96 range rover diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=2685
Printed Date: May 12, 2026 at 5:23 PM
Topic: 96 range rover diagram
Posted By: teammarkiss
Subject: 96 range rover diagram
Date Posted: August 11, 2002 at 7:55 AM
  I am in desperate need of the wiring diagram of a 1996 Land Rover, Range Rover. I'm installing a remote start alarm and i need to know how to completely shut down the factory alarm.
  Your assistance is greatly appreciated..
Posted By: Velocity Motors
Date Posted: August 11, 2002 at 9:50 AM
|              12V|red                 |+  |battery                     |
|          STARTER|WHITE/ red           |-  |ignition harness            |
|         IGNITION|white *4            |-  |ignition harness            |
|        ACCESSORY|WHITE/ pink          |-  |ignition harness            |
|       POWER LOCK|ORANGE / black        |5wi|drivers door motor          |
|     POWER UNLOCK|pink/black          |5wi|drivers door motor          |
| PARKING LIGHTS -|ORANGE / red          |   |BCM *1                      |
|       HEADLIGHTS|blue                |-  |BCM *1                      |
|     DOOR TRIGGER|PURPLE / red          |-  |BCM *1                      |
|  TRUNK/HATCH PIN|purple / YELLOW       |-  |BCM *1                      |
|         HOOD PIN|PURPLE / white        |-  |BCM *1                      |
|TRNK/HTCH RELEASE|white *2            |-  |release switch              |
|  FCTRY ALARM ARM|blue/red *3         |-  |drivers door module         |
|FCTRY ALRM DISARM|same wire *3        |   |                            |
|       TACHOMETER|WHITE/ black         |   |ignition coil               |
|       BRAKE WIRE|GREEN/ blue          |+  |BCM *1                      |
|     HORN TRIGGER|PURPLE / brown        |-  |BCM *1                      |
|           WIPERS|pink/lt. green      |-  |BCM *1                      |
|  LF WINDOW UP/DN|gry/wht - gry/grn   |   |drivers door module         |
|  RF WINDOW UP/DN|gry/wht - gry/grn   |   |R.F. door module            |
|  LR WINDOW UP/DN|gray - gry/orn      |   |BCM *1                      |
|  RR WINDOW UP/DN|gray - gry/orn      |   |BCM *1                      |
Notes:
*1 The BCM is located under the passenger front seat.  *2 High current negative, use relay.  *3 A negative pulse when locking will arm, and a negative pulse when unlocking will disarm.  *4 To interface with the negative ignition wire to remote start, see directfax document #1500 for wiring information.
