDOW UP/DN| | | | | LR WINDOW UP/DN| | | | | RR WINDOW UP/DN| | | | | SUN RF OPN/CLOSE| | | | | SUN ROOF LIMIT| | | | | RADIO 12V| | | | | RADIO GROUND| | | | | RADIO SWITCH| | | | | RADIO ILLUMINATE| | | | | POWER ANTENNA| | | | | LF SPEAKER| | | | | RF SPEAKER| | | | | LR SPEAKER| | | | | RR SPEAKER| | | | Notes: and the one for american crv | ITEM | WIRE COLOR |POL| WIRE LOCATION | | 12V|white |+ |ignition harness | | STARTER|BLACK/ white |+ |ignition harness | | IGNITION|BLACK / YELLOW |+ |ignition harness | | ACCESSORY|yellow |+ |ignition harness | | SECOND ACCESSORY|WHITE/ black |+ |ignition harness | | POWER LOCK|GREEN / WHITE *2 |- |driver door harness *3 | | POWER UNLOCK|GREEN/ orange *2 |- |driver door harness *3 | | LOCK MOTOR|WHITE/ red | |drivers kick panel | | UNLOCK MOTOR|blue/red | |drivers kick panel | | DISARM DEFEAT|yellow/red | |passengers kick panel | | PARKING LIGHTS +|RED / black | |dash dimmer | | PARKING LIGHTS -|blue/red | |*6 | | HEADLIGHTS|RED / white |+ |headlight switch | | DOOR TRIGGER|lt. GREEN/ red |- |drivers kick *3 | | DOME SUPERVISION|comes on with unlock| | | | TRUNK/HATCH PIN|blue/black |- |drivers kick *3 | | HOOD PIN|yellow/red or yellow|- |hood switch *3 | |TRNK/HTCH RELEASE|yellow |+ |release switch | | TACHOMETER|blue | |distributor *1 | | SPEED SENSE|blue/white | |instrument cluster or PCM *7| | BRAKE WIRE|GREEN / WHITE |+ |cruise control *5 | | HORN TRIGGER|gray *4 |- |drivers kick | | WIPERS|blue(L), blu/yel(H) |- |steering column | | LF WINDOW UP/DN|RED / blu - RED / yel |A |power window switch | | RF WINDOW UP/DN|blu/yel - blu/orn |A |power window switch | | LR WINDOW UP/DN|grn/yel - green |A |power window switch | | RR WINDOW UP/DN|yellow - yel/grn |A |power window switch | Notes: *1 Also found at the 2-pin tach test connector on the drivers side of the firewall. *2 Must use relays to trigger the lock and unlock wires. *3 Also found at the green factory alarm plug located in the drivers kick panel. *4 May also use blue/green at the steering column, negative trigger. *5 The cruise control module is located in the drivers kick panel. *6 This wire only works if there is a factory alarm installed. It is at the green factory alarm plug in the drivers kick. *7 The PCM is in the passenger kick panel. VSS is in the 31 pin plug, pin 18. Posted By: muldrocks Date Posted: August 09, 2003 at 1:04 PM Thanks Montrealler Still interested in anything anyone else can provide . . . . Have worked out that since there is no door lock motor on the drivers door, the easist way is to fit one and let my alarm operate that one, and it will operate the factory "central locking" Cheers ------------- John Muldrock Hawera New Zealand |
