2004 Nissan Murano Alarm/Remote Start Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=24886
Printed Date: April 19, 2026 at 11:01 AM
Topic: 2004 Nissan Murano Alarm/Remote Start Wiring
Posted By: Khoy
Subject: 2004 Nissan Murano Alarm/Remote Start Wiring
Date Posted: January 19, 2004 at 4:52 PM
Please... Help, I'm looking for wiring diagram for Nissan Murano 2004. Thanks.
KC.
Posted By: my2004murano
Date Posted: January 24, 2004 at 9:18 PM
Me too! I'm trying to install an Infinity Basslink powered subwoofer, and need a plan of attack. Thanks!!
------------- JaY
Posted By: Khoy
Date Posted: January 27, 2004 at 5:26 PM
If anyone has the wiring information on Murano 2003 will do too. Thanks,
KC.
Posted By: Big Dog
Date Posted: January 29, 2004 at 9:59 AM
Hey Guys,
Try this:
Nissan » Murano » SUV » 2004
12 VOLTS green + ignition harness
STARTER 1 large BLACK/ red + ignition harness
STARTER 2 BLACK / YELLOW + ignition harness
IGNITION 1 small BLACK/ red + ignition harness
ACCESSORY 1 red + ignition harness
ACCESSORY 2 WHITE/ blue (radio) + ignition harness
KEYSENSE BLACK/ red ignition harness
POWER LOCK blue - drivers door
POWER UNLOCK red - drivers door double pulse
Pulse must be shorter than one second otherwise windows will roll down.
DISARM NO UNLOCK single pulse unlock wire
FACTORY ALARM DISARM single pulse unlock wire
Can also disarm using valid transponder key and ignition.
PARKLIGHTS POSITIVE RED / blue + white plug rear fusebox
Also in driver's kick.
BRAKE RED / green + brakeswitch
Also found in white plug at rear of fusebox or driver's kick.
DOOR PIN
LF door trigger is light blue (-) in driver's kick from door harness. To shut off auto headlamps, you must trigger this wire using the re-arm from the aftermarket unit. Lights will shut off after 45 seconds.
TACH gray/red A/C at coil
HORN GREEN/ orange - steering column
Posted By: Khoy
Date Posted: January 29, 2004 at 10:22 AM
Thank you very much Big Dog.
KC.
