directfax document
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=25087
Printed Date: March 28, 2026 at 1:03 PM
Topic: directfax document
Posted By: brianl
Subject: directfax document
Date Posted: January 22, 2004 at 6:21 PM
where do i go to view these types of documents that are refered to in remote start diagrams. For example directfax document # 1055 for a bmw?
Posted By: tom cat
Date Posted: January 22, 2004 at 7:19 PM
u need to have a pass word for dei to log on to there site or to call in they will fax it to u but need a pass word
tom cat
Posted By: tom cat
Date Posted: January 22, 2004 at 7:36 PM
this is for the light flash frist remove the light control assembly from the dash. snap off the switch bezel. pull the switch bezel directly towards you keeping thr ribbon cable flat. separate the individual wires in the ribbon cable and cut the fourth wire from the left interruping this wire will activate the parking lights this circuit must be broken in order to flash the parking lights extend the wires out of light control assembly to a length that will allow the relay to be mounted without putting pressure on the ribbon cable.       85 to neg parking light output 86 to 12 volt constant 87a to wire that was cut 30 to the switch side of the wire that was cut . hope this helps this is for the 99 3 series 4 door and the 2000 2001 3 seriesposted_image
tom cat
Posted By: tom cat
Date Posted: January 22, 2004 at 7:40 PM
bmw 1997 and later5 and 7 series     the connection is a the rear of thr light switch thr relay is wired thr same but no ribbon cable there is one black wire interrupting that wire will activate the parking lightsposted_image posted_image
tom cat
Posted By: itmdtr
Date Posted: January 31, 2004 at 6:49 AM
I found them here:
https://www.drdetailshop.com/techtips.htm
itmdtr
