2003 GMC Yukon alarm/remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=27499
Printed Date: March 20, 2026 at 11:20 PM
Topic: 2003 GMC Yukon alarm/remote start
Posted By: sickstyles
Subject: 2003 GMC Yukon alarm/remote start
Date Posted: March 01, 2004 at 9:43 AM
Sup everybody,
I'm looking for the wire colors and locations to install an alarm on a 2003 GMC Yukon. Thanks for the help!
Date Posted: March 02, 2004 at 2:19 PM
anyone?? (remote start too)
Posted By: eespro
Date Posted: March 02, 2004 at 2:38 PM
Before you attempt to install your alarm are you aware of the transponder on the vehicle and the databus. If not you may want to think about letting a shop install your alarm. On the other hand if you want adventure out there you I can sell you the transponder or databus device needed to make your alarm function with the truck. Let me know
timetooride@hotmail.com
Date Posted: March 03, 2004 at 1:45 PM
The transponder wont be a problem, the owner of the car had a basic key made at home depot and it works to start the car so it isnt equipped with a transponder. All i need is the colors for the ignition and accesory wires. Anyone out there have them??????
Date Posted: March 03, 2004 at 1:57 PM
Found them in an old post, thank god for this Forum....
Posted By: NowYaKnow
Date Posted: March 03, 2004 at 5:24 PM
"The transponder wont be a problem, the owner of the car had a basic key made at home depot and it works to start the car so it isnt equipped with a transponder."
That's because they don't come with transponders. That vehicle has passlock 2 and you will need a passlock 2 bypass. Passlock 2 doesn't have ANYTHING in the keys themselves and they can be started with any cut key, as you mentioned. Good luck,
Mike
Posted By: eespro
Date Posted: March 04, 2004 at 6:43 AM
Thanks NowYaKNow. I guess it takes two people to let a person know that they need transponder bypass. The actual transponder is more or less a resistor located in the ignition cyclinder of the truck. When you start the vehicle a resistence is sent to the module to activate the fuel pump. If the incorrect resistance is sent more than three times the system WILL LOCK YOU OUT FOR 30 to 60 minutes. You will need resistors and a relay or a transponder bypass. PM me for more info or check your local install shop out for a passlock II device.
Posted By: CISCOJR442003
Date Posted: March 29, 2004 at 3:47 PM
YOU WILL ALSO NEED A 456G MADE BY DEI TO MAKE YOUR DOORLOCKS WORK AND IT ALSO DISARMS YOUR FACTORY ALARM
