88 Grand Marquis remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=25443
Printed Date: May 10, 2026 at 3:06 PM
Topic: 88 Grand Marquis remote start
Posted By: 88Marquis
Subject: 88 Grand Marquis remote start
Date Posted: January 28, 2004 at 4:51 PM
Hi i'm new to this forum and it seems like it's extremely interesting. I'm a proud of owner of an older but very comfortable 1988 Grand Marquis. I've always liked the older cars alot better than newer for some odd reason lol..
I live in Chicago and it's gets really cold in the winter... and my tank doesnt heat up as quickly as newer cars i'm not complaining my car has treated me very well.. other than the heater taking 15 minutes to blow out hot air and me having to warm up the car for a while.... my car is parked around 400 feet from my house and was wondering if i can use a remote car start sort of thing... and if so do you guys have a wiring diagram for it? I would really appreciate the info.... I feel like i have a beater compared to all the new cars posted... thanks, Jim
Car specs 302 EFI. Automatic Transmission, power interior everything it seems like.
Date Posted: January 29, 2004 at 10:38 AM
Anyone? posted_image
Posted By: Teamrf
Date Posted: January 29, 2004 at 3:02 PM
Let me take a look and see if I can find some info on your car. If not, don't worry grab you a meter and test all the wires. That's how the old school installers use to have to do it. Some installers still do it that way.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Posted By: Teamrf
Date Posted: January 29, 2004 at 3:06 PM
Alarm
Constant 12 voltsYELLOW AND YELLOWIGNITION SWITCH HARNESS
Ignition 12 voltsRED / LIGHT GREENIGNITION SWITCH HARNESS
StarterWHITE/ PINKIGNITION SWITCH HARNESS
Dome LightBLACK/ LIGHT BLUE(+) AT PIN SWITCH OR COURTESY LIGHT
Trunk Pin SwitchN/A
Parking LampBROWN(+) AT LIGHT SWITCH
Power LockPINK / YELLOWDRIVER KICK #202
Power UnlockPINK/LIGHT GREENPANEL * #203
Accessories
Window UpD\ YEL P\ YEL/BLK D\ YEL/L BLU P\ YEL/BLK @ MAIN
Window DownF/ WHT/BLK F/ RED / BLK R/ RED / L BLU R/ RED / BLK SWITCH #211
Ign Key WarnBLACK/ PINK(-) STEERING COLUMN HARNESS
Trunk ReleasePURPLE / YELLOW(+) AT RELEASE SWITCH #231
OEM HornYELLOW/LIGHT GREEN(-) STEERING COLUMN HARNESS
HeadlightsRED / YELLOW(+) AT HEADLIGHT SWITCH
OEM Alarm ArmN/A
OEM Alarm DisarmN/A
Remote Start
Tach SignalDARK GREEN/ YELLOWAT COIL OR ENGINE CONTROL MODULE *
Ignition #2GRAY / YELLOWIGNITION SWITCH HARNESS
Ignition #3N/A
AccessoryBLACK/ LIGHT GREENIGNITION SWITCH HARNESS
Neutral SafetyNOT GROUNDING TYPE -OEM SWITCH OPENS STARTER CIRCUIT
Brake LightLIGHT GREEN(+) AT SWITCH ABOVE BRAKE PEDAL
Reverse LightBLACK/ PINK (+)GEAR SELECT SWITCH
Rear Window DefrostN/A
* 5.8L Engine Is Carburated, Rest Are Electronic Fuel Injection.
~The Rookie~
Posted By: Teamrf
Date Posted: January 29, 2004 at 3:07 PM
Be sure to still test with a DMM not a test light. You some of these tech sheets are wrong. Good luck..hope this helps.
~The Rookie~
Date Posted: January 29, 2004 at 3:51 PM
Thanks alot i will work on it right away.... I appreciate the help!!!!!
