Installing a battery isolator 98 S10 truc
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=18041
Printed Date: April 03, 2026 at 5:39 PM
Topic: Installing a battery isolator 98 S10 truc
Posted By: adnorth5646
Subject: Installing a battery isolator 98 S10 truc
Date Posted: August 25, 2003 at 10:38 AM
Can anyone help me install a battery isolator in my 98 S10 pickup?  I am planning on purchasing the SR 200 amp model isolator.  Thank you
Posted By: mj239air
Date Posted: August 25, 2003 at 11:00 AM
What help do you need? It is pretty straight forward install. Hook battery wire to one side from front, then second wired goes to second battery. 2 smaller connectors - 1 goes to grnd, the other goes to swtchd 12volt source. try and find a 12 volt source that has about 25 amp fuse just to be on save side. shouldn't pull more than 3-4 amps, just don't want to blow a fuse.
