2004 Chevrolet Avalanche Alarm/RS/Stereo Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=25529
Printed Date: May 14, 2026 at 7:34 PM
Topic: 2004 Chevrolet Avalanche Alarm/RS/Stereo Wiring
Posted By: Fosgate3
Subject: 2004 Chevrolet Avalanche Alarm/RS/Stereo Wiring
Date Posted: January 29, 2004 at 10:03 PM
I'm looking for some wiring colors/codes for a 2004 Avalanche. Can anyone help me or direct me to a site that will have this? This vehicle has Bose.
Posted By: Teken
Date Posted: January 29, 2004 at 10:22 PM
Chevrolet
Avalanche
2002-2003
Remote Starter Wiring Colors and Notes
Function
   Vehicle Color
Location
Start:
   Yellow (+)
Ignition switch harness
Ignition #1:
   Pink (+)
Ignition switch harness*
Ignition #2:
   White (+)
Ignition #3:
   N/A
Accessory:
   Orange (+)
Brake Light:
   White (+)
Brake pedal switch
Tach Signal:
   IF YOU HAVE ANY INFORMATION
PLEASE FAX IT TO 1-703-912-6893
Parking Lights:
   Brown (+)
Drivers kick panel
Headlights:
OEM Alarm Disarm:
   Lt.Green (-)
Drivers door module in door
OEM Alarm Arm:
   N/A
Diesel Glow Plug:
   N/A
Clutch Bypass Wire:
   N/A
Notes:
   *This Vehicle Is Equipped With GM's PassKey III Anti-Theft System, Use Universal Alarm Bypass Module or Vehicle Specific Bypass.
Chevrolet
Avalanche
2002-2003
Alarm and Keyless Entry Wiring Colors and Notes
Function
   Vehicle Color
Location
Constant +12 Volts:
   Red & RED / White (+)
Starter Kill:
   Yellow (+)
Ignition +12 Volts:
   Pink (+)
Dome Lights/Superv:
   N/A
OEM Horn:
   Black or BLACK / YELLOW (-)
Gray plug at BCM, BCM is located behind the headlight switch.
Power Lock:
   N/A
Power Unlock:
   N/A
Trunk Release:
   N/A
Alarm Input Wire:
   N/A
Notes:
**Use vehicle specific door lock module DTI part #23561.
Should be the same . . . If not, break out the DMM and varify all connnection points, as you would do anyways.
Regards
EVIL Teken . . .
Posted By: Teken
Date Posted: January 29, 2004 at 10:24 PM
AVALANCHE          2002-2004
WIRE COLORS LOCATION
12 VOLTS CONSTANT RED & RED / WHITE IGNITION HARNESS
IGNITION 1 PINK (16 AWG) IGNITION HARNESS
IGNITION 2 WHITE (18 AWG) IGNITION HARNESS
ACCESSORY /HEATER BLOWER 1 ORANGE IGNITION HARNESS
ACCESSORY /HEATER BLOWER 2 BROWN IGNITION HARNESS
STARTER YELLOW (18 AWG) IGNITION HARNESS
PARKING LIGHTS ( +) BROWN DRIVER KICK PANEL
DOMELIGHT   *SEE NOTES * 1
POWER DOOR LOCK   *3
POWER DOOR UNLOCK   *SEE DIAGRAM*
TACH SENSOR NOT PINK ANY FUEL INJECTOR
BRAKE WHITE ( + ) AT THE BRAKE PEDAL SWITCH
HORN BLACK / YELLOW OR BLACK ( - ) AT THE STEERING COLUMN OR GRAY PLUG AT THE BCM *2
FACTORY DISARM LT. GREEN ( - ) DRIVER DOOR MODULE IN DOOR
FACTORY ANTI-THEFT TYPE PASSLOCK 2
NOTES:
*1 - The driver door trigger is gray/black at the driver door module in the door. The RF door trigger is BLACK/ white at the passenger door module in the door. The LR door trigger is lt. blue/black and the RR is lt. GREEN/ black, they are in a harness in front of the fuse box leading to the BCM rear plug. Use all four wires and diode isolate each.
*2 - The BCM (Body Control Module) is under the driver side dash.
*3 - At the BCM in the purple plug, look at row B, cavity two and three should be open with not wires in then. If you make connectors for these pins you can connect them as a( TYPE B ) door locking system.
Posted By: Big Dog
Date Posted: January 30, 2004 at 10:44 AM
Tell me if this looks familiar.
posted_image
Prepare your future. It wasn't the lack of stones that killed the stone age.
Posted By: Raypaetzold
Date Posted: January 31, 2004 at 7:05 PM
Check out  the install Dr. for your wiring needs. Has alot of info for new installers.
https://www.installdr.com/Harnesses/GM-Wiring.pdf
Remember to check all wires with a DMM before conecting anything!!
Ray Paetzold
